Author Topic: [GB] GMK Triumph Adler. Pics posted...  (Read 577481 times)
Re: [GB] GMK Triumph Adler
« Reply #650 on: Wed, 01 April 2015, 17:47:40 »
Bought this set to put on a Gon I'm going to order.  Now if I could just settle on a switch type...
When in doubt, clears. When not in doubt, clears. When thinking about whether or not you're in doubt, clears. Hope that clears things up for you  :cool:
The choice is clear!
Offline dimmu
« Reply #651 on: Wed, 01 April 2015, 17:49:41 »
I bought a new keyboard JUST for this set....
Like seriously...
SERIOUSLY
i feel your pain. i bought a lightpad to go with my 60% board for this set, but since i ordered 2 sets i figured that other one would be a waste, so i did what any sensible man would do, i bought another 60% board + numpad combo.
Offline ideus
  • Björkö.
« Reply #652 on: Wed, 01 April 2015, 17:51:01 »
Like seriously...
SERIOUSLY
Just keep it unused and wait for its price to climb and then sell it.
Offline Jokrik
« Reply #653 on: Wed, 01 April 2015, 17:55:37 »
Like seriously...
SERIOUSLY
:( :( where's the sharing love?
Offline feizor
« Reply #654 on: Wed, 01 April 2015, 19:36:32 »
I wasn't going to join... But I joined.
Offline Elrick
  • Hype Master
  • Keyboard Orgasmist
« Reply #655 on: Wed, 01 April 2015, 19:55:08 »
I just installed Dolch on my Poker II w/ Clears. GMK caps are mega tight on Clears, at least compared to the PuLSE set I just pulled. If you end up with Clears, buy some spare switches in case you rip the stems out your first few pulls :)
Damn newbs, ALWAYS use a lubricant when installing tight fitting caps.
Rule one when you first pick up a new keyboard with Clear-based MX switches, apply KY on the open-stem of the GMK KEY, then easy-peasy - slide it in.  Don't tell me you never applied some lube onto your manhood for any back door action in your life?
Same thing here, never go in RAW because it will be painful and hideous for the recipient, no matter what.
Don't be a fool always go in with some lube for easy access (keyboard wise and for everything else in LIFE)  8) .
Offline cjhard
  • Claudia the Magnificent
« Reply #656 on: Wed, 01 April 2015, 20:03:10 »
I will tell you I have never done this. It would be an impressive feat indeed, considering the circumstances.
I didn't have any lubricant on hand, but I'm not too concerned about GMK on my Clears. I'm great with the wiggles, and my Poker is low-pro so I can wedge a stem-keeper down under there to hold the stem down.
« Reply #657 on: Wed, 01 April 2015, 20:33:28 »
Offline MysteryOfTime
« Reply #658 on: Wed, 01 April 2015, 20:47:37 »
Any chance on having 'Super" keys to replace the Windows key? :D
Offline njbair
    • nickbair.net
« Reply #659 on: Wed, 01 April 2015, 20:59:50 »
Do people even read threads?
My boards:
« Reply #660 on: Wed, 01 April 2015, 21:02:10 »
Plus, whenever someone reads a thread to me
« Reply #661 on: Wed, 01 April 2015, 21:02:43 »
No would answer both questions.
« Reply #662 on: Wed, 01 April 2015, 21:04:01 »
So fresh and innocent.  :))
« Reply #663 on: Wed, 01 April 2015, 21:05:03 »
Sorry, I had searched and didn't find any info on it - I will dig deeper.
« Reply #664 on: Wed, 01 April 2015, 21:08:08 »
More info in IC thread here: https://geekhack.org/index.php?topic=65724.0
The set is not subject to further changes.
It has been mentioned quite a few times that there will be no changes.
Not to mention that the buy has already begun, and as such there can be no further changes, even if intelli desired so.
Offline njbair
    • nickbair.net
« Reply #665 on: Wed, 01 April 2015, 21:38:59 »
Don't apologize. I was just being snarky. It's just that there have been so many people making so many requests for so many changes. It even created a lot of controversy towards the beginning of the buy.
My boards:
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #666 on: Wed, 01 April 2015, 21:39:54 »
There is still controversy to the buy because of issues that people didn't bring up when they had the chance
Offline tanker666
  • Izaayaaa!
« Reply #667 on: Thu, 02 April 2015, 22:08:25 »
Reached 700! :p
  PurePro
Offline VesperSAINT
  • vpsert
  • #CustomKorean
« Reply #668 on: Thu, 02 April 2015, 22:11:17 »
Like seriously...
SERIOUSLY
I knowww what it issss ~~~~ <3333
Offline nightdriver
  • life is like t. rex
« Reply #669 on: Thu, 02 April 2015, 22:39:55 »
i'm likely going to buy a keyboard just for this... not sure which one yet though.
seems like a winkeyless g80-3000 would be ideal, but those are hard to come by.
Offline user 18
« Reply #670 on: Thu, 02 April 2015, 23:18:35 »
Joined. It tells me I'm #701, don't know if that's true or not.
Avatar by ashdenej
Offline ideus
  • Björkö.
« Reply #671 on: Thu, 02 April 2015, 23:39:09 »
Why do you think it may not be true? There is no reason for MD to cheat you with your position in the orders queue.
Offline user 18
« Reply #672 on: Thu, 02 April 2015, 23:43:34 »
It also said there were 701 joined already before I joined.
Avatar by ashdenej
Offline Jokrik
« Reply #673 on: Thu, 02 April 2015, 23:46:26 »
Like seriously...
SERIOUSLY
Wink
You won't go wrong with that choice :)
Offline njbair
    • nickbair.net
« Reply #674 on: Fri, 03 April 2015, 00:30:46 »
That just means someone backed out while you were joining. I started at #73 and I'm down to #71 right now.
My boards:
Offline nightdriver
« Reply #675 on: Fri, 03 April 2015, 00:42:41 »
if you have any leads, let me know!
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #676 on: Fri, 03 April 2015, 02:23:52 »
+1 let me know also  :)
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
Offline bazh
« Reply #677 on: Fri, 03 April 2015, 05:22:06 »
****ing damn MassDrop, it show error every time I try to order this
HHKB Pro2 white
Newbie again
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #678 on: Fri, 03 April 2015, 05:27:10 »
Maybe massdrop block all paypals from Vietnam  :confused: I try with address in US but I can't pay via paypal  :confused:
Offline bazh
« Reply #679 on: Fri, 03 April 2015, 05:28:42 »
I pay by credit card but still it's not working
HHKB Pro2 white
Newbie again
  • Frenzy Classic.
« Reply #680 on: Fri, 03 April 2015, 05:33:08 »
Or you should use proxy to pay like me.
Offline cjhard
« Reply #681 on: Fri, 03 April 2015, 09:04:55 »
Somebody in the first 6 orders must have increased their qty, as I started out in #7 and now I'm at #9 :<
Offline morpheus
« Reply #682 on: Fri, 03 April 2015, 09:20:11 »
Only 1 more day left!
Offline engicoder
« Reply #683 on: Fri, 03 April 2015, 09:26:29 »
Some how I moved the other way, from #75 to #77. I guess maybe someone ahead of me order more sets?
Offline cjhard
« Reply #684 on: Fri, 03 April 2015, 10:59:39 »
Since only 1 day is left, should this be reposted to /r/mk?
Also, can you imagine how big this could have been if it was open for orders nearly as long as Hyperfuse? We got over 700 in less than two weeks. I'm sure some people are missed just because their next paycheck hasn't come along in time.
« Last Edit: Fri, 03 April 2015, 11:12:21 by cjhard »
Offline heedpantsnow
  • Old enough to know better
« Reply #685 on: Fri, 03 April 2015, 12:29:34 »
Just upped my order by 1 to proxy for bazh.
I'm back.
Offline exitfire401
  • The Force is Re/\l
« Reply #686 on: Fri, 03 April 2015, 12:40:01 »
Come on, everyone! I want to see this hit 800! I'm amazed at the support that came out of the woodworks for this set. I completely expected it to hit 500, wasn't expecting this high of numbers at all.
Offline intelli78
« Reply #687 on: Fri, 03 April 2015, 14:13:20 »
on it ;)
Offline CommonCurt
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #688 on: Fri, 03 April 2015, 15:34:42 »
Order placed.
WTB/WTS/WTT ---->
Offline bazh
« Reply #689 on: Fri, 03 April 2015, 15:35:43 »
HHKB Pro2 white
Newbie again
Offline mz/x
« Reply #690 on: Fri, 03 April 2015, 17:12:36 »
on it ;)
What time will the MD exactly end? I wanted to place another order but also having trouble with payment. I hope tomorrow I will be able to do it.
« Last Edit: Fri, 03 April 2015, 18:32:32 by mz/x »
Offline justify
  • Great news!
« Reply #691 on: Fri, 03 April 2015, 18:51:01 »
does this set only come with 6.25u spacebars? I would love a 6.5u for my TK!
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #692 on: Fri, 03 April 2015, 18:59:03 »
6.25u and 7u, you should probably upgrade to a standard sized board if you don't have one, just for compatibility
Offline user 18
« Reply #693 on: Fri, 03 April 2015, 18:59:15 »
This set has 6.25u and 7u spacebars. I'm not sure if GMK even has 6.5u moulds.
Avatar by ashdenej
Offline Elrick
  • Hype Master
« Reply #694 on: Fri, 03 April 2015, 19:01:10 »
Word to the wise here on this forum, FIRST buy this key-set, then purchase a keyboard for it (in case you don't have one that is appropriate for this fine piece of TA)  8) .
Offline justify
  • Great news!
« Reply #695 on: Fri, 03 April 2015, 19:02:28 »
Haha okay then, I don't have the money to buy a suitable keyboard and the set, so I'll give both of em a miss :(
Offline nightdriver
« Reply #696 on: Fri, 03 April 2015, 19:17:59 »
until i can find a keyboard suitable for the 7u spacebar, i'll probably put this keyset on the ducky shine year or the snake i just bought.  i think it might look nice with the aluminum.
Offline missalaire
  • Great Finder of Great Finds
« Reply #697 on: Fri, 03 April 2015, 20:09:58 »
The Ducky YOTS that went for $162.50 on ebay? You bastard, outbid me :P
Offline nightdriver
« Reply #698 on: Fri, 03 April 2015, 20:53:59 »
hahaha sorry.  i set up a snipe for $170 and it got damn close!
Offline missalaire
« Reply #699 on: Fri, 03 April 2015, 21:02:21 »
I had my max bid set @ $150 in the hopes I could snag it for pretty cheap. I should've set it higher, but oh well. I bought a GMK Dolch and Olivetti set and I'm waiting for a decent deal on a GTX 970 so probably better off not spending any more money XD
