Author Topic: Help with JIS layout bottom row  (Read 2616 times)
Offline VinnyCordeiro
« on: Fri, 27 March 2015, 19:21:59 »
I'm designing a 60% board that will support as many layouts as possible. Right now it has support for:
  • ANSI
  • ISO
  • ABNT 2 (which is an ISO/JIS hybrid layout. Yeah, Brazilian standard is weird.)
  • Partial JIS support (continue reading)
Now I'm trying to solve a problem with JIS layout: the bottom row. I'm trying to use as much standard keycaps as possible, so I reached this configuration: http://www.keyboard-layout-editor.com/#/layouts/763af5efef5f020b4251799278bbdb66
The spacebar in the link is using a 1×2 keycap, but possibly can be changed with no problems to a 1×2.25 keycap (not in the mockup, though). Japanese typers: is that bottom row layout good enough? Any suggestions for changes? Remember: I'm trying to use standard keycaps.
Offline KRKS
  • Your friendly neighbourhood umbrella
Re: Help with JIS layout bottom row
« Reply #1 on: Sat, 28 March 2015, 03:50:00 »
I think JIS spacebars are 2.5u, but I'm not sure.
What I'd actually do is change right winkey to 1u and use a blank right shift as a spacebar, since JIS uses a 1.75u one anyway.
The increasing power of Massdrop WILL kill the community group buys - don't come crying to me after it happens when you're too stupid to see it now. Join me in saving the community!
MD = NO $, NO EXCEPTIONS
Offline berserkfan
« Reply #2 on: Sat, 28 March 2015, 05:39:16 »
JIS spacebars are 3 and 4.5u depending on whether you're using standard Filco JIS, or Filco minila.
« Reply #3 on: Sat, 28 March 2015, 09:25:10 »
Yeah, that's why I have doubts. It seems that there isn't a rigid standard, or I can't find one. From what I researched, spacebar isn't needed in Japanese and Chinese as we Western language users need, that's why it's so tiny.
And 1×2.5 is exactly the keycap that I want to avoid, KRKS. I can't find it for sale on the aftermarket; SP don't sell them, for example. I think your suggestion would be fine, with a 1×2.75 spacebar: http://www.keyboard-layout-editor.com/#/layouts/f769d80f941f5b726f11d08273602532
