Author Topic: Pink Topre caps  (Read 4145 times)
Offline tokidokijake
Pink Topre caps
« on: Tue, 31 March 2015, 15:53:15 »
Anyone have any idea where these can be found? I've searched high and low and had no luck. Any help would be appreciated!
Thanks
Offline trizkut
Re: Pink Topre caps
« Reply #1 on: Tue, 31 March 2015, 16:06:35 »
They have been out of production for a while now.  Topre also seems to have little interest in producing new sets.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
Re: Pink Topre caps
« Reply #2 on: Tue, 31 March 2015, 16:15:18 »
Maybe one day we'll have some step up and fill the market, but for now, Nada.
Your best bet is hunting them down via classifieds or ebay and probably pay $130+
Re: Pink Topre caps
« Reply #3 on: Tue, 31 March 2015, 16:21:54 »
Word thanks for the help. Unfortunately I have not even been able to find them in either of those places for a while now =( bummer!
Re: Pink Topre caps
« Reply #4 on: Tue, 31 March 2015, 18:18:36 »
White/beige/light grey caps + iDye Poly is your best bet.
Offline SpaceGhost
Re: Pink Topre caps
« Reply #5 on: Tue, 31 March 2015, 18:36:52 »
Thanks
Pink caps for Topre? They wouldn't be shaped like little boobs, would they? Seems appropriate in light of the description some have used for what it feels like to type on a Topre.
Offline btctopre
Re: Pink Topre caps
« Reply #6 on: Tue, 31 March 2015, 19:26:20 »
Right in front of me huHuehUehUEHuhUEHueHEuhe (sorry, I had to).
Re: Pink Topre caps
« Reply #7 on: Tue, 31 March 2015, 19:55:12 »
you cruel, cruel monster
Re: Pink Topre caps
« Reply #8 on: Tue, 31 March 2015, 19:56:01 »
Didn't think about this! Perhaps this is the key to sweet success
Re: Pink Topre caps
« Reply #9 on: Tue, 31 March 2015, 20:32:34 »
Even widebasket hasn't got any!
Re: Pink Topre caps
« Reply #10 on: Tue, 31 March 2015, 20:34:01 »
Tis a sad time for my hhkb
Re: Pink Topre caps
« Reply #11 on: Tue, 31 March 2015, 20:47:03 »
It's the plan for mine.  I'm looking at pink and grey.
Re: Pink Topre caps
« Reply #12 on: Tue, 31 March 2015, 20:49:30 »
I wonder if they grey colored caps would come out a slightly different color with the dye or not.
Re: Pink Topre caps
« Reply #13 on: Tue, 31 March 2015, 20:52:56 »
They will.  You can try to mitigate that by dying the white ones longer or adding a hair of grey iDye poly powder to the mix.  It was different between my mods and alphas with purple.
Re: Pink Topre caps
« Reply #14 on: Tue, 31 March 2015, 21:02:09 »
sweet, that is good to know.
Have you ever considered taking novatouch stems and putting them into your hhkb?
Re: Pink Topre caps
« Reply #15 on: Tue, 31 March 2015, 21:04:32 »
Nope.
Offline luminor
Re: Pink Topre caps
« Reply #16 on: Thu, 09 April 2015, 19:39:11 »
my wife wants her pink topre caps....
Offline slip84
  • GUYDUDE MAGICIAN
Re: Pink Topre caps
« Reply #17 on: Thu, 09 April 2015, 19:45:57 »
I see everything through rose-tinted glasses, so all my caps are pink.
