Author Topic: Infinity ErgoDox on Massdrop  (Read 2347 times)
« on: Wed, 01 April 2015, 04:44:11 »
https://www.massdrop.com/buy/infinity-ergodox?mode=guest_open
$199.99
19 days left.
This is the Infinity ErgoDox - a different design (thanks Thechemist!).
« Last Edit: Wed, 01 April 2015, 05:13:23 by rowdy »
Offline Thechemist
Re: ErgoDox on Massdrop
« Reply #1 on: Wed, 01 April 2015, 04:55:32 »
I would put "Infinity" in the title since this a whole new ergo-dox design.
Re: Infinity ErgoDox on Massdrop
« Reply #2 on: Wed, 01 April 2015, 05:13:33 »
Done, thanks :)
Offline geniekid
« Reply #3 on: Wed, 01 April 2015, 09:07:07 »
The configurator for the original Infinity still doesn't work months after the drop.  If you are going to join in this GB you should make sure you are okay with the default layout or are comfortable compiling your own binaries using KLL.
« Reply #4 on: Wed, 01 April 2015, 14:17:51 »
Is this version really that different from the original?
Apart from the little LCD screens, that is.
Offline byker
  • Literally Canada
« Reply #5 on: Wed, 01 April 2015, 14:20:35 »
There was a thread on it here, with input by Haata, the creator: https://geekhack.org/index.php?topic=70476.0
Offline Thechemist
« Reply #6 on: Wed, 01 April 2015, 14:21:18 »
New pcb, new controller, new interface but same layout from what I can see.
Offline engicoder
« Reply #7 on: Wed, 01 April 2015, 14:23:46 »
It uses different microcontroller. In fact, there is a microcontroller for each hand, so they can be used independently.
It also supports MX or Alps switches.
https://geekhack.org/index.php?topic=70476.30
« Reply #8 on: Wed, 01 April 2015, 14:27:57 »
More info can be found in the threads below
https://geekhack.org/index.php?topic=70486.0
edit: that's one crazy time out whew...anyway still kind of relevant
« Reply #9 on: Wed, 01 April 2015, 16:03:21 »
I have not been through the keyboards section for a couple of days, so sorry about this duplicate thread.
Is it a good find though?
