Author Topic: HELP!!! LED lead broke off in PCB hole!  (Read 2460 times)
Offline swornxin
    • Nailed Down Custom Pins
« on: Fri, 03 April 2015, 21:52:56 »
So this is a total newbie mistake, and I'm embarrassed to be asking for help with it.
I was desoldering an LED in my caps lock of a keyboard I have assembled, and I suppose it was heated too much.  One lead and the main LED came out, but one lead was ripped from the main part and is now stuck in the PCB.  The switch is soldered in place, and although I don't want to, I could desolder it to fix it if need be.
Any other tips on fixing my stupid error?
Octagon - 62g Cherry tactile greys
Phantom - 65g Cherry tactile greys
FC660M - Cherry blues
KC60 - Gateron browns
Offline slickmamba
Re: HELP!!! LED lead broke off in PCB hole!
« Reply #1 on: Fri, 03 April 2015, 21:59:31 »
reflow, use something to poke the lost piece out.  done
not sure if I'm reading this wrong.
« Last Edit: Fri, 03 April 2015, 22:01:05 by slickmamba »
Hi :)
Offline alienman82
« Reply #2 on: Fri, 03 April 2015, 22:03:32 »
removed.
« Last Edit: Thu, 01 March 2018, 17:32:37 by alienman82 »
Offline swornxin
« Reply #3 on: Fri, 03 April 2015, 22:11:44 »
I think you get it.  Here's a photo.  You can see the negative side is open through, and the lead is blocking the positive side.
Offline slickmamba
« Reply #4 on: Fri, 03 April 2015, 22:26:53 »
yep, if you have pliers that are thin enough to get in there, just heat up the pad and lead, and pull it out
Hi :)
Offline swornxin
« Reply #5 on: Fri, 03 April 2015, 22:34:05 »
The problem is it's out far enough on the other side (the PCB side) that none of the lead is showing, and there is no solder left on the pad.  I'm incredibly frustrated by it.  Hahaha.
