Author Topic: Modify german (1391403) Model M to US (1391401) layout?  (Read 8554 times)
Offline zangetsu
« on: Sun, 05 April 2015, 16:23:24 »
Hi,
I have bought a german Model M (due to terribly expensive shipping from US to europe),
but I like the US layout much more. Is it possible to replace german layout of left shift, return etc with the US one (attaching pictures of particular keycaps)?
and are the Unicomp (I am gonna also order OS X specfic ones) keycaps compatible with 1391403?
From what I saw the backplate is common for 1391401 and 1391403 so it should be possible, but I'm not sure...
Thank You!
« Last Edit: Sun, 05 April 2015, 18:17:52 by zangetsu »
Offline Huxley2500
Re: Modify german (1391403) Model M to US (1391401) layout?
« Reply #1 on: Sun, 05 April 2015, 16:26:53 »
Sure, I have seen that at /r/mK.
« Reply #2 on: Sun, 05 April 2015, 16:30:16 »
Fohat.digs has a nice guide on how to do ANSI conversions. Essentially, you open the board up, swap out the little white stabilizers pins to be in the right location, and pull out the hammers in the locations you want to change caps in. I did this modification so that my 6019284 could have the standard 60% ANSI layout with 1.25x - 1x - 1.25x mods.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #3 on: Sun, 05 April 2015, 17:59:32 »
I believe the question was for a Model M ISO to ANSI conversion.  I would think there would need to be a controller swap and (I would think) rearrangement of the springs for the keys.  (So it would need to be torn down and bolt-modded to swap the springs.)
I am not sure if that is correct or not being as I have never owned an ISO model M.
Offline zangetsu
« Reply #4 on: Sun, 05 April 2015, 18:09:50 »
Thank you for answers.
Controller is certainly compatible (but I am going to make Bluetooth controller anyway)
I have found this (it is ANSI to ISO though) of /r/MK so i'm sure it is possible:
http://imgur.com/a/fmqXG
« Reply #5 on: Sun, 05 April 2015, 18:13:36 »
Does the M membrane not allow for swaps like the F capacitive PCB?
« Reply #6 on: Sun, 05 April 2015, 18:14:55 »
When doing a bolt-mod, swapping springs is trivial.
There may be a difference of a spring or 2, but I think ISO uses more, if I remember correctly.
If you have the new keys, just look at the back and you can see what you need to do.
- D Trump 2026-10-24
Offline Snowdog993
« Reply #7 on: Sun, 05 April 2015, 18:17:13 »
The membrane should be fine.  I believe all the keys in the matrix are on it.  The question is whether or not the controller would be compatible?  (I guess it is??)  It was German ISO....
It still would need to have the springs rearranged for ANSI.
« Reply #8 on: Sun, 05 April 2015, 18:32:16 »
Aren't they all the same?
Isn't it a matter of selecting the appropriate "language" in the keyboard control panel under Windows?
Offline Snowdog993
« Reply #9 on: Sun, 05 April 2015, 18:34:16 »
If that is the case, then yes, there would be no need to change the controller at all.  I thought they were hard-coded for the language, is all.
Offline Ludovician
« Reply #10 on: Sun, 05 April 2015, 20:12:22 »
Does anyone here know for sure whether it'll work just by swapping springs and stabs around? I've been wondering about this for a while.
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
« Reply #11 on: Sun, 05 April 2015, 20:36:15 »
Yes (I think), any mod that I have ever tried has worked. IBM made parts interchangeable and used the same ones everywhere, as far as I know. That is why people get excited about activating the "secret keys" and squeezing in things like Windows.
« Reply #12 on: Sun, 05 April 2015, 20:38:08 »
I'll test it when I get an ISO M in hand. Should be soon.
« Reply #13 on: Mon, 06 April 2015, 05:46:33 »
I'll be keeping a look out for this - I am considering an M122, which are only available in ISO (locally, too!) and would need an ANSI conversion.
Offline Ludovician
« Reply #14 on: Mon, 06 April 2015, 05:48:41 »
Where did you find one of those locally, Rowdy?
Typing speed:
My collection:
Pending:
Infinity kit
Offline E TwentyNine
    • Some of My Keyboards
« Reply #16 on: Mon, 06 April 2015, 08:01:04 »
Yes, definitely.  No controller swap is necessary.
