Author Topic: HHKB vs. other layouts: Difficult to switch between frequently?  (Read 3190 times)
Offline dyrdevil
I've been planning a custom Gon MX build for a while (going to put the TA caps on when I get them from Massdrop).  I'm super pumped but now I'm having a few second thoughts:
I imagine, if not immediately, then soon that I will want to buy a HHKB.  I really like the look and am curious about Topre, but I like the idea of having several boards in several flavors.
Do those of you that have HHKB and other boards find switching between the different layouts difficult?
The reason I'm asking is because I could technically plan my custom MX board (and other future boards) around the HHKB layout and never have to deal with multiple layouts.  However, it's harder to find MX caps with the right profiles for that layout and to be honest I really like the look of a standard layout.
Essesntially, I'm trying to avoid spending ~$400 on a custom Korean, then buying a HHKB and loving the layout and wishing I had planned my custom differently.
Thoughts?
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
Re: HHKB vs. other layouts: Difficult to switch between frequently?
« Reply #1 on: Tue, 07 April 2015, 01:15:43 »
Overall I don't really find any difficulty switching over to other boards when needed. It's not that different that it would impair work on other boards. In my opinion.
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #2 on: Tue, 07 April 2015, 01:19:38 »
I have more issues when switching between different switches, particularly when going from F buckling springs to the ghost blacks in my rosewill.  I don't have any issues with layouts I have become familiar with.  I switch between standard 104 key full size, F AT, and F XT, fairly often with no issues.
Offline Polymer
« Reply #3 on: Tue, 07 April 2015, 03:51:21 »
If you're switching between them frequently and keep doing it, you'll find it easy to switch back and forth..that's what I do today...At first you'll have a lot of extra \\ (which is the main difference)...At some point it was frustrating enough for me to think I needed to get rid of my HHKB...but it eventually clicks...just like driving on the right and left side of the road...you get used to switching back and forth if you do it enough..
That said, the HHKB layout as far as backspace and CTRL is far better IMO....It just makes more sense and it is better use of the key positions...Why Capslock has such a prime space is beyond me....but as you said, finding keycaps in that layout is a bit of a pain..
Offline Ludovician
« Reply #4 on: Tue, 07 April 2015, 05:51:20 »
HHKB layout ruined the normal layout for me. I now rebind my other boards to HHKBish. The lack of keycap availability is one of the reasons I prefer blanks now. If Unicomp would just do 1.5U with a Backspace legend...
Typing speed:
My collection:
HHKB Pro 2 (Blank, white) | HHKB Pro 2 Type-S (Blank, white) | Topre Realforce 87UB silent-modded (not currently functional) | Das Keyboard Model S Professional Silent (MX Brown) | IBM Model M 1391401 - 9th January 1991 (Bolt+Floss-modded) | Apple keyboard m0116 (Orange Alps) | Unidentified DIN Keyboard (White Alps) | ADDS 1010 (Green Alps) | AEK II (Linear-modded, USB-converted) | IBM PC-AT Model F | Noppoo Choc Mini (MX Black) | Amstrad PC2286 | BigKeys LX | IBM Model M 1391401 - 6th September 1990 | IBM Model M2 1395300 - 28th February 1991 | Leopold FC660C | Cherry G80-11802 (MX Brown) | Matias Tactile Pro (Simplfied grey Alps) | Razer Blackwidow (MX Blue) | Novatouch 55g | Focus FK-2001 (White alps) | DSE Multitech (Blue alps) | Dell AT101W (Matias quiet) | Pok3r (White w/Clears) | KBP V80 (Blue Alps)
Pending:
Infinity kit
Offline derb2k2
  • Something of a Topre ****..
« Reply #5 on: Wed, 08 April 2015, 17:45:17 »
Initially, you'll have some problems when switching from HHKB layout to normal one with Capslock, especially if you use the CTRL shortcuts alot and depending on how you change certain keys by the dipswitches of HHKB
HHKB | RF 45UB | Novatouch | Poker II Blue | QFR Browns | Rosewill RK-9000RE
Offline exitfire401
  • The Force is Re/\l
« Reply #6 on: Wed, 08 April 2015, 17:50:31 »
I have no problems switching between hhkb and my other layouts...I do occasionally have the accidental "\" rather than backspace though.
Offline TopreFan333
« Reply #7 on: Wed, 08 April 2015, 23:56:33 »
For a couple months now, been switching daily between two stock current-gen Mac keyboards (on my Air and the Mini at my office) and this HHKB.
For the first 2 weeks or so, maybe longer, I was struggling to adjust to the location of the Delete key in particular, and also getting used to the arrows. But mind you, I wasn't using the HHKB anywhere near as often as my work keyboard, so I bet the adjustment would have gone faster if I was going home and typing on this for hours at a time.
Anyway, at this point, I can switch freely without any issues. And I'm really starting to pick up the HHKB FN arrow keys as well -- definitely not looking down or hesitating at all at this point. You don't use CTRL as much on a Mac anyway, so that isn't as much of an adjustment as I bet it would be for a PC user.
The key feel of the Mac keyboards is of course a huge disappointment every time I go back, but not much to be done about that I'm afraid, without blowing another $250 to put one of these on my work desk.
« Last Edit: Wed, 08 April 2015, 23:58:45 by dchadwick »
