Author Topic: Orion V2 Kustom TKL Group Buy  (Read 1418931 times)
Offline appleonama
  • Trollo en USA
Re: Orion V2 Kustom TKL Group Buy
« Reply #1400 on: Tue, 05 January 2016, 13:10:36 »
Am i the only person annoyed by the PWM flicker of the backlight LEDs (keyswitch LEDs, not the back-*side* LEDs)?
Haven't noticed it mentioned by anyone. It's pretty nasty, i'd say 60 Hz or so?
I notice it as well but it is common with duck pcbs
Offline Steezus
  • Keeper of Facts
« Reply #1401 on: Tue, 05 January 2016, 13:15:30 »
I think it depends on the LEDs and the brightness settings, the lower the brightness the more noticeable imo. I haven't really noticed it all with the Pink LEDs that I'm using but in the low brightness settings with the White LEDs on my RS96 it is very noticeable.
Offline orcinus
« Reply #1402 on: Tue, 05 January 2016, 14:12:32 »
Yeah, white LEDs here.
I notice it at nearly full brightness.
Oh well... Perhaps it'll be less noticeable with the keycaps on.
Haven't assembled it yet, i'm stuck on trying to figure out why my space is sticky with a space bar on.
My current suspect is the cherry stab wire - it's likely bent a little too wide, so one of the stabs is at an angle instead of completely straight.
Offline Steezus
  • Keeper of Facts
« Reply #1403 on: Tue, 05 January 2016, 14:33:23 »
I have that issue on my RS96 but it's all soldered and the issue didn't start in the beginning, it seems to be ok for the time being but I'm definitely going to open it up and see what mischief is going on whenever I'm bored.
Offline filphil
  • One day I hope to find a love like JD and Turk
« Reply #1404 on: Tue, 05 January 2016, 14:37:08 »
Also when building it make sure to align your pcb so that it's straight with the top case when everything is tightened. I noticed that my space was slow to return and just had to do what i described. I think it's more prevalent on wkl boards because my brothers winkey board didn't have that issue.
Offline orcinus
« Reply #1405 on: Tue, 05 January 2016, 15:39:15 »
Yup, noticed that too when test-fitting it.
I think i'll mount some keycaps on, then align, test the edge keys, adjust and only then tighten to the top case.
Offline orcinus
« Reply #1406 on: Tue, 05 January 2016, 15:58:10 »
Little update in case someone encounters the same issue...
It seems the space stab holes are mounted ever so slightly too close to each other, or, the wire i've got was ever so slightly too long (as i've correctly guessed initially). This then causes the stab stems to rub against the edge of the stabilizer housing (the wire displaces the bottom too far to the left on the left stab and too far to the right on the right stab - since the stems can pivot around the wire, this forces the stems to rub against the right and left wall of the housing respectively).
While i was troubleshooting, i first tried lightly shaving off some material off the moving part of the stabilizer under the stem with an emery file. Bad idea. It leaves a sandpapery feel to the stabilizer that i had to smooth with sandpaper, and it all amounted to nothing.
What did help was removing the stab wire (you don't need to remove the plate or desolder anything to do that, it's accessible through the hole and on the side - if you need to do this and can't figure it out, let me know, i'll help), take the pliers and lightly bend the short segments *inwards*, like this:
/_______\
And by *lightly*, i mean really lightly. It's a trial and error thing. You bend it a little, put it back, mount a space bar cap, try it, remove it, remove the wire, bend a little more etc. until it's just right.
I'm getting 0 stickyness now and the sandpaper texture is irrelevant, as the stem isn't chafing the edge of the housing anymore anyways.
Offline R1N3
« Reply #1407 on: Tue, 05 January 2016, 16:01:43 »
/_______\
Meant to ask about this last night, I'm glad you said something before I forgot.
Offline orcinus
« Reply #1408 on: Tue, 05 January 2016, 20:51:33 »
Dammit, right after i've assembled everything, i've realized the right side of the spacebar is still sticky a bit :(
Offline orcinus
« Reply #1409 on: Tue, 05 January 2016, 21:35:25 »
What's the FLIP key on this keyboard?
Offline Steezus
  • Keeper of Facts
« Reply #1410 on: Tue, 05 January 2016, 21:37:31 »
Backspace
Offline orcinus
« Reply #1411 on: Tue, 05 January 2016, 22:02:48 »
Backspace
Of course, the only one i didn't try.
I can't figure out the LED controls for the life of me. LED Down seems to turn the LEDs off. LED Up seems to turn them on. No idea how to change the brightness. Oh well, something to play with tomorrow, it's 5am already.
Offline Steezus
  • Keeper of Facts
« Reply #1412 on: Tue, 05 January 2016, 22:05:12 »
Backspace
Pretty sure you need to press LED Control first and then the brightness settings will work.
Offline appleonama
  • Trollo en USA
« Reply #1413 on: Tue, 05 January 2016, 22:23:26 »
So I'm just planning ahead. How many of you add a heavier spring to your space bar? I have 78g gold springs I plan to put on the my space bar due to having a sticky space bar on my GON. good idea or bad?
Offline ika
« Reply #1414 on: Tue, 05 January 2016, 23:31:22 »
I'm putting a Cherry Tactile Gray on my spacebar, with 62g lubed Ergo Clears on everything else. I like a bit of weight behind the spacebar, although I will also put an o-ring on it to quiet it down a little bit. I made the mistake of putting a Cherry White on my current B.87 with Zealios and it makes a huge clatter.
Offline Steezus
  • Keeper of Facts
« Reply #1415 on: Tue, 05 January 2016, 23:33:56 »
+1
I got that in my spacebar for my Jane and love it. However I went full Zealios in my Orion because having all Purple stems and one Gray one would look weird af in my opinion.
« Reply #1416 on: Tue, 05 January 2016, 23:38:39 »
+1
My Zealio & Tactile Gray Jane is superior. Fite mii.
Offline appleonama
  • Trollo en USA
« Reply #1417 on: Tue, 05 January 2016, 23:41:50 »
So would 78g on zealios be good or bad? should I buy a grey switch?
Offline Steezus
  • Keeper of Facts
« Reply #1418 on: Tue, 05 January 2016, 23:56:00 »
+1
It's a quality board so I'll let it slide. :p
I'd try the 78g in the Zealios. Tactile Grey feels very similar to a clear imo.
Offline Want
« Reply #1419 on: Wed, 06 January 2016, 04:44:01 »
Looks like I have to let mine go. Will be putting up a classifieds thread, but thought I'd post here first. I've only opened the package to check for damages, there were none.
E: On hold. Multiple deals fell through. Still available. Keeping it.
« Last Edit: Mon, 25 April 2016, 05:53:47 by Want »
Offline Arvid
« Reply #1420 on: Wed, 06 January 2016, 09:19:31 »
Pmd!
Offline filphil
« Reply #1421 on: Wed, 06 January 2016, 09:25:48 »
Pmd!
from sweden to sweden.  Awfully lucky!
« Reply #1422 on: Wed, 06 January 2016, 09:32:55 »
PM'd!
Offline orcinus
« Reply #1423 on: Wed, 06 January 2016, 10:25:44 »
I'd strongly suggest a heavier spring on the spacebar.
It's way too mushy and sticky.
I'm on 62g clears.
It's so bad i'm actually considering putting a blue on the space bar as a temporary measure.
Other large keys are iffy too, but tolerable for modifiers.
Return is a bit too mushy for my tastes as well, if i go the replacement spring route, i'll probably swap that too.
Offline orcinus
« Reply #1424 on: Wed, 06 January 2016, 17:08:22 »
How do you "commit" the change?
Also, for some reason, now the changes made to the underglow LED pattern in 02D KeyMapper won't apply to the board.
I thought it was just me being very tired last night, but apparently, i'm way too daft to figure this thing out  :'(
Offline slushi
« Reply #1425 on: Wed, 06 January 2016, 18:09:57 »
If anyone is interested in grabbing the Alps Plate/PCB, my order just arrived and I don't need it. Please let me know if you're interested!
 HHKB Pro 2
Offline orcinus
« Reply #1426 on: Wed, 06 January 2016, 19:24:40 »
Okay, so hitting LED Control again commits.
But if you hit LED Control AGAIN, it shuts down all the LED sections. And you basically need to turn them on again then set the brightness. Very bizarre behaviour. I've also managed to get the underglow LEDs to flicker really really badly somehow, no idea how. I don't mean breathe slowly, nor pulsate, but really flicker at like 20Hz or so. Hitting LED Control and RGB Mode a few times fixed it. Couldn't replicate, i think it's a weird bug.
Annnyways, i think i've finally cured my space bar:
Offline appleonama
  • Trollo en USA
« Reply #1427 on: Wed, 06 January 2016, 19:26:49 »
SA on orion  :'(
Offline orcinus
« Reply #1428 on: Wed, 06 January 2016, 19:51:23 »
They see me SAin, they hatin.
Offline R1N3
« Reply #1429 on: Wed, 06 January 2016, 19:52:45 »
This stab issue is legit bumming me out
Offline orcinus
« Reply #1430 on: Wed, 06 January 2016, 19:58:01 »
I had to do three things before it got better:
1) bend the wire as i've described (/____\)
2) lube the stabs - both where the wire is anchored and the stab stems
3) insert and remove the wire like a dozen times before the anchors loosened a bit
Now it's fine. Activation force is still a bit too low for such a big key, but at least there's 0 sticking now.
Offline R1N3
« Reply #1431 on: Wed, 06 January 2016, 20:00:47 »
I'm otw to a casino to see if I can win two jackpots in 5 days. I'll start bending again when I get back.
What'd you use as lubricant? I've got graphite on hand but no liquids
Offline orcinus
« Reply #1432 on: Wed, 06 January 2016, 20:04:48 »
Krytox grease.
Actually was a 50/50 oil/grease mix, but the oil ran away from the bottle. No idea where.
Now it's grease.
Offline slushi
« Reply #1433 on: Wed, 06 January 2016, 22:09:33 »
PS I finally got my package and it seems I was sent a silver winkeyless instead of the black winkey top that I wanted. If anyone is interested in a trade, I mainly care that it is black and don't mind if it is winkeyless still.
 HHKB Pro 2
Offline orcinus
« Reply #1434 on: Thu, 07 January 2016, 09:07:09 »
Gotten the hang of the LED controls.
But the firmware is pretty buggy.
Some combinations of backlight and underglow brightnesses causes either of those to flicker badly (i assume due to some kind of temporal aliasing effect in the interrupt loop that controls the LEDs). Also, sometimes, in use, some sections of backlight temporarily fade down in brightness, then come back to the actual preset brightness (and no, that's not an effect, this is with constant on).
Now i'm trying to figure out the debounce settings, as i sometimes get double spaces.
Offline orcinus
« Reply #1435 on: Thu, 07 January 2016, 16:50:15 »
A few gratuitous shots.
Yes, it's Granite. Yes, it's DSA. I don't like cylindrical profile. Get over it :P
Offline HannahPeach
« Reply #1436 on: Thu, 07 January 2016, 18:15:31 »
It turned out just marvellous, congratz!
Offline ika
« Reply #1437 on: Thu, 07 January 2016, 23:19:31 »
Just opened my package it's... it's beautiful. I had some time today to put together the rest of my MX clears so hopefully I'll have it done by this weekend! One thing I didn't find, how were the indicator LEDs supposed to work? I don't have anything soldered in the holes and I don't see any bags containing LEDs. Were we supposed to provide our own LEDs?
also what exactly do the five LEDs indicate? I need to catch up on how this keyboard works.
« Last Edit: Thu, 07 January 2016, 23:24:18 by ika »
Offline Steezus
  • Keeper of Facts
« Reply #1438 on: Thu, 07 January 2016, 23:43:42 »
You're suppose to provide your own LEDs for the indicators. The five indicators above your arrow keys are for your layers with the fifth being the temp layer. The three indicators next to your ESC key are for your Scroll, Num, and Caps Lock.
Offline ika
« Reply #1439 on: Fri, 08 January 2016, 00:37:30 »
Oh, ok. Didn't expect that but it's not a problem. What LED colors are people using for these? There shouldn't be an issue mixing and matching high vs lower current LEDs, right? (e.g. white LEDs on switches and red/blue/green/orange LEDs on indicators).
Offline ctrlX
« Reply #1440 on: Fri, 08 January 2016, 05:04:12 »
Looks awsome! I was also thinking of using my Granite set but with black top and bottom aluminium housing. Unfortunately my EU soldering service guy is not responding to PM. Seems I have to wait even longer before I can start using this beauty :(
Can anyone recommend other EU based soldering service in case he never replies?
Offline orcinus
« Reply #1441 on: Fri, 08 January 2016, 13:49:29 »
There's no issue. They're driven separately.
I'm using yellow for first layer, white for upper three layers, red for the last LED.
BTW, the last LED isn't quite for temporary layer.
It generally indicates any "non-standard" mode + settings changes.
For mode changes, it tends to blink once when entering and multiple times when exiting.
Temporary layer does that, as well as LED control mode and various LED ops.
Macro recording too. Control mode (the mode in which you can access the KB settings) lights it constantly until you exit Control mode.
Edit: Oh, also, the first 4 LEDs also indicate FN layers, but in an "inverse" fashion from regular layers. E.g. FN1 = off on on on; FN2 = on off on on, FN3 = on on off on.
« Last Edit: Fri, 08 January 2016, 13:53:00 by orcinus »
Offline orcinus
« Reply #1442 on: Fri, 08 January 2016, 13:51:25 »
Thanks, guys.
I think granite DSA matches silver pretty nicely. Also, i think Dolch might be interesting on blue-gray or black.
Offline orcinus
« Reply #1443 on: Fri, 08 January 2016, 13:55:03 »
All classy and crap:
Offline xondat
  • i'm not a star
« Reply #1444 on: Fri, 08 January 2016, 14:20:14 »
Oh boy :eek:
Offline MrChunky
« Reply #1445 on: Fri, 08 January 2016, 14:48:35 »
My new favourite board:)
Offline Rainbow_
« Reply #1446 on: Fri, 08 January 2016, 14:56:27 »
my photography is garbage
Offline MrChunky
« Reply #1447 on: Fri, 08 January 2016, 15:04:44 »
Your board is great though  ;)
Also your photography is fine. One day I'll also get my Hyperfuse...    :p
Offline ramnes
  • T fou, mec?
« Reply #1448 on: Fri, 08 January 2016, 15:13:22 »
Looks awesome, best Orion so far to me!
Anyone knows if there's a way to control the five LEDs on the right software side?
Offline Steezus
  • Keeper of Facts
« Reply #1449 on: Fri, 08 January 2016, 15:22:17 »
They're indicators, nothing really that you can control about them.
