Author Topic: Lifted pin help  (Read 2294 times)
Offline adrl
Lifted pin help
« on: Sat, 11 April 2015, 21:07:28 »
Oh man, I screwed up. Any way to fix this lifted pin?
Offline fknraiden
Re: Lifted pin help
« Reply #1 on: Sat, 11 April 2015, 21:10:06 »
Someone else can do a better job of explaining how to fix, but from my opinion, it doesn't look too bad.
Offline HPE1000
  • Keycap Paparazzo
Re: Lifted pin help
« Reply #2 on: Sat, 11 April 2015, 21:20:50 »
It looks like it is all intact so perhaps it could all lay down and be held down/together by the switch pin? (With solder ofc) That should work and I would probably try that first.
Offline adrl
Re: Lifted pin help
« Reply #3 on: Sat, 11 April 2015, 21:29:16 »
Heh you guys are right.
Well the pin as still good but I did have to solder a wire from the teensy. Thanks!
