Author Topic: White M13 $40 Shipped - buttons not working  (Read 2167 times)
Offline E TwentyNine
    • Some of My Keyboards
« on: Fri, 17 April 2015, 19:01:35 »
http://www.ebay.com/itm/IBM-Trackpoint-II-M13-Mechanical-Keyboard-PS-2-K91-/261855843978
Looks like it may need some internals and a new cable ($15) but for that price...
Free local pickup in Hayward CA wherever that is.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
Re: White M13 $40 Shipped - buttons not working
« Reply #1 on: Sat, 18 April 2015, 00:15:14 »
I made an offer and the seller counter offered and I accepted it.  Good find!
« Reply #2 on: Sat, 18 April 2015, 07:54:46 »
I suspect the hardware is fine and there's just a loose connector somewhere.  If I didn't already have a white M13 I would have picked it up myself.
Offline Snowdog993
« Reply #3 on: Sat, 18 April 2015, 10:03:31 »
Yeah.  I figure the same thing.  I did order a new cable for it.  I have the feeling once I clean up the thing, and replace the cable, it will work just fine.  It's really dirty.  Let's just hope it's just that.
Offline Snowdog993
« Reply #4 on: Fri, 24 April 2015, 14:15:53 »
Nope.  Buttons do click, but no response.  It's sent to Phosphorglow to be done.  The keys feel flat on it too.  No life left in the springs I guess.  (Maybe that's why some folks don't like the M's!)  It was dreadful to type on.  Nothing like the other keyboards I have.
Edit:I did make it look pretty though!
https://geekhack.org/index.php?topic=33130.msg1725698#msg1725698
« Last Edit: Fri, 24 April 2015, 14:18:54 by Snowdog993 »
« Reply #5 on: Fri, 24 April 2015, 14:23:29 »
If the trackpoint works and the buttons don't, that does point to a bad connection (I'd find it odd if the trackpoint controller failed for the buttons only).  The button wiring is separate from the trackpoint.
But the flat keypresses sound like a bolt mod candidate if it's all of them.  Only a few I'd have said it was a spring seating issue.
Maybe you can get the barrel plate painted a nice color...
Offline Snowdog993
« Reply #6 on: Fri, 24 April 2015, 14:47:53 »
Yes and yes and yes.  The springs are probably shot.  This keyboard was heavily used.  The barrel may get a new underlay or it will be painted.  I like the idea of just a brilliant white underlay on it.  I don't believe he has the underlays in white, however.  It might just get painted for that.  I'm also thinking maybe a lime green underlay for it.
