Author Topic: Would a TKL keyboard fit in a full sized case?  (Read 16515 times)
Offline andCoffee
« on: Fri, 17 April 2015, 20:08:44 »
I'm interested in a project that would involve putting a small Raspberry Pi screen where the number pad would be on a full-sized keyboard, and I was wondering if anyone knows if the TKL internals would be able to just drop into a full-sized case (thus leaving an open area on the far right for some electronics)?
Offline En4cer408
Re: Would a TKL keyboard fit in a full sized case?
« Reply #1 on: Mon, 20 April 2015, 17:17:19 »
i dont no but that sounds really cool
Offline FrostyToast
  • Litshoard
« Reply #2 on: Mon, 20 April 2015, 17:21:06 »
It's entirely possible. However for a board to have a custom lcd panel for it to interact with, you would likely have to make it entirely custom. I don't know if any PCB out there would support that kind of display.
With anything entirely custom it would of course fit in any case you wanted assuming the controllers have enough space as well.
Quote from: elton5354
« Reply #3 on: Mon, 20 April 2015, 17:26:16 »
There is no standard for the spacing between the sections on a keyboard but if you go with two similar age/style boards from the same manufacturer you should be OK.  What are you planning to put on the screen?  I'm intrigued :)
Offline En4cer408
« Reply #4 on: Mon, 20 April 2015, 17:29:59 »
this would also be cool to try with a 75% pcb and a case like the TK
Offline andCoffee
« Reply #5 on: Mon, 20 April 2015, 21:48:25 »
Since people seem interested, I'm just interested in the idea of making a dedicated, distraction-free writing board that would be a standalone system. Hook the TKL keyboard internals directly to the Raspberry Pi, then have the screen boot directly into FocusWriter.  If I was able to power it with a usb battery pack, i think it could be a fun project... though I'm just casually researching at the moment.  I haven't taken any serious steps toward starting the build yet.
Offline Evo_Spec
  • (╯°ヮ°)╯︵⌨
« Reply #6 on: Mon, 20 April 2015, 22:47:33 »
Assuming you'd be putting the screen in the number pad area I don't think that'd be convenient to look at while typing.
GON NerD TKL DTA Edition
Offline andCoffee
« Reply #7 on: Tue, 21 April 2015, 00:23:13 »
No, not really.  But the idea of the screen is less about reading what you wrote and just being able to make sure you hadn't made typos.
