Author Topic: OG 30% Keyboard  (Read 5915 times)
Offline engicoder
OG 30% Keyboard
« on: Mon, 20 April 2015, 07:39:12 »
Offline spiceBar
    • ChessTiger.com
Re: OG 30% Keyboard
« Reply #1 on: Mon, 20 April 2015, 07:57:08 »
1907 30% Keyboard - 30 keys + 2 mods and space.
http://www.ebay.com/itm/RARE-ANTIQUE-VINTAGE-1907-Junior-typewriter-The-smallest-keyboard-ever-produced-/321729766354
I can see only 29 keys + 2 mods and space. :)
So all the time they were telling us that the staggered layout was unavoidable because of the levers, and it was a LIE!!??
It's a gorgeous device!
Offline MAR82
  • Keyboard Addict
Re: OG 30% Keyboard
« Reply #2 on: Mon, 20 April 2015, 08:02:35 »
And I only see 28, a space, and two mods  :confused:
Offline spiceBar
    • ChessTiger.com
Re: OG 30% Keyboard
« Reply #3 on: Mon, 20 April 2015, 09:33:15 »
Yes, you are correct: 29 keys (counting space) + 2 modifiers.
Offline engicoder
Re: OG 30% Keyboard
« Reply #4 on: Mon, 20 April 2015, 10:11:17 »
Hey, I'm an engineer/computer scientist. I can apply Green's Theorem to the Navier-Stokes equations to be able to find an approximate solution numerically, but I can't count  ;D
« Last Edit: Mon, 20 April 2015, 10:13:45 by engicoder »
Offline spiceBar
    • ChessTiger.com
Re: OG 30% Keyboard
« Reply #5 on: Mon, 20 April 2015, 12:17:39 »
Anyway... Nice find.
Do you know if this typewriter is still more or less functional? It looks like it is in very good condition.
Offline taylordcraig
Re: OG 30% Keyboard
« Reply #6 on: Mon, 20 April 2015, 12:27:58 »
  EVERYTHING WORKS NO STICKEY KEYS CARRAGE MOVES AND TYPES PROPERELY. ROLLERS NEED INKING FOR BETTER PRINT, A SINGLE ELEMENT MACHINE
The typewriter that would fit in your pocket. Measuring 25 x 10 x 3 cm ALSO INCLUDED ITS
CARRYING CASE.
Offline spiceBar
    • ChessTiger.com
Re: OG 30% Keyboard
« Reply #7 on: Mon, 20 April 2015, 12:37:48 »
CARRYING CASE.
Oh, yes, sorry.
I was so mesmerized by the pictures that I missed that. :)
Offline Oobly
Re: OG 30% Keyboard
« Reply #8 on: Mon, 20 April 2015, 15:01:34 »
30% size, 100% awesome!
Really nice find :)
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Re: OG 30% Keyboard
« Reply #9 on: Mon, 20 April 2015, 15:14:35 »
JD30 anyone? :P
CAD drawing files attached, courtesy of builder.swillkb.com.
Offline engicoder
Re: OG 30% Keyboard
« Reply #10 on: Mon, 20 April 2015, 15:19:53 »
JD30 anyone? :P
JD-Junior
Re: OG 30% Keyboard
« Reply #11 on: Mon, 20 April 2015, 15:46:44 »
JD30 anyone? :P
JD-Junior
Good call. :)
It can also be reversed, for those who like their 2U spacebar on the bottom.
Re: OG 30% Keyboard
« Reply #12 on: Mon, 20 April 2015, 15:49:05 »
JD30 anyone? :P
JD-Junior
Good call. :)
Nah, force those plebs to insert their stabs upsidedown.
Edit: I read revised not reversed
Offline Tiramisuu
Re: OG 30% Keyboard
« Reply #13 on: Mon, 20 April 2015, 18:12:11 »
Stunning.
Keyboard error F1 to continue.
Poker 2, Gherkin, Lets Split, Planck, Filco
Offline alexofthewest
Re: OG 30% Keyboard
« Reply #14 on: Mon, 20 April 2015, 19:41:11 »
That JD 30 looks bad ass,except the top spacebar,I couldn't get used to that.
Offline Oobly
Re: OG 30% Keyboard
« Reply #15 on: Tue, 21 April 2015, 01:30:01 »
I like how it makes the letters "G" and "H" more prominent ;)
Offline Nai_Calus
  • CLACK
Re: OG 30% Keyboard
« Reply #16 on: Tue, 21 April 2015, 02:56:57 »
That is so amazing. If I had money I'd be all over that. XD
Hmm, here's my random go at a 30-key:
http://www.keyboard-layout-editor.com/#/layouts/edf0b86cbca1eb1c3e14183bdf456869
Not a ton of thought has gone into this. Bottom board is the Fn layer. There's a shift lock because I'm too tired to figure out where a normal shift would work. I guess this would be a good use of that spacefn thing. There's no way to use keyboard shortcuts like ctrl+v on this. I'd have to play with this a lot more lol
- IBM 4704 Model F 107-key "Bertha"
Other boards: Kinesis Essential, Infinity(G.Clears), Ergodox(MX Blues), Monoprice 9433
Eternally searching for Celestial Blue BS V2 and blue/purple Bros.
Re: OG 30% Keyboard
« Reply #17 on: Tue, 21 April 2015, 07:12:08 »
While a manual typewriter doesn't need a key assigned to carriage return and line feed, a computer keyboard certainly does. :)
Unless you want to include a lever for it, like on the Qwerkywriter.
You most certainly need the two non-alphas to be shift and enter, while space does double duty as Fn.
