Author Topic: modify username  (Read 2075 times)
Offline Giorgio
modify username
« on: Fri, 24 April 2015, 02:14:08 »
Is it even remotely possible for a user to ask the admins change his username?
Offline azhdar
  • Praise the AZERTY god
Re: modify username
« Reply #1 on: Fri, 24 April 2015, 02:17:40 »
it seems, the1onewolf got renamed to Novus.
Azerty Propagandiste
Offline paicrai
  • mindblank
Re: modify username
« Reply #2 on: Fri, 24 April 2015, 09:13:46 »
you havent been very awake the last forever if thats the only name change youve seen
THE FEMINIST ILLUMINATI
Offline absyrd
  • CPT HYPE PADAWAN
Re: modify username
« Reply #3 on: Fri, 24 April 2015, 09:39:59 »
They'll do it and usually add a subtext saying "Formerly XXXXXX"
Offline C5Allroad
  • Formerly HUNTERANGEL121
Re: modify username
« Reply #4 on: Fri, 24 April 2015, 14:15:02 »
Who do we pm for one?
Re: modify username
« Reply #5 on: Fri, 24 April 2015, 14:16:55 »
It's not that it's hard to change a name, it's just annoying. For new users it should be fine since no one would probably notice. For older members, like the wolf, confusing for a bit
Offline paicrai
  • mindblank
Re: modify username
« Reply #6 on: Fri, 24 April 2015, 17:58:15 »
jd made a thread a while ago with peoples mod roles etc, and i'm sure there are threads out there in certain subs to help as well
