Author Topic: Finished my first planck build!!!  (Read 2873 times)
Offline omen7288
« on: Mon, 27 April 2015, 17:33:48 »
Turned out better than I imagined. I think I might have to build more  ;D!
http://imgur.com/a/v3m9z#0
Planck MX Blue
Keycool PBT
RK-9000I MX Blues, Vortex PBTRK-9000 MX Blues
Offline evangs
  • TheVan
Re: Finished my first planck build!!!
« Reply #1 on: Mon, 27 April 2015, 17:35:30 »
looks sweet, nice work!!
Offline Baxter
  • They do not know it, but they are doing it.
    • http://www.darklightweb.co.uk
« Reply #2 on: Mon, 27 April 2015, 17:44:06 »
Noice noice very noice, is this with one of the new PCBs or were we hand-wiring?
Offline omen7288
« Reply #3 on: Mon, 27 April 2015, 17:47:30 »
Thanks! I went with the hand-wired option as I wanted to try it for the first time anyway. I initially ordered the kit right before jack added the pcb options also.
Planck MX Blue
Keycool PBT
Offline Baxter
« Reply #4 on: Mon, 27 April 2015, 18:11:53 »
Cool, looks like a pretty tight gap at the bottom so I wasn't sure.
Good luck fighting with the lack of offset for a few days :P
Offline omen7288
« Reply #5 on: Mon, 27 April 2015, 19:28:06 »
It is small. I had to put electrical tape around the teensy to make sure it wasn't shorting on any wires. I figure I'll be used to the ortholinear within a week. So far it's nice because of less finger travel but I sometimes hit two keys at the same time still.
Planck MX Blue
Keycool PBT
Offline DrHubblePhD
  • I am star stuff
« Reply #6 on: Mon, 27 April 2015, 19:42:31 »
Looks great!  :thumb:
Offline Latin00032
« Reply #7 on: Sat, 02 May 2015, 10:44:47 »
In your opinion, is it hard to get used to the lack of offset?
I was considering getting planck so I wanted to hear some opinions.
Offline omen7288
« Reply #8 on: Sat, 02 May 2015, 11:06:56 »
I don't think so, it's not so different that it makes it a pain. I've had more issues while coding and remembering where I put [], {}, (), -+=_ etc. With my layout, I used the keys to the immediate left and right of the space key to switch to layers that have those keys, and some of them are in places that I'm not used to. I also ended up making the 2nd key to the left of space enter so I could keep the single/double quote in the same relative position that it used to be so I use my left thumb more often.
The other thing I should point out, is that a friend let me borrow a kinesis advantage for a few weeks which have the linear columns as well, and I was spending some time with that before finishing this build so I might have had some experience moving towards being more linear.
I noticed with the linear offsets, you need less finger motion overall which I believe makes it somewhat more ergonomic. I also switch between keyboards often, so it's not so odd that I can't get back to typing at 80+wpm on a regular keyboard.
I'm considering building more of these because I was in the group buy for the gateron switches, however a friend of mine just introduced me to plover so I'm looking at building something for that soon.
http://plover.stenoknight.com/
Planck MX Blue
Keycool PBT
Offline Latin00032
« Reply #9 on: Tue, 05 May 2015, 13:03:35 »
I was thinking about getting into plover in the future.
It looks like a big time investment though.
Offline omen7288
« Reply #10 on: Tue, 05 May 2015, 13:20:23 »
Yea, we'll see. I guess if I go down this path, I should document how much time I actually invest in it so it might be useful for other people interested in trying it out. I started doing the online walkthrough and am practicing the vowels for a few minutes a day.
I figured I've kind of hit my limit with qwerty so I'll try steno for a bit.
http://qwertysteno.com/Basics/TheVowelsPractice.php
Planck MX Blue
Keycool PBT
