Author Topic: What would you like to see in a switch lube review?  (Read 14476 times)
Re: What would you like to see in a switch lube review?
« Reply #50 on: Thu, 30 April 2015, 14:28:49 »
I'm planning on being conservative with all the Dow Corning stuff.  Each will have its own fine brush and will be lightly brushed on so you barely have a shine and have no clumps, like you do with Krytox.
Offline RSSonic92
« Reply #51 on: Mon, 04 May 2015, 11:37:38 »
What about Nivea Creme?
« Reply #52 on: Thu, 07 May 2015, 21:23:50 »
I ordered Dow Corning Molykote 111, Molykote EM-30L, High Vacuum Grease 976V, 33L, and a Molybdenum Disulfide powder.  I really want to try Dow Corning G-4500 or G-4501 because they sound like they could be perfect, but they're pricey.  Between what I have on hand and what I'm getting from people, it should be an interesting review.
Offline greath
  • A waffle is like a pancake with a syrup trap.
« Reply #53 on: Fri, 08 May 2015, 08:11:10 »
Awesome. I look forward to reading it.
Have you come up with a testing procedure yet?
Personally I think ~4 of each in a blind study would be solid, but I don't know if you have the time or materials.
Along the same lines, you could rig up sets of 4 gaterons on a plate and tour the plate to a couple members and only label the groups with numbers. It would be cool to see multiple "blind" perspectives on it. Only tell them what each lube is afterwards. I will soon have an extra TKL plate I could lend out for the tour (eventually would want the plate back... I have future plans for it).
« Reply #54 on: Mon, 11 May 2015, 14:44:59 »
I'll be cleaning the switches in an ultrasonic cleaner and applying lube.  Switches will be lubed, numbered, and put on a  stainless steel plate for testing with GMK or Cherry caps.  I will not be doing a blind test, though may share numbered switches with certain members.
I still need a sample of EK's lube if someone has some.
Offline TheMamaMafia
« Reply #55 on: Mon, 11 May 2015, 15:12:30 »
I would like to see natural lube ( ͡° ͜ʖ ͡°)
/s
Offline wlhlm
« Reply #56 on: Mon, 11 May 2015, 15:24:32 »
I got an additional dispenser of MechLube 2 I can send you, but I'm located in Germany, so only when nobody else has some. :thumb:
Offline slickmamba
« Reply #57 on: Mon, 11 May 2015, 22:48:41 »
I'd say skip the two water based sexy lubes and get one water based and one silicone one :)
Hi :)
Offline Zukoi
  • ****posting at 90wpm
« Reply #58 on: Tue, 12 May 2015, 13:22:33 »
Test various places on the switches and with different amounts. Lube doesn't matter if they are in the wrong place or there is too much.
There are guides on how to lube switches but putting them to the test is always a good thing.
Try some switches completely dry too just to see what would happen.
Also Toothpaste.
Offline Air tree
  • Better late than never ^-^
  • Formerly not demik
« Reply #59 on: Tue, 12 May 2015, 13:31:52 »
Maybe Brian will send you some review samples of their lube?
« Reply #60 on: Tue, 12 May 2015, 14:29:26 »
Maybe, but probably not as he's already done his PR bit on why his stuff is superior to Krytox.
« Reply #61 on: Tue, 12 May 2015, 14:30:30 »
My childhood ;_;
« Reply #62 on: Tue, 12 May 2015, 14:32:17 »
My childhood ;_;
Keep those tears flowing.  I need to see how well they lube.
Offline Air tree
« Reply #63 on: Tue, 12 May 2015, 14:33:43 »
My childhood ;_;
Little known secret: demik tears are the best lube.
