Author Topic: Mechanical keyboard for $3.4k!  (Read 3220 times)
Offline berserkfan
Offline RoflCopter4
Re: Mechanical keyboard for $3.4k!
« Reply #1 on: Fri, 01 May 2015, 18:21:40 »
I will never understand the appeal of a gaming laptop. It sounds like a nightmare.
Acer KB-101A with Blue Alps | HHKB Pro 2 | '85 122 Key IBM Model F | '86 1390131 "Silver Label" Model M | AEK M0115 with Orange Alps | Focus FK-2001 White Alps | Chicony 5181 with SMK "Monterey Blue" Switches | Dell AT101W | Unicomp "Ultra Classic" | Razer Blackwidow 2013
Offline GL1TCH3D
« Reply #2 on: Fri, 01 May 2015, 21:55:21 »
My Asus G53 was a nightmare. Can't easily clean the internals so dust would get clogged around the GPU and CPU. The laptop was so heavy it often wasn't worth bringing.
It was more expensive than if I had grabbed a desktop + cheapy laptop for school
Offline FrostyToast
  • Litshoard
« Reply #3 on: Fri, 01 May 2015, 22:25:16 »
Maybe someone could pick this up to harvest the switches and then toss the rest into the trash.
Good plan.
Quote from: elton5354
Offline RickyJ
« Reply #4 on: Sat, 02 May 2015, 03:22:22 »
Product purchased for work, lightly used for 40 days.  Unfortunately, this is too large of a laptop for me to take while traveling.
I think he may be onto something here...
Currently GMMK Pro: lubed 68g U4T, FR4 plate, extra gaskets, etc
« Reply #5 on: Sat, 02 May 2015, 05:23:24 »
"This listing has ended" - lol did no-one buy it?
Offline absyrd
  • CPT HYPE PADAWAN
« Reply #6 on: Sat, 02 May 2015, 05:25:18 »
Says it sold. Yikes.
Offline Dihedral
  • Mostly Harmless
« Reply #7 on: Sat, 02 May 2015, 05:36:33 »
In fairness, it does have a computer attached to it :)
Offline GL1TCH3D
« Reply #8 on: Sat, 02 May 2015, 13:04:04 »
Inb4 someone posts picture using the laptop as a keyboard for a desktop
Offline Dihedral
  • Mostly Harmless
« Reply #9 on: Sat, 02 May 2015, 13:05:38 »
Just rip the screen off, you won't need that :)
Offline JonasDK
  • Let me poo on you
« Reply #10 on: Mon, 04 May 2015, 09:16:11 »
"Product purchased for work, lightly used for 40 days."
"purschased for work"
"for work"
Seriously, name one job that would require a laptop of that size and specs!
Offline ttzhou
  • in your base, belonging
« Reply #11 on: Mon, 04 May 2015, 09:17:49 »
This. However, put Linux on it and basically converted it to a media center desktop, the hardware is decent. But the dust clogging is a definite issue, every few minutes the fan enters take off mode as it struggles to clear out the dust.
