Author Topic: [IC] Orange Alps Apple IIGS keyboard 658-4081 group buy  (Read 27408 times)
Offline Vanilla
  • 110% Snuggable
Re: [IC] Orange Alps Apple IIGS keyboard 658-4081 group buy
« Reply #50 on: Fri, 08 May 2015, 19:35:00 »
Vanilla go ahead and change one of mine to a white. I don't mind getting one of each.
Noted.
« Reply #51 on: Fri, 08 May 2015, 19:35:08 »
My personal (selfish) opinion is that the orange Alps boards should go in order to the first people who requested them, unless they state otherwise. :)
Offline Vanilla
  • 110% Snuggable
« Reply #52 on: Fri, 08 May 2015, 19:42:00 »
If we do that, we will be 5 orange alps boards short of already who has expressed interest toward an orange alps keyboard. There's simply not enough to go around.
*Hears "the needs of the many outweigh the needs of the few"
-Huh who said that?
Offline njbair
    • nickbair.net
« Reply #53 on: Fri, 08 May 2015, 19:43:12 »
Does the buy go through with just orange Alps or do you have to buy the whole lot?
My boards:
Offline Vanilla
  • 110% Snuggable
« Reply #54 on: Fri, 08 May 2015, 19:44:50 »
The buy will happen whether we get the SMK monterey white boards or not.
The price for each board regardless of switch is still $17 each.
« Reply #55 on: Fri, 08 May 2015, 19:47:58 »
If I'm limited to only one orange board, I'd like to change my order from two to one, please.
Offline njbair
    • nickbair.net
« Reply #56 on: Fri, 08 May 2015, 19:51:03 »
Well then first come first serve is totally fair. There will be some dashed hopes, but nobody will have lost money.
I kind of want to change my mind back now, and ask for two orange Alps again. Is that OK?
Can anyone weigh in on whether the white Monterey switches are worth having?
My boards:
Offline Vanilla
  • 110% Snuggable
« Reply #57 on: Fri, 08 May 2015, 19:55:51 »
If I were to limit everybody to just 1 orange board there is enough orange boards to go around for everybody who has expressed interest so far.
With no further immediate participants.
Otherwise we're in a deficit of 6 orange ALPS boards.
I believe the newer SMK monterey white boards are less common than the older orange ALPS ones.
« Last Edit: Fri, 08 May 2015, 20:04:05 by Vanilla »
Offline njbair
    • nickbair.net
« Reply #58 on: Fri, 08 May 2015, 20:06:26 »
Classic economics problem: unregulated free market versus compulsory wealth redistribution? Someone's going to be disappointed either way.
My boards:
Offline Vanilla
  • 110% Snuggable
« Reply #59 on: Fri, 08 May 2015, 20:15:20 »
If I were to solve this with classic economics, I'd come out on top by having to charge more to quell demand.... which I won't.
« Reply #60 on: Fri, 08 May 2015, 20:25:17 »
I'd still be in for two orange boards at $22 each. :)
Offline njbair
    • nickbair.net
« Reply #61 on: Fri, 08 May 2015, 20:37:57 »
JD is the keyboard 1%.
My boards:
Offline unoab
« Reply #62 on: Fri, 08 May 2015, 21:28:14 »
Well shipping makes much more sense at 2 boards per order.. so I would be hesitant to get just one, but if we are only given the option of just one....
And there is a deskthority thread that talked about the difference in switches, and it seems the SMK ones are more tactile than the orange ones, or so someone expressed as their opinion in the thread.  Though also in that thread they said that the double shot keycaps had binding issues on the SMK switches but not the orange alps ones because the stem tolerances on the smk switches were much tighter.
And I was hoping to try dyeing some of the caps, so double shot would be out for me, but if someone wanted to do a switch I would take a SMK board with PBT caps from one of the alps boards also with PBT caps and then they could have the double shots.  That should then fix the binding issue on the SMK boards and someone else could get an orange alps board..  Then I would be able to try each switch type too..
edit: found the page I was reading before, and actually Jacobolus actually suggested in there switching caps on the boards to alleviate the binding issues and make both versions pleasing to type on:
http://deskthority.net/post164638.html#p164638
« Last Edit: Fri, 08 May 2015, 21:35:26 by unoab »
Offline derezzed
« Reply #63 on: Fri, 08 May 2015, 21:58:27 »
Sorry, but I have to bow out of this group buy.  Stupid grown-up responsibilities have hacked my wallet.
Offline Vanilla
  • 110% Snuggable
« Reply #64 on: Fri, 08 May 2015, 22:04:43 »
Noted.
The deficit has improved to 5!
Offline FrostyToast
  • Litshoard
« Reply #65 on: Fri, 08 May 2015, 22:06:26 »
Still in for one orange board. 2 would have been really swell though but we are at a shortage.
Quote from: elton5354
Offline theanyday
  • love love love
« Reply #66 on: Fri, 08 May 2015, 22:11:09 »
Definitely still in for an orange and possibly one of each for shipping sake.  :thumb: :thumb:
MIRA SE | White Fox w/ 67g Zealios | POK3R w/ Blues | K70 w/ Browns | Planck w/ Greens | NovaTouch TKL
Offline Vanilla
  • 110% Snuggable
« Reply #67 on: Sat, 09 May 2015, 00:41:32 »
« Last Edit: Sat, 09 May 2015, 00:53:25 by Vanilla »
« Reply #68 on: Sat, 09 May 2015, 00:48:47 »
If it's one per person, I'm out, it's not worth it.
Offline Vanilla
  • 110% Snuggable
« Reply #69 on: Sat, 09 May 2015, 13:36:22 »
Alright I've slept on the issue and I'm going to just do it first come first serve with quantities already posted. In everybody's best interest, especially mine, I want to get this group buy delivered and completed as the supplier might have other plans. Otherwise I might just end up hoarding them all for myself.  :))
Offline njbair
    • nickbair.net
« Reply #70 on: Sat, 09 May 2015, 13:56:27 »
This was a tough call to make, but don't beat yourself up over it. You were given bad information by the seller. At least you caught it before the boards were paid for and shipped!
My boards:
Offline Vanilla
  • 110% Snuggable
« Reply #71 on: Sat, 09 May 2015, 14:13:37 »
I try my best to cover all my bases.
Offline brownbaglunch
« Reply #72 on: Sat, 09 May 2015, 19:36:51 »
If these will work with PC's, I'm in for two, possibly three.
« Reply #73 on: Sat, 09 May 2015, 19:41:10 »
If other people really want one, it's not a problem for me to give mine up.  It just wasn't worth it with shipping for just one of them.  I have one at home, so it's not a huge deal.
« Reply #74 on: Sat, 09 May 2015, 19:45:49 »
I'm with nubbinator. If I can get an Orange Alps board, that'd be great. If there is someone ahead of me who doesn't already have Orange Alps, they can have mine and I'd be happy to bow out. Not interested in the Monterey boards.
You have to have an ADB Converter like hasu's, there's a converter you can buy, or Soarer Mod it. It won't work right out of the box with your PC.
Offline jacobolus
« Reply #75 on: Sun, 10 May 2015, 01:14:11 »
You guys are silly with the shipping thing. These boards in similar condition often sell on ebay for about $50 + shipping (though price is fairly variable depending on how good the pictures are, how many keywords the ebay title covers, etc., so you can occasionally find one for $20–25). Getting one for $22 + shipping is still a great deal.
« Last Edit: Sun, 10 May 2015, 01:20:01 by jacobolus »
Offline Vanilla
  • 110% Snuggable
« Reply #76 on: Sun, 10 May 2015, 12:59:46 »
You guys are silly with the shipping thing. These boards in similar condition often sell on ebay for about $50 + shipping (though price is fairly variable depending on how good the pictures are, how many keywords the ebay title covers, etc., so you can occasionally find one for $20�25). Getting one for $22 + shipping is still a great deal.
This 110%. I personally have a full collection of ALPS & SMK switched boards and I paid $40 for my orange ALPS board.... without considering the groupbuy, $22 is a steal already.
The GREED is strong.
« Last Edit: Sun, 10 May 2015, 13:36:17 by Vanilla »
Offline njbair
    • nickbair.net
« Reply #77 on: Sun, 10 May 2015, 13:43:57 »
The GREED is strong.... in all honesty I'm pretty disheartened and fed up by this.
I work a full time job with a family. This is something I don't need. No good deed goes unpunished I suppose.
I hope my comments below don't sound argumentative, because they're not intended to be.
Maybe I missed something, but I saw two people who already have orange Alps boards willingly surrender their rightful spots for two boards each. Both of them made it sound like it was totally not a big deal to them.
I personally offered to change my second spot to a Monterey board when I thought the buy was in jeopardy, but then changed my mind when I found out the seller was willing to part with only the oranges for the same price. Does that seem greedy to you?
My boards:
Offline wakko
« Reply #78 on: Sun, 10 May 2015, 13:59:20 »
 I'm still in for one orange alps board. Not a big deal if I don't get one.
NOOB
KUL ES-87
Offline Vanilla
  • 110% Snuggable
« Reply #79 on: Sun, 10 May 2015, 15:35:40 »
The overtones are still present. You can't deny it.
Then again, that's the point of groupbuys.
I'm pretty disheartened and discouraged by this nonetheless. Especially considering this is the 1st group buy I've organized while balancing full time work and family.
It's been so much more than I bargained for especially considering I'm doing this for nothing in return.
I'm going to have to do some thinking in regards to the progression of this.
Offline njbair
    • nickbair.net
« Reply #80 on: Sun, 10 May 2015, 15:45:53 »
It takes some thick skin to run a group buy, from what I gather. Look at what mkawa has dealt with in the Smallfry kit buy, or even BunnyLake in recent keycap buys. You're correct that nobody appreciates the work involved. People just want their stuff. But it's oftentimes a necessary evil.
However, I don't think this feeling is unique to group buys. I gave up on EBay years ago because of greedy scumbags. Especially as a seller, there are all kinds of scammers who will ruin your auction for a chance to rip you off. Then when you refuse their shady terms they back out of the sale, forcing you to relist and wait longer, hoping that the next winner is not a scammer.
The simple truth is that people are all selfish jerks.
My boards:
« Reply #81 on: Sun, 10 May 2015, 15:54:38 »
And your point being?  Everyone is in different economic conditions.  While $40 for one might be good for you, others may not be able to justify that cost.  I couldn't justify it unless it was an average of $30 or less for each board shipped.  I've never paid more than $30 for one shipped and I've gotten a couple.  Since I have one at home, these were to be backups for future projects.
If you're going to talk trash about people looking to be in your GB like that, I'm out.  Before it was me being nice and being willing to give up my boards for people who wanted them more than me, but at this point I'm out and not looking back.
Talk to anyone on here and you'll see I sell things at cost and never try to go around making a profit off of other people's work.  This just wasn't worth it to me unless I had two.  It had nothing to do with greed and everything to do with what I'm willing to pay for something.  I set hard limits for myself and don't go over them.
« Last Edit: Sun, 10 May 2015, 15:56:55 by nubbinator »
Offline Vanilla
  • 110% Snuggable
« Reply #82 on: Sun, 10 May 2015, 17:11:33 »
I simply agreed and shared my experience collecting ALPS boards. That's all.
I'll admit that "greed" was too strong of a word for me to use. I probably should've used the word "WANT" instead. It was not directed at anyone whatsoever. If any of you guys were offended or set off I apologize for misusing that one single word, it was not the right word to use and I blame my preoccupation and frustration with a task that was underestimated by me. We are all human.
It's not you guys it's me. As I for one do not come from a retail or sellers prospective. And pretty much I've never organized a groupbuy let alone participate one.
Everybody has a budget and I respect that. Reason why I'm charging what they're charging me; at cost. Like I said before I'm doing this for the team.
I could have simply shrugged off the opportunity to put the container of boards in the hands of the eager deserving masses who will love them for what they are for a down to earth price but no I did not.
Nubinator, the decision is yours to make. At the moment I still plan on doing 1st come 1st serve, quantities reserved. I do not plan on changing the price.
« Last Edit: Sun, 10 May 2015, 18:20:58 by Vanilla »
Offline rsadek
  • raging keyboard monkey
« Reply #83 on: Sun, 10 May 2015, 18:19:48 »
I'm still in for 2 orange. I appreciate your hard work on all this.  :thumb:
❤️Keeboardz
Offline Vanilla
  • 110% Snuggable
« Reply #84 on: Sun, 10 May 2015, 18:22:15 »
I'll be sending out confirmation emails with further instructions for payment tonight.
ALPS orange boards *may* be all gone BUT there are still SMK white boards w/ double shot keycaps up for grabs.  ;)
Offline rsadek
« Reply #85 on: Sun, 10 May 2015, 18:33:03 »
I'm cool either way.
 I'd prefer orange since I have more white switches than boards to build.
I guess I could ....keep ... one .... intact  ? :eek:
❤️Keeboardz
« Reply #86 on: Sun, 10 May 2015, 18:57:16 »
I would suggest adding a few dollars per order as a group buy fee. That way you don't end up paying out of pocket when things don't go exactly as planned, as usually happens.
Offline njbair
    • nickbair.net
« Reply #87 on: Sun, 10 May 2015, 19:18:52 »
Agreed. Especially since this is your first time running a buy, I'm sure something unexpected will come up.
My boards:
Offline Vanilla
  • 110% Snuggable
« Reply #88 on: Sun, 10 May 2015, 19:53:37 »
You guys are definitely more experienced with these than I am. Any suggestions? I want to be fair. I'm all ears.
Offline njbair
    • nickbair.net
« Reply #89 on: Sun, 10 May 2015, 21:18:31 »
Actually I've never run a group buy either. But having taken part in several. $3-5 per order seems pretty fair to me.
My boards:
Offline Vanilla
  • 110% Snuggable
« Reply #90 on: Sun, 10 May 2015, 23:28:59 »
$3 fee for 1, $5 for orders of 2 sound about right?
Offline Vanilla
  • 110% Snuggable
« Reply #91 on: Mon, 11 May 2015, 15:59:40 »
All confirmation messages have been sent out via GH PM!
Offline Vanilla
  • 110% Snuggable
« Reply #92 on: Mon, 11 May 2015, 20:18:25 »
It looks like everybody who has expressed interest and got into the group buy have confirmed.
Paypal invoices will be sent out shortly.
Offline Vanilla
  • 110% Snuggable
« Reply #93 on: Tue, 12 May 2015, 01:04:57 »
There are still SMK monterey white boards if anybody's interested.
Offline rsadek
« Reply #94 on: Tue, 12 May 2015, 01:34:06 »
I'd be game for one...unless I'm a,ready getting one! So confused... Let me check my pm.
❤️Keeboardz
Offline Zukoi
  • ****posting at 90wpm
« Reply #95 on: Tue, 12 May 2015, 01:41:42 »
Can you fit Matias switches in a SMK Monterey board?
Offline njbair
    • nickbair.net
« Reply #96 on: Tue, 12 May 2015, 06:11:31 »
No. They use a different mounting hole and pin layout. http://deskthority.net/wiki/SMK_Alps_mount
My boards:
« Reply #97 on: Tue, 12 May 2015, 10:53:51 »
Yay! Vanilla is spreading the Orange Alps love! Glad my board is going to someone who doesn't have them yet. I was just being greedy :).
Offline Vanilla
  • 110% Snuggable
« Reply #98 on: Tue, 12 May 2015, 21:11:02 »
Update: all invoices to those that made it in and responded with a paypalable email address have been sent!
Any stragglers should pick up the pace!
Like the saying goes, the faster everybody posts payment, the quicker the boards will arrive!  ;D
Offline njbair
    • nickbair.net
« Reply #99 on: Tue, 12 May 2015, 21:42:41 »
Yes, that's an old saying. I believe it was coined by Abe Lincoln.
My boards:
