Author Topic: Pok3r with Clears Review  (Read 10748 times)
Offline zenless
« on: Thu, 07 May 2015, 13:24:36 »
In box next to CM storm:
And out:
Now no one will want to use my desk if I'm not in the office:
Boring shot:
Stock keycaps:
So my second modern mech. Other one is TKL with browns.
I really enjoy the heavy switches. Going to try out a set of deep space caps on here soon.
Positives:
Very nice for the money.
Heavy
PBT keycaps
Negatives (as of today):
No media keys
Default Fn and Arrow key setup are a pain to use
So my negatives could be fixed with an alternative firmware and re-programming it. Overall i do really like it though!
« Last Edit: Thu, 07 May 2015, 13:33:09 by zenless »
Offline Bludude4
Re: Pok3r with Clears Review
« Reply #1 on: Thu, 07 May 2015, 13:26:04 »
There is a dedicated reviews section. :D
All hail Hall Effect keyboards!
I'm a QFR Blues noob.
WASD keycaps are terrible.
Offline zenless
« Reply #2 on: Thu, 07 May 2015, 13:26:17 »
Found the manual here:
https://drive.google.com/file/d/0B-Ho1rdXm1bDbWt5LUxxUVRMY1E/view
So I can reprogram the arrow keys, function key, etc.
So now only complaint will be lack of media control.
Offline AlexdeL
  • キーボード 키보드
« Reply #3 on: Thu, 07 May 2015, 13:28:16 »
which mx switch is better of typing? clear or brown
Offline zenless
« Reply #4 on: Thu, 07 May 2015, 13:28:27 »
I'm a n00b. I reported myself to a mod..
Offline user 18
« Reply #5 on: Thu, 07 May 2015, 13:29:02 »
Moved it for you :thumb:
Avatar by ashdenej
Offline zenless
« Reply #6 on: Thu, 07 May 2015, 13:29:57 »
They're very similar, but I like the clear better. I'd have to try with same caps i think but the clear seem quieter to me as well as being heavier resistance. So maybe just not from bottoming out like i do with the browns.
Offline wlhlm
« Reply #7 on: Thu, 07 May 2015, 13:32:06 »
I wonder if you'd be willing top make a shot of the PCB for SCIENCE!! you know ;) (I'm interested if these have holes for LEDs as the engineering samples did)
Offline AlexdeL
  • キーボード 키보드
« Reply #8 on: Thu, 07 May 2015, 13:47:20 »
Thanks for the info about this...
By the way I am already dizzy trying to find information about this keycap set (posted pic here)...
Do you have any idea who/where these keycaps are for sale (copied from the space cadet)???
For me these caps looks very nice on Poker!
Thanks...
Offline Axollott
« Reply #9 on: Thu, 07 May 2015, 13:47:44 »
Vortex posted a comment on their facenuke page saying they will add media keys to the function layer in a FW update.
Offline Bludude4
« Reply #10 on: Thu, 07 May 2015, 14:24:21 »
Clear is a slightly heavier brown, so it's up to you.
Offline user 18
« Reply #11 on: Thu, 07 May 2015, 14:49:37 »
That's not quite right, actually. Clears and browns have different stems. A clear stem has a much larger tactile bump than a brown stem. The ergo clear is a clear stem with a lighter spring, approaching the same weight as a brown spring, however this feels much different from a stock brown. If you look at the stems side by side, you'll also be able to see the difference.
That said, it still is definitely personal preference between browns and clears. My preference is for stock clears, as I prefer heavier and more tactile switches.
Avatar by ashdenej
Offline MJ45
  • HHKB Pro
« Reply #12 on: Thu, 07 May 2015, 15:00:16 »
Thanks...
@Alexdel that set was from 7bitts R4 (on DeskThority) group-buy a couple of years ago.
Offline Bludude4
« Reply #13 on: Thu, 07 May 2015, 15:13:19 »
When he asked clear or brown I was assuming he meant stock switches. :D
IMO bigger tactile bump = heavier.
Offline user 18
« Reply #14 on: Thu, 07 May 2015, 16:48:54 »
That's not the extent of it though. Clears have stronger strings than browns, and a different stem.
Most people use lighter/heavier to refer to the spring only; reds are lighter blacks, greens are heavier blues, etc. A black is heavier than a blue, but the blue is still more tactile.
Sorry if I wasn't very clear earlier.
Avatar by ashdenej
Offline Bludude4
« Reply #15 on: Thu, 07 May 2015, 21:54:37 »
Right.
Offline Mikey Mo
« Reply #16 on: Sat, 09 May 2015, 20:31:42 »
mx clear is nice
Offline againer
« Reply #17 on: Wed, 20 May 2015, 16:03:36 »
Nice board.
I will have to wait about another week or two until I get my iso pok3r.
But loocking at your board helps me to wait for it.
BTW it when you look at pok3r posts all over the internet, it seams as 90% of them have mx clears. Is here anybody, who got some diffrent switches?
Offline illitirit
« Reply #18 on: Thu, 21 May 2015, 17:03:17 »
i have this board as well.
I like it alot other than it pings like crazy.
Offline gosinger
« Reply #19 on: Fri, 22 May 2015, 11:42:02 »
This one should be in the mail for me....also clear, but ISO DE :)
Bolt-modded 1391403 | Ducky Shine 3 slim (MX-blue)
Offline ithrowthinqs
« Reply #20 on: Fri, 19 June 2015, 15:49:18 »
Are these plate mounted?
Offline user 18
« Reply #21 on: Fri, 19 June 2015, 15:59:38 »
Yes, you can tell from the shot with caps pulled.
Avatar by ashdenej
