Author Topic: Finished offer  (Read 1751 times)
Offline burn1nsun
  • Trade Count: (0)
    • My stupid YouTube Channel
Finished offer
« on: Mon, 11 May 2015, 08:13:27 »
FINISHED
Hello, I would like to get black keycaps for my HHKB, does anybody black keycaps and wants the white ones? I would prefer the blank black ones, but lettered ones can be fine aswell! Or we can swap only the longer ones aka the ones that are blue on my keyboard!
Also does anybody know what would happen if I would try to color the keycaps with some pbt dye? Because they already have lettering and also some keycaps are light blue.
« Last Edit: Fri, 22 May 2015, 10:59:59 by burn1nsun »
HHKB Pro 2 l Pok3r Gateron Blacks
Offline burn1nsun
  • Trade Count: (0)
Re: [WTT] HHKB White lettered keycap set for black keycap set
« Reply #1 on: Tue, 12 May 2015, 14:59:39 »
Step riight up! Step right up!
Offline Air tree
  • Better late than never ^-^
  • Trade Count: (0)
  • Formerly not demik
« Reply #2 on: Tue, 12 May 2015, 15:26:33 »
If you dyed the keycaps, the legends would show through with the dyed colour. The mods and alpha all dye quite nicely.
If you're going to dye them, use iDye poly.
Offline burn1nsun
  • Trade Count: (0)
« Reply #3 on: Wed, 13 May 2015, 04:11:14 »
Does it wear off after a few months?
