Author Topic: Artisan key cap issue  (Read 3657 times)
Offline arcvile
« on: Wed, 13 May 2015, 12:52:04 »
I just got a new cap in and I have a slight issue with it. The MX stem does not fit due to an irregularity. So I am left with a choice, should I make an attempt to get it to fit (modify the cap or stem) or should I just find a place for it to sit and look pretty(commit to being an investment)?
Re: Artisan key cap issue
« Reply #1 on: Wed, 13 May 2015, 12:53:50 »
Could you be a bit more descriptive in how it fits/doesn't fit?
Offline arcvile
« Reply #2 on: Wed, 13 May 2015, 13:00:00 »
I have a keyboard with Cherry MX browns and the stem of the switch does not fit into the mount. The stem is incapable of fitting without shaving something down currently.
Offline arcvile
« Reply #3 on: Wed, 13 May 2015, 14:05:26 »
Disregard this thread, I got it worked out. :p
Offline APC-7
  • DC to 18 GHz
« Reply #4 on: Thu, 14 May 2015, 01:04:14 »
Good for you, I guess?!
Why not share your solution with the world and turn this thread from whining into charity?  ;D
Offline Hellcatz
« Reply #5 on: Thu, 14 May 2015, 01:13:11 »
my gatorade switches dont really co op with my raven too but it does fit so i just have it on keys i hardly use
Offline CaplockJack
« Reply #6 on: Thu, 14 May 2015, 09:25:32 »
Who made the defective key?  Who is "H"?
Offline arcvile
« Reply #7 on: Thu, 14 May 2015, 09:28:45 »
Sorry about the vague answer to my problem. It was exceptionally tight and after just sanding down the stem ever so slightly the cap fit without a problem. Was just a worst case scenario with deviation in the stem and how the cap fit on it.
« Reply #8 on: Thu, 14 May 2015, 10:04:26 »
Martin, AKA HKP
I think it's a Raven
Offline arcvile
« Reply #9 on: Thu, 14 May 2015, 10:26:21 »
You are so right on the Raven cap
Offline GenKaan
  • Mer caps, mindre käbbel
« Reply #10 on: Fri, 15 May 2015, 10:04:41 »
Looks like the stem hole is a bit narrow, could probably be fixed with some carving but risk is you damage the cap. Have you PM'ed Martin?
|| @Home:: Shine 3 TKL (Mx Red / Deep Space)  || @Work:: G2Pro (Mx Clear / Dye Sub PBT) ||
@Reserve:: HHKB (Topre 45g / Mixed PBT) // Das v3 (Mx Brown / Blank PBT)
Offline APC-7
  • DC to 18 GHz
« Reply #11 on: Fri, 15 May 2015, 18:29:41 »
Thanks for reporting back!  :thumb:
