Author Topic: Symbiosis SA  (Read 8713 times)
Offline getf
  • In Rod We Trust
Symbiosis SA
« on: Fri, 15 May 2015, 12:44:51 »
Ahoy
This set just arrived this afternoon, mounted on a Choc Mini.
This was my first Group Buy from SP via PMK. Missing a few caps  :-\ unsure if I will give PMK/SP more of my business.
Thank you for looking.
Offline absyrd
  • CPT HYPE PADAWAN
Re: Symbiosis SA
« Reply #1 on: Fri, 15 May 2015, 12:56:09 »
That is not acceptable. Send them an email. They seem to have more of a problem with this than individuals who run GBs.
Offline getf
  • In Rod We Trust
Re: Symbiosis SA
« Reply #2 on: Fri, 15 May 2015, 13:02:11 »
I did - I prefer to do CS related things over the telephone - and what do you know SP is closed on Fridays  :cry:
Offline KeypressGraphics
  • Dare to Dream
    • Keypress Graphics
Re: Symbiosis SA
« Reply #3 on: Fri, 15 May 2015, 13:02:40 »
That's a really nice looking key set getf. The email key really pops.
I've been wondering where to buy key sets to fit my Choc Mini (many of the keys seem to be non-standard sizes), what does does PMK/SP stand for?
May all your key presses strike true.
  Choc Mini         HHKB
Re: Symbiosis SA
« Reply #4 on: Fri, 15 May 2015, 13:07:41 »
Your \  key is upside down.
That does suck that so many are missing (I can't tell though).  They should make it right.
Offline getf
  • In Rod We Trust
Re: Symbiosis SA
« Reply #5 on: Fri, 15 May 2015, 13:11:18 »
Hi -
PMK = http://www.pimpmykeyboard.com/
SP = Signature Plastics http://www.keycapsdirect.com/
From what I understand is Pimp my Keyboard is the storefront are side of Signature Plastics.
And as far as the Choc Mini which has a unique home row (1.5,1,1.5,5.5,1,1,1.5)  and right shift (2u)
I bought  my spacebar here http://www.shapeways.com/product/274MBNFB5/blank-spacebar-keycap-5-5x?optionId=34454473
This is the only place i have been able to find a 5.5u spacebar.  Keep in mind this is 3D Printed so it will not be as nice as the stock POM Plastic spacebar on the Choc Mini.
Thanks for pointing that out!
  • Dare to Dream
    • Keypress Graphics
Re: Symbiosis SA
« Reply #6 on: Fri, 15 May 2015, 13:36:58 »
Cheers for that info getf. I have the old version of the Mini and its a great little board -really useful layout- but many of the POM were so worn I replaced them with a PBT Vortex set but unfortunately the modifier keys don't match up. I'll look into PMK and SP for a set that does.
  Choc Mini         HHKB
Offline xqwtz
Re: Symbiosis SA
« Reply #7 on: Sat, 16 May 2015, 02:43:52 »
Looks good. Maybe it's just the lighting, but your shapeways bar looks so much whiter than mine.
Offline getf
  • In Rod We Trust
Re: Symbiosis SA
« Reply #8 on: Sat, 16 May 2015, 07:32:55 »
Hey thanks - I sanded primed painted and put on a clear coat on it.  Too fuzzy from the factory for my likes
Offline Firebolt1914
  • POM Overlord
Re: Symbiosis SA
« Reply #9 on: Sun, 17 May 2015, 19:04:04 »
Looks surprisingly nice on a 75% keyboard compared to others
