Author Topic: [IC] Out of the Vault - Series III: Lucky 38 and Vault 111 (GB has begun!)  (Read 88330 times)
Offline iamtootallforthis
  • Something a lot Funnier
  • I like green stuffs.
    • WTB/WTTF Thread
A few of the mockups aren't showing for me.
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
They are not up, just place setters atm...
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
    • WTB/WTTF Thread
That explains it. Thanks!
Offline 00zeRO
Some mockups added...not in stone. Blank spaces are only place holders
Offline 00zeRO
a few place holders added
Offline aznairjordan
ooh looks so pretty. I'm down to pick up a set of each!
TGR Jane CE|FC660C|Orion V2
GMK Hyperfuse|GMK Olivetti|GMK Red Alert|Soulfree's Teal|GMK Cyan
Offline Data
 :)) The six pack is a really cool idea.
Offline 00zeRO
Definitely planning to do a Nuclear Data Green and Orange Vault 111 keycaps as well. I am concerned of the cost for all the different colors, however.
Offline Oobly
Um... could you please explain the reason for using Row 3 with colourways from Row 1 sets (SA Retro, Jukebox, Carbon) and not putting those in the Row 1 kit?
What's the point of a Row 3 cap in a Row 1 colourway?
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline 00zeRO
These keycaps are meant to be novelties for other profiles as well. Row 3 is about the same height as Esc/F Row OEM profile. I am trying to bring the colors of the sets to others. But...maybe its a silly idea, and I should have a mega set for Row 1 for the reason you mention...
Offline Data
Maybe we should talk about where people are most likely to use them on the board?
Offline 00zeRO
Good point, Data. It seems that all the SA Row 3-only excitement is gone. I still need to see exactly how much my ideas are going to cost per deal with PMK.
If anyone has ideas to share, now is that time... :D
Offline Data
There are still Row 3 sets out there.  Still rocking Nuclear Data on my 'Dox and 1976 isn't very old either.  If I can ever get Danger Zone off the ground with PMK we might add another to that distinguised list.  :D
It probably makes sense to keep your original blue & gold "Vault" caps in Row 3 and if you have a base colorway for Nuka Cola (I'm assuming it's white on red) maybe let that one stay in R3 too.  The rest?  Match the profile with the colorway.  I think these 1u caps are most likely to wind up in the top 2 rows of the keyboard for 99% of users -- preference definitely toward the function row.  So if you're matching colors with an existing set you might as well match the row profile from that set too.
Do you have a "base" colorway for the Lucky 38 legend?  I think the white on black might be a solid choice if you don't already have one in mind.  It's very "Vegas" looking -- reminds me of a poker chip.
Here's what I'm imagining in the lineup:
Vault Dweller Pack (parent deal) - Row 3 "Vault" caps & original red Nuka Cola & NEW Lucky 38
Ascended Vault Dweller (child) - Row 1 "Vault" caps & original red Nuka Cola & NEW Lucky 38
Lucky 38 (child) - NEW Lucky 38 caps to match various popular sets, both color and row profile
Nuka Cola Six Pack (child) - Row 3 Nuka Cola variety pack
Irradiated Travels (child) - Row 3 PC/GID "Vault" caps & others
Does that make sense?
« Last Edit: Wed, 22 July 2015, 09:43:09 by Data »
Offline 00zeRO
Did you see the new mockups? Already covering a 4 key set featuring Vegas styles colors for Lucky 38.
Thanks for the suggestions, I shall ponder on them, kind sir.
Offline Data
Yeah, I used them for reference.   ;D
If you have just one colorway as the "default" for Lucky 38, like you do for Nuka Cola, it will help you keep things organized.  Then you can expand on that for Junktown in as many directions as you want.  I guess white-on-green might be your default, but I wasn't sure if you were just using a Nuclear Data placeholder for that key.
Offline 00zeRO
Absolutely correct. Nuclear Data Green and White is going to be the base colorway for the Lucky 38. I don't plan on doing much with that legend beyond just the additional 3 Vegas style colorways.
Offline 00zeRO
Furthermore, I don't have the mockups yet, but I am considering Nuclear Data Green and Orange, and Rad Hard Yellow/Black for the Vault 111 in Row 3. Then I will push the other colorway possibilities to the Row 1 deal, where I will likely only go by request. I believe that the more color variation, the more expensive the entire set will be regardless of separate child deal pricing. I am beginning to think I have been dreaming a little too big on this, but I will consult with Melissa at SP regarding pricing before laying down concrete plans for the set as a whole.
Offline 00zeRO
Updated mockups to reflect current thought stream...
Offline Data
Totes amazeballs.
Offline nathanrosspowell
    • nathanrosspowell.com
They look great! Love the color ways in the mock ups. LOVE the Retro keys in Row1.
The Hack'd By Geeks set has a Row3 top row, so I'm not sure if it fits best into the Row1 set.
Keep up the hard work, zero. I will be buying a couple of each set  :thumb:
Offline 00zeRO
Ok, thanks for the input. I didn't know what Rows were what in that H by G set. Everything is still pretty fluid in the planning stage.
Offline Oobly
Sorry to throw the cat among the pigeons like that...
They look amazing as they are right now, I'd buy them all!
The only change I'd make (for my own uses) would be to add the orange and grey caps to the Row 3 set AS WELL as the Row 1 set so I can use one set with Carbon and one with Hack'd by Geeks. Hack'd has Row 3 top row with Row 1 2nd row. On a full size or TKL, novelties would be used predominantly alongside Row 3 caps (F key row), but sometimes on the top row of the edit cluster (Row 1) and on 60% boards, they would be used on Row 1, such as Esc.
The black and white caps and orange and grey caps are simply beautiful. I also love the sixpack. Actually I love them all now... and my wallet is ready.
I think it's time for me to change my signature to point people to this thread :)
Offline Alex92
This is much better! I'm glad the set-matching keys are now row 1  :)
Offline Xenocidal
  • Professional Lurker
Liking this selection, yowza. I am still in for all packs!
Offline THSdrummer
  • HKP hunter. Need moar.
I absolutely love it. I joined after lurking for a while just to say I want a full set. Maybe introduce a "family" pack with one of each key...? If the prices were in line with the first Vault keys, I'd probably buy two sets.
I also enjoy the Jukebox key cap set. A lot. Not sure I'd combine it with any of the vault caps, but I'd really enjoy having the Jukebox set.
Leopold FC660m  CM Stealth TKL
WTB: ^^ (O-Zone Bro V2), Drunk Skull, Oktoberfest, Laser/Poison/Woodland HKPs, G1 HKP Gas Masks
MY CLASSIFIEDS THREAD
Offline 00zeRO
Thanks. The currently mocked up sets are close to what the end result will be for the PMK group buy.
Offline iceman1925
Nice, I can't wait
Rapid-I||Ducky Mini||'87 Model M SSK||Goldtouch 0077
reddit.com/u/iceman1925
Offline Data
Zero, any chance that you'll do one in R3 for 1976?
Offline 00zeRO
Legend and color preference recommendation please?
Offline Data
Hmm...  I had to refer back to Engicoder's Add-on Thread to see what he had in mind for additional kits.  Maybe Lucky 38 or any of the Vaults in green (VBV) with brown (TGH) legends?
Offline 00zeRO
Got you covered...check the new Vault 111 key. Should I do the other vaults too?
Offline Jhonan
  • Chicks love duck pics...
time for nothing but vaults and colas for my board lol
Offline Data
Looks good.  One is probably enough, I would think.
Offline Bakgrund
I'd definitely buy a SA Row 3 Nuka Cola Six Pack, and the parent deal of course, mostly because that mint-green keycap. Gotta say that the orange and green color in Child deal 3 look stuning.
So all in all I would definitely spend some money on this. And when it comes down to child deals, I just want to avoid paying duplicate shipping. If it means that I have to buy a parent set too, so be it.
Quickfire Rapid    Quickfire Rapid
Mx Browns          Mx Reds
Ducky thick PBT   Stock caps
Offline 00zeRO
Hard part will be to make them inexpensive...I may have to be chop chopping some keys away...I don't want to, but they be not cheap unless we get maximum participation on this one.
Offline dndlmx
I like but rather have a mint Nuka Cola.   :)
Offline 00zeRO
I will see what I can do on this...
Offline Steezus
  • Keeper of Facts
I'm interested, I've been trying to get fallout novelty keys for the longest time now.
Offline 00zeRO
Thanks for your support...all we are waiting on is for PMK to come back up...
Offline THSdrummer
Ohhh, yes! Yes!  :thumb:
Offline Xenocidal
Have you considered running it through MassDrop? I know they are a bit of a dirty word around here, but could really increase the potential volume of buys.
Offline 00zeRO
I would run the GB myself before I do that. I don't want any notion of impropriety since my name is associated with Mechanical Keyboards. I believe it would be a grave conflict of interest.
Offline Xenocidal
Hahaha, whoops. Let's just attribute that to me wanting these now, and having no clue when PMK is going to relaunch.
Offline 00zeRO
No worries. Thought that was the case. I am actually thinking of creating another account on here just so I can show divestment from MK when I go solo with my own projects apart and separate from the company. Trouble is that I will need to get the post count up on the other account in order to do GB's, lol
Offline 00zeRO
Check the OP. I have a mockup now...
Offline livingspeedbump
    • KeyChatter
Just PM users that know you and find someone to "sponsor it" and help out  :thumb:
<- My Collection (so far)
Offline 00zeRO
Good idea
Offline iceman1925
I'll help lol
Offline Oobly
Which set is the Green Row 1 NukaCola for? The only set I recall in green recently is Nuclear Data, but that's all Row 3.
maybe something that can match the rumored penumbra set?
For this, I'd use GTL on BED for a Row 1 NukaCola or Vault to match the second ESC and GeekHack keys from the original set, but in Row 1 like the new version will be. Another option is RR on BED to match the normal ESC, but GTL matches more positions on TKL boards.
Offline 00zeRO
Which set is the Green Row 1 NukaCola for? The only set I recall in green recently is Nuclear Data, but that's...
The Lime Green Nuka Cola is for SA Retro
