Author Topic: [IC] Cherry MX to Lego Stem Adapters  (Read 8579 times)
Offline vistination
    • Store
« on: Fri, 05 June 2015, 20:59:11 »
This would have to be injection molded if it's going to be possible at all. Molds are pretty expensive so I'd have to sell at least enough to cover the cost of the mold which I estimate to be around $300 to $600. Pricing would be similar to O-Rings, $10 for 120, or $2 for 10. Length of the adapter is 5mm. Again, nothing is concrete obviously. Let me know what you guys think!
102740-0
TK78 maker
Offline starscream
  • I have nothing to say
Re: [IC] Cherry MX to Lego Stem Adapters
« Reply #1 on: Fri, 05 June 2015, 21:30:01 »
I can't image there's anyone on geekhack who wouldn't want a lego keyboard  :thumb:
              Poker                                 HHKB Pro 2
Offline Latin00032
« Reply #2 on: Fri, 05 June 2015, 21:43:18 »
Love it!
Hopefully this doesnt raise the lego too high.
Do you have any other pictures?
Offline Giorgio
« Reply #3 on: Sat, 06 June 2015, 09:59:05 »
So this is a Lego to cherry mx adapter, that allows to mount flat lego pieces on a cherry switch? Because with anything different from a flat lego piece, the typing surface would be too high. Correct me if I'm wrong.
Offline tjweir
« Reply #4 on: Sat, 06 June 2015, 11:00:29 »
Interesting for sure!
Offline fenwick
« Reply #5 on: Sat, 06 June 2015, 15:20:34 »
Could you make it so the stud was longer and have it still fit over the MX stem?
That way it wouldn't be raised so high if you put a brick on it.
Offline rm-rf
« Reply #6 on: Sat, 06 June 2015, 15:21:46 »
yes please!
Offline fenwick
« Reply #7 on: Sat, 06 June 2015, 15:58:57 »
OK I had some ideas:
First, you could make the whole thing as big as the inner diameter of a lego piece, that way a brick fits further down(but the walls are really thin at that point):
If those walls are too thin, you could get rid of them like this!
Offline rm-rf
« Reply #8 on: Sat, 06 June 2015, 16:04:13 »
personally i would say keep the walls.
mainly because in the past i bought a cheep key cap that didn't have the walls on the stem,
and it seemed to wear out just from taking it on and off the key switch itself. so now its fairly UN-usable.
but depending on the materials it could be different.
who knows maybe i'm just rambling.
Offline starscream
« Reply #9 on: Sat, 06 June 2015, 16:16:52 »
It's a shame this method wouldn't work with all Lego bricks
              Poker                                 HHKB Pro 2
Offline fenwick
« Reply #10 on: Sat, 06 June 2015, 16:18:50 »
You could add a collar like this:
That way:
*the walls are all thick enough
*it keeps the brick from going too far down the stem
*it keeps the fins from expanding
Offline bcredbottle
« Reply #11 on: Mon, 08 June 2015, 19:03:58 »
I think Ripster has been hyping these up
Offline 27
  • The Maple Man
« Reply #12 on: Mon, 08 June 2015, 19:23:21 »
Ripster has definitely been hyping these up. SentrantPC mentioned putting together an IC for these, which he is doing here, and I'm 3D printing a few to see how they work.
CAD Files are here https://grabcad.com/library/cherry-mx-to-lego-stud-adapter-1
IG: https://www.instagram.com/27mechs/                                        Website: http://www.mech27.com/
Offline Oni74
« Reply #13 on: Sun, 03 January 2021, 16:04:17 »
Did this ever go anywhere close to a group buy?
I was playing Lego with my kids and suddenly thought that a bunch of Lego Star Wars helmets would make great artisans. I'm sure a bunch of folks have thought about this, so I figured it's worth asking the community.
Offline Havattack
« Reply #14 on: Sun, 03 January 2021, 19:31:09 »
Could you coat the stem in a thin layer of super glue or something, as to increase it's thickness and make it fit better?
Offline kapowaz
    • kapowaz industries
« Reply #15 on: Mon, 04 January 2021, 08:53:46 »
I’d love to see this resurrected. Is the original poster still around and active?
Offline Pach
« Reply #16 on: Mon, 04 January 2021, 18:10:20 »
cant wait to step on these :cool:
Offline jeniverre
    • instagram.com/keebgeek
« Reply #17 on: Mon, 04 January 2021, 19:41:47 »
This thread is already 5years old.. but I think a 3d printed mx adapter would suffice, maybe..
Offline Shiba1337
« Reply #18 on: Mon, 18 January 2021, 15:06:21 »
yes
