Author Topic: {GB} Gateron PBT Blank Keysets CLOSED [EXTRAS SOLD OUT]  (Read 357891 times)
Offline jujubii
Re: {GB} Gateron PBT Blank Keysets ($28/set shipped worldwide!)
« Reply #100 on: Sun, 07 June 2015, 23:54:12 »
hey shadovved and all... do you think the 6.25u spacebar might have the same fitment issue like the ones from ivan's last black on black pbt set? i mean it's nothing a dremel can fix (or using the set on a keyboard with costar stabs) but it's worth an ask.
http://i.imgur.com/0FVtbEd.jpg
https://geekhack.org/index.php?topic=50935.msg1748789#msg1748789
Offline honoka
« Reply #101 on: Mon, 08 June 2015, 00:24:14 »
A blank pbt set with ISO compatibility would draw a lot of attention. We are starving.
Offline yuiop
« Reply #102 on: Mon, 08 June 2015, 00:38:04 »
Here's a few comparison shot to the beiges of gaterons next to OG doubleshots.
Question...
In this pic F1 is beige or white?
blank key next to iso enter is light grey?
Offline [esc]
« Reply #103 on: Mon, 08 June 2015, 00:41:25 »
Hi Shadovved, will we get extra modifier keys and stepped caps lock like on MD?
EDIT:
Can you confirm: Light grey is really a dark shade of beige? Hard to decide what color I should get :/
« Last Edit: Mon, 08 June 2015, 01:00:15 by [esc] »
Offline azhdar
  • Praise the AZERTY god
« Reply #104 on: Mon, 08 June 2015, 00:44:24 »
Question...
beige and light grey.
Azerty Propagandiste
Offline Shadovved
  • King of Stickers (and GBs)
« Reply #106 on: Mon, 08 June 2015, 01:50:09 »
EDIT:
White is white white, beige is warmer white. Light Grey is more greyish than the previous two.
Offline Shadovved
« Reply #107 on: Mon, 08 June 2015, 01:51:10 »
Assuming their molds are still the same, probably still need a little manual editing.
Offline [esc]
« Reply #108 on: Mon, 08 June 2015, 03:07:37 »
EDIT:
Hi, thanks for the reply. What i want to know is if Light Grey has a warm tone to it or if it is complely desaturated in color (compare model M mods to HHKB mods which are completely gray-scale)
Also, will the stepped caps lock fit on a regular ansi board? It says the stem is off-centered on the stepped key. Not sure what that means :/
Offline Nai_Calus
  • CLACK
« Reply #109 on: Mon, 08 June 2015, 03:42:19 »
No. It's for Cherry-style caps lock keys, which have the key moved slightly to the left of the standard non-stepped caps. The stem is moved to match. It's the same with the 6u spacebar that won't fit most boards with a 6u spacebar; Cherry likes to put things off-center for some reason and the stem is moved as a result.
- IBM 4704 Model F 107-key "Bertha"
Other boards: Kinesis Essential, Infinity(G.Clears), Ergodox(MX Blues), Monoprice 9433
Eternally searching for Celestial Blue BS V2 and blue/purple Bros.
Offline [esc]
« Reply #110 on: Mon, 08 June 2015, 03:46:53 »
Oh! The set still has all the keys I need for my poker II, doesn't it?
Offline Shadovved
« Reply #111 on: Mon, 08 June 2015, 05:17:29 »
EDIT:
Gotta have infiniti step in for this.
He used Model M keys as comparison didnt he?
Offline Lumic
« Reply #112 on: Mon, 08 June 2015, 07:58:30 »
I've got additional function row keys above the numpad: http://mechanicalkeyboards.com/shop/images/products/large_486_large_485_large_484_DK2108Sblue_main.JPG
Would it be possible to work out something for a set + those four keycaps? I'd be happy to pay extra.
Offline Shadovved
« Reply #113 on: Mon, 08 June 2015, 08:12:43 »
Firstly, I cant because they come ready in sets, like your GMK or BSP.
Unless you'll want to buy two sets......my recommendation is that you get a two-tone and a single colour which overlaps with the two-tone mods colour
Offline Shadovved
« Reply #114 on: Mon, 08 June 2015, 08:46:35 »
ISO is no-go for now. Sorry guys :(
Opportunities might pop up later.
« Last Edit: Mon, 08 June 2015, 08:49:49 by Shadovved »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #115 on: Mon, 08 June 2015, 08:48:37 »
That's unfortunate. I will try to contact Vortex again, they aren't so responsive though.
Offline Shadovved
« Reply #116 on: Mon, 08 June 2015, 08:51:04 »
If you need keycap samples, contact infiniti.
He might be able to spare you some.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #117 on: Mon, 08 June 2015, 08:55:30 »
I am just afraid that the colors isn't exactly the same. Also the profile may not be the same.
So a total of 4 keys.
We need: 1x ISO enter, 1x R4 key(1u), 1x R3 key(1u) and 1x 1.25u key. Everything should be blank.
Offline Shadovved
« Reply #118 on: Mon, 08 June 2015, 09:00:29 »
I'm just hoping a have a miracle soon. :(
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #119 on: Mon, 08 June 2015, 09:13:52 »
Lets hope Vortex want to help :)
Offline azhdar
« Reply #120 on: Mon, 08 June 2015, 09:35:19 »
Does Vortex make cherry profile?
Offline wlhlm
« Reply #121 on: Mon, 08 June 2015, 10:06:11 »
Offline Metr0
  • HHKB or nuttin
« Reply #122 on: Mon, 08 June 2015, 11:16:39 »
Has invoicing started yet? ;D
[WTB] BLANK PINK HHKB ARROW CLUSTER
Offline Giorgio
« Reply #123 on: Mon, 08 June 2015, 11:38:05 »
But do they make iso cherry profile? I've seen iso only in oem profile.
Yes
Offline lasttycoon
  • Ergonomic Wizard
« Reply #124 on: Mon, 08 June 2015, 15:09:49 »
Damn. The price on these is so good. Might go with Ivans though to get black instead.
Kinesis Advantage | Ergodox EZ Browns | RK RC930 | DS 3 Blues
Offline Nikelu
  • Don't read this!
« Reply #125 on: Mon, 08 June 2015, 16:02:23 »
Couple questions what will be the difference from these caps and my current razer blackwidow 2013 except the pbt quality and thickness?Will they be the same height etc?Or will they be flat,cause I think razers each row is a bit elevated dont know if these are called cherry or oem. need some enlightment here :/ .Also if I buy a ducky mini or pok3r will they fit as well as the stock ones? Not causing any problems?
Offline Shadovved
« Reply #126 on: Mon, 08 June 2015, 20:36:43 »
Not yet. I only got like 50 orders so far :(
Please order more, people
Offline tmk1207
  • Yêu Màu Tím
    • Vietnam Mechanical Keyboard Club <3
« Reply #127 on: Mon, 08 June 2015, 22:49:15 »
 @Shadovved: don't worry, small gb live on Vietnam mechanical group :D. 19/6 i'll order :D
Offline Shadovved
« Reply #128 on: Mon, 08 June 2015, 23:19:53 »
Offline Sn0_Man
« Reply #129 on: Mon, 08 June 2015, 23:24:20 »
I'm new around here but I couldn't resist a set!
Thanks for running this Shadovved
Pok3r w/Clears & blank PBT
Offline cinnamoncider
  • Thorpies are snappy
  • No clack; no life.
« Reply #130 on: Mon, 08 June 2015, 23:43:02 »
Which color combination should I choose to match the tone in the Model M?
Offline Kraicheck
« Reply #131 on: Tue, 09 June 2015, 02:27:53 »
@Shadovved: Are you planning on running a blank black version in the future?
Offline Shadovved
« Reply #132 on: Tue, 09 June 2015, 02:53:04 »
Check the OP for the color combination.
Nope. Imsto has exclusivity on blacks.
Offline Giorgio
« Reply #133 on: Tue, 09 June 2015, 03:27:23 »
Exclusivity on blacks. Are we in the fifteenth century?
Offline wlhlm
« Reply #134 on: Tue, 09 June 2015, 04:50:06 »
So much for Massdrop (currently @ 180) vs Geekhack...
Offline Shadovved
« Reply #135 on: Tue, 09 June 2015, 07:17:56 »
What to do? Multinational business be poor old me with one-man-show.
But shipping timelines and speed are comparable.... Either I'm they need to up their game, or I am underpaid HAHAHA
Offline Nikelu
  • Don't read this!
« Reply #136 on: Tue, 09 June 2015, 07:43:22 »
IS BEIGE THE MILK COLOR DESCRIBED IN MASSDROP?
Offline Kraicheck
« Reply #137 on: Tue, 09 June 2015, 08:23:44 »
One white set ordered!  :cool:
Offline Shadovved
« Reply #138 on: Tue, 09 June 2015, 08:30:12 »
It is. I'll add into the OP.
Correction: I don't think so. Gateron offered two whites, one was blindingly white white which hurts my eyes to look at and the other was normal white which can be likened to pure milk white.
This GB has the normal milky daylight white white. Not the blindingly white white.
My white should be the equivalent of MD's milk, hard to tell unless they got better pictures.
And they don't have my beige.
« Last Edit: Tue, 09 June 2015, 08:42:36 by Shadovved »
Offline TBone
« Reply #139 on: Tue, 09 June 2015, 08:42:19 »
Got in for light grey/beige. Too good to pass up. Not sure if I'll use them though... :p
Offline Ngt
« Reply #140 on: Tue, 09 June 2015, 09:08:06 »
Tough choice. Hard to know what to want. Full dark grey or two-tone light-grey, beige. Or perhaps just both! Mouahaha.
Offline 3K
« Reply #141 on: Tue, 09 June 2015, 14:59:20 »
1. Is this GB linked in any way to the drop of blanks on Massdrop? Or just weird timing?
2. Is there a minimum of orders to start this GB?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #142 on: Tue, 09 June 2015, 15:01:31 »
1. No they are not linked, they're are the same keycaps, yes.
2. Nopo
I suggest you buy from here though, cheaper International total, faster and directly supporting the community.
Offline 3K
« Reply #143 on: Tue, 09 June 2015, 15:35:44 »
2. Nopo
The same, except that one bright white color, I suppose.
That's what I plan to do, thanks!
Offline Ngt
« Reply #144 on: Tue, 09 June 2015, 15:38:24 »
2. Nopo
Yeah I agree with that. If you are afraid about taking part into this GB, shadovved is a member you can trust. He managed a GB of 100k+ gateron switches with Hwood and everyone got their orders. Just saying in case you are not used to GH's GB.
Offline Freezzy
« Reply #145 on: Tue, 09 June 2015, 17:06:31 »
Just as I thought picking the color combination was hard enought..
Offline Nuum
« Reply #146 on: Tue, 09 June 2015, 17:38:41 »
I thought beige is Massdrop's milk white and all the other colors are named the same here and on MD, so light/dark grey and white.
Light grey mods and and beige/milk white alphas are very close to Cherry thick dyesub PBT keycaps, with the beige being slightly more yellow and the light grey a tad colder.
« Last Edit: Tue, 09 June 2015, 17:46:38 by Nuum »
Offline Shadovved
« Reply #147 on: Tue, 09 June 2015, 17:50:29 »
Don't worry. You are not losing out on the stark white color. It's like a set of hardcore white CCs.
My white is the normal white you see around from SP or BSP.
And you get a beige which they don't have. Beige is like evaporated milk while white is like fresh milk.
Offline [esc]
« Reply #148 on: Tue, 09 June 2015, 18:21:23 »
Hm. This is not good news. Until now most of us have assumed that the keycaps are identical in color to what Massdrop offers. I based my choice of keycaps on the Massdrop mockups because they were supposed to be accurate. Now I'll probably have to cancel and make a new selection based on the correct color comparisons. It would be nice if someone could get Gateron to release a full color comparison chart/image, cause right now there seems to be no way to know the difference between Massdrop's and Shadovved's caps.
Offline yuiop
« Reply #149 on: Tue, 09 June 2015, 18:55:30 »
So if I understand correctly, Gateron has something whiter that the white in this pic?
That's impressive.
