Author Topic: Dolch PAC conversion to USB or PS2?  (Read 3470 times)
Offline Blackehart
« on: Mon, 08 June 2015, 10:44:17 »
Can the PAC be converted to USB? P/S2?
What all is needed?
Thanks in advance,
-Blacke
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
Re: Dolch PAC conversion to USB or PS2?
« Reply #1 on: Mon, 08 June 2015, 10:58:39 »
Offline Blackehart
« Reply #3 on: Mon, 08 June 2015, 11:45:24 »
Do you guys know of anyone that's done a conversion to USB?
Kinda concerned with the 6ft req on the ps2 cable -_-'
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #4 on: Mon, 08 June 2015, 11:59:17 »
I converted mine by getting a PS2 cable from mimic cables, and then by stripping off the non-ps2 end. So what I would do is get a PS2 cable from your favorite cable maker, have them keep the one end stripped, have them tell you where the GND, 5V, and the others are, and then follow one of the other guides for the PIN-OUT, and just directly solder it to the board.
« Reply #5 on: Mon, 08 June 2015, 12:03:17 »
I know I've seen them, I do believe you can go from the dolch original to ps2 then use an internal ps2 to usb adapter and either go attached or detached with the usb from there.
« Reply #6 on: Mon, 08 June 2015, 13:47:54 »
... just directly solder it to the board.
Or crimp a 4P4C plug to the cable so that the mod is easily reversible in case you would like to sell the board later on.
BTW, get also a slim cable because the Dolch case's cable hole is narrow.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #7 on: Mon, 08 June 2015, 14:03:21 »
I had a 4p4c and it was too wide, unless tjcaustin didn't use a 4p4c and instead an RJ11
Offline rpeterclark
  • RPTR ❌
« Reply #8 on: Mon, 08 June 2015, 14:27:20 »
In my case I already had a Soarer's converter around for use with a terminal model M. So on the Dolch PAC I lopped off the RJ11 connector and crimped on an RJ45 connector translating the Dolch pinout (described here http://deskthority.net/wiki/Cherry_G80-1813) to the terminal pinout (described here https://geekhack.org/index.php?topic=17458.0) that the converter was expecting. Works great!
Offline heedpantsnow
  • Old enough to know better
« Reply #9 on: Mon, 08 June 2015, 19:35:13 »
I'll be doing this soon as well.
I'm back.
