Author Topic: HHKB Type-S has reduced key travel?  (Read 2051 times)
Offline Macsmasher
« on: Tue, 09 June 2015, 16:04:48 »
I have several RF 87U variable silent boards as well as an HHKB Pro 2 standard. I liked the idea of the HHKB Type-S, but didn't want to spend the money for it. And I've never considered doing a silencing mod to my standard HHKB simply because I didn't want to change the key travel.
The Realforce silent actually uses a different switch housing, so that you still have 4mm of key travel with the silencing. I always assumed the HHKB did the same. However, according to PFU's specs, the key travel on the Type-S is reduced to 3.8mm. I'm not saying that reduced travel is good or bad. But my point is, if you want an HHKB Type-S, I see no reason not to just do a mod, provided the the foam rings are only .2mm thick.
Here's the link to PFU's HHKB Type-S specs...
http://www.pfu.fujitsu.com/hhkeyboard/hhkbpro2_types/feature.html
From what I can see, I don't think it would be any different than the factory Type-S. Am I wrong?
Offline exitfire401
  • The Force is Re/\l
Re: HHKB Type-S has reduced key travel?
« Reply #1 on: Tue, 09 June 2015, 16:08:37 »
Just do the O2dazone mod. It doesn't reduce keytravel at all and silences more than the standard type-s.
Offline CaplockJack
« Reply #2 on: Tue, 09 June 2015, 19:00:00 »
What is that?
Offline Gaspar
« Reply #3 on: Tue, 09 June 2015, 19:06:52 »
Here's a link to the thread https://geekhack.org/index.php?topic=49046.0
Edit : Here's the one from 02dazone https://geekhack.org/index.php?topic=40582.0
« Last Edit: Tue, 09 June 2015, 19:09:58 by Gaspar »
Offline strict
  • TKL Zealot
« Reply #4 on: Wed, 10 June 2015, 08:19:18 »
I have the OEM silenced Topre plungers in my 87UB 55g and the key travel is identical to my non-silenced 87UW 45g and I never did anything with the housings.
