Author Topic: IBM golfball writer and model F capacitive keyboard  (Read 5880 times)
Offline snhstq
« on: Sun, 14 June 2015, 09:49:19 »
Hi all,
I recently discovered that the IBM Typewriters (like type 65) contains a model F capacitive keyboard.
This keyboard has a TTL parallel interface, needs only +5V and can easily be interfaced with an AVR chip.
After replacing the standard  keys with PS/2 keys you have a very nice little keyboard.
Just to let you all know....
(p.s. the missing caps are on order :-)
Re: IBM golfball writer and model F capacitive keyboard
« Reply #1 on: Sun, 14 June 2015, 10:04:06 »
Looks more Model M-style to me.
Too bad it doesn't have the coveted "Code" key.
- D Trump 2026-10-24
Offline berserkfan
« Reply #2 on: Sun, 14 June 2015, 10:31:29 »
can't quite see any membrane that speaks of Model M. But it seems to be using barrel plate?
Offline snhstq
« Reply #3 on: Sun, 14 June 2015, 11:10:59 »
Correction: not a model F, but it is a capacitive buckling spring (not membrame) keyboard.
I converted it to a small model M style.
Offline 0100010
  • Not Sure
« Reply #4 on: Tue, 16 June 2015, 18:35:41 »
Nice little board.  Looks like an xwhatsit with an adapter would work on it.
Offline FrostyToast
  • Litshoard
« Reply #5 on: Tue, 16 June 2015, 18:40:41 »
Model m style is membrane.
It's buckling spring over a membrane.
Membrane =/= rubber dome.
Membrane just refers to the two sheets with circuitrycircuitry that get pressed together by pressure from keys to complete a circuit and register a stroke.
Quote from: elton5354
Offline JP
« Reply #6 on: Tue, 05 September 2017, 09:28:55 »
I found a Model 85 typewriter which has a capacitive keyboard as well. The Model 65, 85, and 95 typewriters have these type of keyboards. They don't show up too often.
177486-0
177488-1
177490-2
177492-3
« Last Edit: Tue, 05 September 2017, 09:39:32 by JP »
About Me | The Collection
Offline E TwentyNine
    • Some of My Keyboards
« Reply #7 on: Tue, 05 September 2017, 09:45:07 »
Necro, but a worthy one.  Yeah those are rare beasts, and I think they all have that unique stepped big-ass-enter key.
Offline 0100010
  • Not Sure
« Reply #8 on: Tue, 05 September 2017, 15:14:23 »
JP - could you get a pic of just the PCB?
Offline JP
« Reply #9 on: Fri, 08 September 2017, 20:43:55 »
Here ya go.
177845-0
177847-1
