Author Topic: Help identifying some clicky switches  (Read 2396 times)
Offline Blaise170
  • ALPS キーボード
    • XYZ
« on: Wed, 17 June 2015, 07:30:22 »
These things are MX clones but they have no identification whatsoever. The two I'm looking at are an MX Blue clone with a teal slider and an MX White clone with a translucent slider. They appear to be different companies. The teal has no marking on top and on the bottom has the diode symbol with a "V" in front of it. The clear one has a 22 on the back. I'm working on a switch tester, so it would be nice to know what is actually being tested. :)) Thanks for the help guys.
Re: Help identifying some clicky switches
« Reply #1 on: Wed, 17 June 2015, 09:47:14 »
If the clear one is the third row down, second from the left, it appears to be an Aristotle clone.  Not sure of the blue one, but inside of the housing shots always help.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #2 on: Wed, 17 June 2015, 10:31:17 »
Yeah I think you are right. I got the inclination to google Gaote and the Gaotes match up with the unbranded clones so I think that's what it is. Interestingly, they are said to have made Noppoo's switches as well, yet the Noppoo slider is more of a true blue where the Gaote is a teal color. Even more interesting is that Gaote and Outemu are thought to be the same company, yet have branded and unbranded switches.  :confused:
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #3 on: Thu, 18 June 2015, 20:25:59 »
Yeah, the "clear" one is Aristotle. Shape of the housing matches; they also have a glossy housing instead of Cherry's matte plastic. Last indicator would be the rounded rectangle where a logo would normally be.
Offline wlhlm
« Reply #4 on: Sun, 12 July 2015, 03:23:26 »
The Blue switch is an Outemu/Gaote switch as it has the same housing.
« Reply #5 on: Sun, 12 July 2015, 09:41:49 »
BTW, it would have been easier if your images were showing only the switches you are referring to, and not your whole collection.
Yeah, the switch with white slider and glossy black slider with a rectangle instead of a brand label is a Aristotle. Somewhat more tactile and clicky than Cherry MX but the sliders are not interchangeable. Supposedly, the housings break more easily than on other clones.
Offline Blaise170
  • ALPS キーボード
    • XYZ
« Reply #6 on: Sun, 12 July 2015, 15:41:31 »
Yeah I realized that after the fact but too late now lol.
Okay thanks a ton!  :thumb:
