Author Topic: wasd v2 code firmware  (Read 3018 times)
Offline majache
« on: Wed, 17 June 2015, 20:48:12 »
So, today I was flashing my infinity and of course I did the unthinkable. Installed the infinity driver (winUSB) over my CODE :(
Naturally, I uninstalled the CODE from windows Devices and plugged it back in, however it installs the infinity's drivers now. All is lost of my CODE's original drivers.
I contacted support and the only they can do is send me a new micro-controller to replace on the PCB. Is there an easier solution or can someone tech savvy enough send me their driver to install over it. It was using HidUsb (v6.3.9600.17041)
I see now under Zadig there is
 USB Keyboard (Interface 1) w/ HidUsb (v6.3.9600.17041)
and
USB Keyboard (Interface 0)  w/ WinUSB (v6.1.7600.16385)
Both are the wasd code
I can't rollback the driver through device manager.
Is there a way to extract the driver file from Interface 1 and replace Interface 0 with it?
« Last Edit: Thu, 18 June 2015, 10:03:48 by majache »
CODE Mx Clears 104 | | Infinity KiiBohd Mx Clears 60%
Offline majache
Re: wasd v2 code firmware
« Reply #1 on: Thu, 18 June 2015, 10:20:08 »
I found hidusb.sys files with a modified date when I first got my Code,  so those are there because of the board. The files are currently sitting in my system32/drivers folder.
