Author Topic: Double check my circuit please?  (Read 1747 times)
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« on: Sun, 21 June 2015, 22:52:10 »
Hey guys, I am in the prototyping phase of my lighting circuit and would like some helpaking sure I don't need other components for protecting other parts mainly.
103940-0
The pads on the xwhatsit, I know are correct.  I tested those with a bare LED and I get the results I want.  The selection swith has 4 levels and none of the pins I am using for a setting are on the same level as any other setting being used here.  The unlabeled pins between the switch and the PSU are from motherboard pins for HDD activity.
Offline Melvang
Re: Double check my circuit please?
« Reply #1 on: Mon, 22 June 2015, 23:18:56 »
Problem solved... I think.  Thanks dfj.
