Author Topic: BeeCaps - First try at keycap making (interest check)  (Read 33420 times)
Offline zazie_rx
Re: BeeCaps - First try at keycap making (interest check)
« Reply #100 on: Tue, 22 December 2015, 07:54:08 »
Interesting, thanks! For non-translucent caps have you considered using Urethane liquid plastics instead? Something along the lines of Smooth Cast 300 or ONYX. They have a low viscosity almost that of water and set in 15 min.
I had a look at those.. but the working time is way too low. With TC-857 I have about 6 minutes to Mix, degass, pour into the mold, and get in the pressure pot (preferably before it starts to gel.). Smooth cast 300 would only give me less than 3 minutes before it starts gelling and becomes unworkable.
Offline Telephasic
« Reply #101 on: Tue, 22 December 2015, 07:57:56 »
Well done, you are coming through with some ethereal effects!
Offline FLFisherman
  • I'd rather be fishing.
« Reply #102 on: Tue, 22 December 2015, 08:01:00 »
I love that word.
And I'll second this sentiment! Your caps are looking great, zazie_rx. Did they all sell out?
Offline zazie_rx
« Reply #103 on: Tue, 22 December 2015, 08:08:13 »
Having a look through some of the other BJB resins, TC-891 works promising.. cures to white (for non-transparent keys) and gives me 12 minutes of working time.
I love that word.
Mostly yes, just a couple rootbeer and red/white ones are remaining.
« Last Edit: Tue, 22 December 2015, 08:47:51 by zazie_rx »
Offline ccarlitos2
« Reply #104 on: Thu, 24 December 2015, 16:33:48 »
Any chance for Topre coming soon :)?
Offline __red__
« Reply #105 on: Sun, 27 December 2015, 00:10:11 »
If you're taking materials recommendations this is what I use.
GI-1000 for your silicone, oc-7085 or oc-7086 for your glass clear caps.
Gi-1000 is tin based so significantly less expensive than the omo that youre using.
For translucent as opposed to clear I use ie-3076.
And yes, we've all pulled caps out of molds at the published "demold" time and had them fail badly.
great work btw
Offline ImAWildDeer
  • All about that click clack
« Reply #106 on: Sat, 02 January 2016, 22:15:08 »
Awesome caps! Any chance you will be making more grape soda?
HHKB | Ergodox Infinity | OG Ergodox | Atreus | Planck | WASD V2  | Whitefox | TX1800 | F62
Offline qazeqaz
« Reply #107 on: Mon, 08 February 2016, 17:15:51 »
These are pretty slick looking.
Offline xondat
  • i'm not a star
« Reply #108 on: Tue, 09 February 2016, 02:05:06 »
Hey everyone! After this set (which I'm quite happy with), I probably only have enough resin for one or two more sets. After which I'll see if I can throw together a sale for those interested.'
edit: spelling :x
They're nice, maybe you should buy some more resin :-X
« Reply #109 on: Tue, 09 February 2016, 08:35:35 »
edit: spelling :x
Right? I want some more.
Offline theoriginal123123
« Reply #110 on: Thu, 11 February 2016, 09:39:56 »
How do you arrange your vents? I'm looking into making caps too and the most common I've seen is to have two tubes on the corners on the bottom of the caps.
Offline zazie_rx
« Reply #111 on: Thu, 11 February 2016, 09:58:20 »
Currently, I've used all 4 corners as sprues/vents and fill them up from one or two corners (depending on the cap effect i'm going for) until I see overflow from all of the other sprues. I found the most effective way to do this is to use plastic tip disposable syringes like this to inject the resin, just be careful the tip is completely immersed so you don't suck up any air bubbles you just worked out with the vacuum chamber.
Offline mrlooolz
« Reply #112 on: Thu, 11 February 2016, 10:00:53 »
Are there any sales soon
Ducky Shine 5 w Mx Browns  | White fox w Zelio's purple 67g | Gateron Blank set
Current Aims: Jack O Lantern is my end game cap. Looking for one.
                                                   --> MrLooolz's Classified. <--
Offline zazie_rx
« Reply #113 on: Thu, 11 February 2016, 10:11:02 »
No plans yet for a sale, trying work out all the kinks I had with the last batches as well as ordering some materials for it.
« Reply #114 on: Thu, 11 February 2016, 10:20:16 »
Thanks a bunch! I currently don't have any pressure/vacuum equipment, so I'll just be trying with molds and care lol. All the literature I've read so far suggests placing your feeder/pour area and vents above the work, so that the air gets pushed upwards and out, your method seems to corroborate that nicely! Been practising my sculpting too, so hope to have something to show for it in a month or two!
