Author Topic: Making some 60%s!  (Read 3217 times)
Offline Thash
Making some 60%s!
« on: Fri, 03 July 2015, 21:47:28 »
http://imgur.com/a/cG097
Also will start selling these custom soontm
Offline calvinhousecat
Re: Making some 60%s!
« Reply #1 on: Fri, 03 July 2015, 21:54:10 »
Neat shape you got going there
« Reply #2 on: Fri, 03 July 2015, 23:44:40 »
Case is too bulky
Offline nmur
  • ಠ_ಠ
« Reply #3 on: Fri, 03 July 2015, 23:50:43 »
pretty nice design, however people tend to choose 60%s for their compact size. Those cases have a huge bezel, to the point where it might actually be deeper than a keyboard with the function row.
Offline Thash
Feedback
« Reply #4 on: Sat, 04 July 2015, 00:33:34 »
Feedback taken to heart, will make the bezel smaller for the next run.
« Reply #5 on: Sat, 04 July 2015, 00:40:06 »
I like the all matching materials. Not digging that bezel or shape though. Looks like a Pyrex baking dish...for a second I thought you were using that to hold your plate while you worked on the board.
Offline KRKS
  • Your friendly neighbourhood umbrella
« Reply #6 on: Sat, 04 July 2015, 01:05:28 »
I actually like the bezel, but I'm looking for a 65%/75%/something else around that
The increasing power of Massdrop WILL kill the community group buys - don't come crying to me after it happens when you're too stupid to see it now. Join me in saving the community!
MD = NO $, NO EXCEPTIONS
Offline Thash
« Reply #7 on: Sat, 04 July 2015, 10:41:33 »
I can make a 65% or 75% if you want!
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #8 on: Sat, 04 July 2015, 11:07:22 »
What pcb will you be using?
Offline Thash
« Reply #9 on: Sat, 04 July 2015, 11:20:37 »
I'm gonna handwire it. It's juts cheaper and for me better than having to make a PCB.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #10 on: Sat, 04 July 2015, 11:21:40 »
Well, winkeyless.kr sells 60% PCBs, so as long as your spacing is standard they should fit fine
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #11 on: Sat, 04 July 2015, 11:21:52 »
If you are interested in using PCBs that is
Offline Thash
« Reply #12 on: Sat, 04 July 2015, 11:36:11 »
Huh, I'll look into, thanks!
Offline Oobly
« Reply #13 on: Sun, 05 July 2015, 06:38:36 »
With 3mm plates (that's what they look like) and no undercuts or PCB, the switches won't "lock" into place and you'll have to use hotglue or some other means of holding the switches in place. Even then, the force of pulling keycaps could pull the switches out the plate. I'd look into both undercutting the relevant area for the switches (see pic below for an example) and using a PCB, or using a 5mm plate and PCB to get better switch / plate strength / stability. With a 5mm plate, the plate is held tightly between the switches and PCB and the whole assembly is nice and strong and you don't need undercuts, but it means you need to mount all the electronic parts on the bottom of the PCB.
What controller are you planning on using?
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline Thash
« Reply #14 on: Sun, 05 July 2015, 17:22:48 »
With 3mm plates (that's what they look like) and no undercuts or PCB, the switches won't "lock" into place and you'll have to use hotglue or some other means of holding the switches in place. Even then, the horse of pulling keycaps could pull the switches out the plate. I'd look into both undercutting the relevant area for the switches (see pic below for an example) and using a PCB, or using a 5mm plate and PCB to get better switch / plate strength / stability. With a 5mm plate, the plate is held tightly between the switches and PCB and the whole assembly is nice and strong and you don't need undercuts, but it means you need to mount all the electronic parts on the bottom of the PCB.
Gonna use a teensy 2.0, thanks for the advice, I'll look into for the next build!
Offline hwood34
  • underwater squad
  • #1 CL stan
    • Keyboard Illuminati
« Reply #15 on: Sun, 05 July 2015, 21:30:56 »
You haven't considered making the bezel slightly smaller? Besides that, I'm certainly intrigued by the design
Offline KHAANNN
« Reply #16 on: Mon, 06 July 2015, 21:19:03 »
I think it's a good idea to get a solid/proven design going on, once you do that, you could even sell parts only, I would love to buy a 65%/75% case (only case, with screws and adhesives and stuff) for example - to handwire manually
Nice socks by the way
Offline Thash
« Reply #17 on: Tue, 07 July 2015, 00:36:02 »
That's pretty much what i'm doing!
And that's a jacket sleeve XD
