Author Topic: WTS GMK dogethink novelty keycap packs [sold]  (Read 51914 times)
Offline nickheller
  • Cherry ML life
  • Trade Count: (2)
    • hickneller.com
« on: Mon, 06 July 2015, 17:57:17 »
For sale are some GMK novelty keycap packs. Picture and original artwork credit: switchnollie Sold out, thanks everyone
Sets are 10$ each plus shipping cost. To order please fill out
the order form [CLOSED]. Orders placed today will begin to ship this following Friday.
« Last Edit: Sun, 24 November 2019, 14:18:27 by nickheller »
Offline nickheller
  • Cherry ML life
  • Trade Count: (2)
    • hickneller.com
Re: [WTB] Topre Bro Bot V2
« Reply #1 on: Fri, 10 July 2015, 11:42:31 »
bump
Offline nickheller
  • Cherry ML life
  • Trade Count: (2)
    • hickneller.com
Re: [WTS] UMAD BRO Summer Set
« Reply #2 on: Wed, 22 July 2015, 00:04:41 »
bump
Offline meiosis
  • Trade Count: (3)
  • Time
Re: [WTS] UMAD Bro Summer Set
« Reply #3 on: Wed, 22 July 2015, 00:11:35 »
Good price GLWS!
Keyboards:
Aripeko TKL
Offline beehatch
  • baehatch
  • Trade Count: (0)
« Reply #4 on: Wed, 22 July 2015, 00:21:13 »
That price just made this entire forum wet.
Offline nickheller
  • Cherry ML life
  • Trade Count: (2)
    • hickneller.com
Re: [WTS] Vortex Orange and White doubleshot PBT 60% set
« Reply #5 on: Fri, 31 July 2015, 13:18:58 »
bump
Offline nickheller
  • Cherry ML life
  • Trade Count: (2)
    • hickneller.com
Re: [WTS] 1976 Base Set
« Reply #6 on: Sat, 15 August 2015, 20:13:11 »
bump
Offline nickheller
  • Cherry ML life
  • Trade Count: (2)
    • hickneller.com
Re: [WTT] Topre Pharoah BBv2 [WTTF] Other Torpe Bros
« Reply #7 on: Mon, 17 August 2015, 14:44:04 »
bump
« Last Edit: Mon, 17 August 2015, 14:46:44 by nickheller »
Offline nickheller
  • Cherry ML life
  • Trade Count: (2)
    • hickneller.com
Re: [WTT] Topre Celestial Blue V2 [WTTF] Other Topre Bro Caps
« Reply #8 on: Thu, 20 August 2015, 19:54:21 »
bump
Offline nickheller
  • Cherry ML life
  • Trade Count: (2)
    • hickneller.com
Re: [WTS] Topre caps
« Reply #9 on: Sun, 30 August 2015, 13:54:51 »
bump
Offline do_Og@n
  • Trade Count: (0)
« Reply #10 on: Sun, 30 August 2015, 14:13:17 »
I'll take em!
  • Trade Count: (1)
    • Gray Designs
Re: [WTS] Topre caps - SOLD
« Reply #11 on: Sun, 30 August 2015, 18:18:48 »
Who made the green ones ? Used punksdeads stems.
Offline PocketFool
  • Trade Count: (0)
  • Coming down with a serious case of mech-mania
« Reply #12 on: Sun, 30 August 2015, 21:22:50 »
...Used punksdeads stems.
That's actually really interesting that you're able to ID one cap stem vs. another. Are there like a few "major" stem makers/versions out there that are used by all of the small(er) artisan makers, or are the stems themselves generally unique to the artisan themselves? I've never heard that this was actually a thing so I'm curious!
Always looking for lime-green and red colored topre RF sets.
  • Trade Count: (1)
    • Gray Designs
« Reply #13 on: Sun, 30 August 2015, 21:29:42 »
Clack used the Topre stem for Topre. Hipsterpunks used it as well for the first 3/4 of his mummy molds. Then he designed his own Topre stem.
Ive seen Nubs and now KK use it as well. Which is fine, it is an amazing design and works well. I was just curious who made these.
Offline KatzenKinder
  • Trade Count: (0)
« Reply #14 on: Sun, 30 August 2015, 23:52:22 »
I made them, definitely didn't use punks stems seeing as I don't own a KBK / KWK
Filled the center in with clay myself...
edit: more pictures of caps that came from the same molds here
https://geekhack.org/index.php?topic=70059.msg1840357#msg1840357
I'm no copy pasterino
*the right set not the left, left was my old topre mold
« Last Edit: Sun, 30 August 2015, 23:57:31 by KatzenKinder »
Offline PocketFool
  • Trade Count: (0)
« Reply #15 on: Mon, 31 August 2015, 00:42:14 »
I made them, definitely didn't use punks stems seeing as I don't own a KBK / KWK...
Those caps are gorgeous, so of course you made them, Katz! :thumb: Out of curiosity, did you pass on using punks stems because you knew/thought that you'd be able to improve upon the stem itself, or did you mainly just want to have something that was purely "your" creation?
Offline clacktalk
  • Trade Count: (0)
  • circa 2015
« Reply #16 on: Mon, 31 August 2015, 00:55:48 »
how will i believe your artisan stem analysis anymore : ' [
diary of a clacktalk
radio_killah: too much frank
  • Trade Count: (0)
« Reply #17 on: Mon, 31 August 2015, 00:56:05 »
It's not an improvement by any means; punks did a much cleaner job with the topre stem. The reason I filled the stem in my original molds was to reduce the amount of places that air could be trapped, since I wasn't using pressure at the time. There are only so many ways to fill the space between the two parts of the stock topre stem, hence the similarities between ours.
  • Trade Count: (0)
« Reply #18 on: Mon, 31 August 2015, 01:18:44 »
For clarification, I've never used anyone's stems except my own.  I respect other artisans too much to mold any part of their caps.  My Topre stems were all modified Topre caps (I filled the stem with the same material I use to make my masters) and they are moving to 3D modeled ones I did myself.  The filled in Topre stem was because I was not happy with the strength or durability of the standard Topre style stem and felt that it should be filled in for max durability and strength.
My MX now are ones I 3D modeled myself.  I'm planning on switching over to square stems shortly that will be MX and Topre cross mount compatible.I've worked on a dual compatibility Topre/MX stem that I'd like to do, but no printers seem to have a high enough resolution to successfully make.  Alps stems are coming as are BS stems once I get the BS stem finalized.  Both of those will also be stems I entirely 3D modeled on my own.
« Last Edit: Mon, 31 August 2015, 01:21:11 by nubbinator »
Offline nickheller
  • Cherry ML life
  • Trade Count: (2)
    • hickneller.com
Re: WTS GMK dogethink novelty keycap packs
« Reply #19 on: Mon, 04 November 2019, 13:28:15 »
Offline Auxo
  • Formerly CJD_Anthony
  • Trade Count: (0)
« Reply #20 on: Mon, 04 November 2019, 18:05:37 »
Thanks fam
Offline popkorn62
  • Trade Count: (0)
  • No keyboards for old men
    • Mekibo
« Reply #21 on: Mon, 04 November 2019, 20:50:09 »
In42
https://mekibo.com/
Offline slickmamba
  • Trade Count: (0)
Re: WTS GMK dogethink novelty keycap packs [sold]
« Reply #22 on: Fri, 08 November 2019, 03:44:30 »
Hi :)
Offline matrixzj
  • Trade Count: (0)
« Reply #23 on: Fri, 08 November 2019, 11:32:56 »
really want to grab one set. if anyone is willing to sell it? please let me know. Thanks
Discord:Matrix#6203
HHKB Fanatics
SA/GMK Keycaps Info
Offline AdrianMan
  • Trade Count: (0)
« Reply #24 on: Fri, 08 November 2019, 12:08:10 »
Would like one too, thanks !
Offline nickheller
  • Cherry ML life
  • Trade Count: (2)
    • hickneller.com
« Reply #25 on: Fri, 08 November 2019, 12:35:22 »
I have a few extra from some cancelled invoices, I will pm the both of you once I catch up on shipping. Locking the thread for now.
