Author Topic: How to use Teesy 2.0 for keyboard? Please help  (Read 2825 times)
Offline last100yen2
« on: Mon, 06 July 2015, 22:56:56 »
I am currently trying to install Teesy 2.0 to my realforce so that it can be removable usb keyboard
I installed all the wires but not sure how
 program teesy to become keyboard....what exactly am I suppose to do?
Please help fellow Geekhack geniuses
Offline merlin64
    • MechMerlin
Re: How to use Teesy 2.0 for keyboard? Please help
« Reply #1 on: Mon, 06 July 2015, 23:00:33 »
You don't need a teensy to make the usb removable. You only need it if you want to re-program all your keys.
You really only need to figure out which wires go to what on the cable, and buy a usb mini breakout board such as:
http://www.adafruit.com/products/1764?gclid=CjwKEAjwzuisBRClgJnI4_a96zwSJACAEZKenrrMb1hII7HekXAVuzrCk1GrPKQJs_uOwVY-c84FiRoC3qTw_wcB
Offline last100yen2
« Reply #2 on: Mon, 06 July 2015, 23:03:00 »
thanks for the info, but I already have teesy 2.0 and want to know how to make this work....
Offline merlin64
    • MechMerlin
« Reply #3 on: Mon, 06 July 2015, 23:10:30 »
Search Google for TMK firmware and you should get a link to github with the source code, and all the instructions you need for building, assembling and loading the firmware onto your Teensy.
The Teensy is used so as to provide a controller for a board that doesn't have one, or has a broken one. It can also be used for converting old connector types over to usb such as ADB, 5 Pin DIN, etc etc. Perhaps other Geekhackers can chime in, but I'm unsure if the TMK firmware supports usb to usb conversion.
Offline merlin64
    • MechMerlin
« Reply #4 on: Mon, 06 July 2015, 23:13:23 »
You also may want to provide a picture or a diagram of what you mean by "install the wires".
Offline last100yen2
« Reply #5 on: Mon, 06 July 2015, 23:19:56 »
Offline merlin64
    • MechMerlin
« Reply #6 on: Mon, 06 July 2015, 23:27:43 »
Ok yah...if you're happy with the key layout, it would have been easier with the adafruit link I sent you.
What guide were you following to know to connect the wires to F7 and B6?
Offline last100yen2
« Reply #7 on: Mon, 06 July 2015, 23:29:22 »
someone in geekhack used teesy 2.0 to convert PS2 to USB and he told me to do this setup
but I am still confused as what to do with programing....so confusion
Offline merlin64
    • MechMerlin
« Reply #8 on: Mon, 06 July 2015, 23:31:22 »
Is your keyboard PS/2?
Offline last100yen2
« Reply #9 on: Mon, 06 July 2015, 23:32:41 »
no it is not, its USB....I am hoping it works...
I downloaded TMK firmware and it shows usb to usb..but not sure what to load to my device...or how
Offline merlin64
    • MechMerlin
« Reply #10 on: Mon, 06 July 2015, 23:35:38 »
There should be instructions on the site that tell you to download a few more things and how to make the hex file. It's fairly long and very well written. Read the whole thing a few times before trying to do any of it.
Offline jackiecanev2
« Reply #11 on: Mon, 06 July 2015, 23:35:59 »
As far as I know, there's no pre-existing TMK fork/map for any RF (and there are many iterations); unless you know the matrix setup/pinout (hard enough to work through with normal switches, let alone variable capacitance) and want to do some serious source code work, I don't think you'll be flashing TMK on your teensy RF anytime soon*. My $0.02 would be to sell the teensy and buy a breakout board like Merlin suggested.
*Some people here have a hard enough time compiling and flashing firmware, even when the source code (minus your keymap) is provided; it's not to say that you can't, but it's not for the faint of heart and if you do, post it to github when you're done!
| HHKB2 | Viper | 356.2 | Ducati | pitties | scalpels |
Offline merlin64
    • MechMerlin
« Reply #12 on: Mon, 06 July 2015, 23:38:20 »
yaaay a more senior member responded!
But yes...in the time it would take you to figure out how to code the teensy to offer a "pass thru" connection, the adafruit product I recommended could already be at your doorstep.
Offline last100yen2
« Reply #13 on: Mon, 06 July 2015, 23:45:48 »
Thank you guys for your suggestions
I will just get the board you suggested and get it done...I appreciate the help
Thank you again
Offline merlin64
    • MechMerlin
« Reply #14 on: Mon, 06 July 2015, 23:51:33 »
You don't have to get it on adafruit.
I would suggest just searching ebay for
"usb mini breakout board". That should give you a whole lot of options.
Offline last100yen2
« Reply #15 on: Mon, 06 July 2015, 23:56:29 »
Yeah, the shipping cost was outrageous, so I bought it at ebay
thank you for your suggestion
