Mod Edit: removed "orders now open!" from the subject.The web site is a go! Time to order your Brand New Model F Keyboard! $160,000+ in orders so far!
Please head to
http://www.ModelFkeyboards.com to place your order! In general, keyboards ship out by the timestamp of your order - first in, first out!
This thread is for discussion of ongoing development of the Brand New Model F Keyboards project, including the ultra compact cases and split right shift (HHKB style) options. Please head to the group buy for discussion on project updates and ordering options.
https://geekhack.org/index.php?topic=79141.0F62/F77 Prototype testing, brief teardown, and sound comparisons with original IBM keyboards
F62 / F77 features:
Only new parts will be used - not New Old Stock or used part pulls from other keyboards (you can use your original IBM/Lexmark/Unicomp caps - they will be compatible)
Metal top and metal bottom case, like the original
Metal top and metal bottom inner "sandwich" plates with interlocking tabs, like the original
Model F barrels and full-size capacitive flippers, all injection molded for accuracy/durability (not 3D printed)
2 mm foam like in my original F77
Ships fully assembled at no extra charge - no further soldering will be required. You will put on the feet though!
Cork-rubber feet, plus a small selection of rubber feet (cork-rubber feet like the PC XT Model F keyboard)
Top and bottom case powdercoated in a color similar to the original "off white/beige" color, black, or similar to industrial gray (or you can pick your own color and pay extra for tooling)
New buckling springs made to original Model F spring tolerances (ideally)
Keys to be sourced from Unicomp (or you can provide your own keys). To use brand new one-piece dye sub keys instead, someone else would need to take on production of the keys.
Layouts can be adjusted at the factory, or you can adjust them later for international versions
Metal tabs attached to the top inner assembly for the Model M style spacebar stabilizer wire - no plastic pieces like in the original
Packed like a new keyboard: in two custom white EPS foam shells and in a close-fitting brown double-walled cardboard box
Fully assembled in China
10 foot monoprice USB cable with ferrite core
Extra barrels (AT-style) and capacitive flippers will be produced and made available for purchase separately (for other projects and for replacement parts)
Any other suggestions?
After everyone interested has placed their order and sent payment, please be aware that it will be several months before your order arrives.
Working Prototype photos:
![[IC] F62+F77! New Kishsaver+Industrial Model F Keyboards 125899-0](https://geekhack.org/index.php?PHPSESSID=p27h34t3m816f31gvgc5s452lu84bol7&action=dlattach;topic=73363.0;attach=125899;image)
![[IC] F62+F77! New Kishsaver+Industrial Model F Keyboards 125901-1](https://geekhack.org/index.php?PHPSESSID=p27h34t3m816f31gvgc5s452lu84bol7&action=dlattach;topic=73363.0;attach=125901;image)
![[IC] F62+F77! New Kishsaver+Industrial Model F Keyboards 125903-2](https://geekhack.org/index.php?PHPSESSID=p27h34t3m816f31gvgc5s452lu84bol7&action=dlattach;topic=73363.0;attach=125903;image)
![[IC] F62+F77! New Kishsaver+Industrial Model F Keyboards 125905-3](https://geekhack.org/index.php?PHPSESSID=p27h34t3m816f31gvgc5s452lu84bol7&action=dlattach;topic=73363.0;attach=125905;image)
![[IC] F62+F77! New Kishsaver+Industrial Model F Keyboards 125907-4](https://geekhack.org/index.php?PHPSESSID=p27h34t3m816f31gvgc5s452lu84bol7&action=dlattach;topic=73363.0;attach=125907;image)
![[IC] F62+F77! New Kishsaver+Industrial Model F Keyboards 124187-5](https://geekhack.org/index.php?PHPSESSID=p27h34t3m816f31gvgc5s452lu84bol7&action=dlattach;topic=73363.0;attach=124187;image)
![[IC] F62+F77! New Kishsaver+Industrial Model F Keyboards 124189-6](https://geekhack.org/index.php?PHPSESSID=p27h34t3m816f31gvgc5s452lu84bol7&action=dlattach;topic=73363.0;attach=124189;image)
![[IC] F62+F77! New Kishsaver+Industrial Model F Keyboards 124191-7](https://geekhack.org/index.php?PHPSESSID=p27h34t3m816f31gvgc5s452lu84bol7&action=dlattach;topic=73363.0;attach=124191;image)
![[IC] F62+F77! New Kishsaver+Industrial Model F Keyboards 124193-8](https://geekhack.org/index.php?PHPSESSID=p27h34t3m816f31gvgc5s452lu84bol7&action=dlattach;topic=73363.0;attach=124193;image)
![[IC] F62+F77! New Kishsaver+Industrial Model F Keyboards 124195-9](https://geekhack.org/index.php?PHPSESSID=p27h34t3m816f31gvgc5s452lu84bol7&action=dlattach;topic=73363.0;attach=124195;image)
![[IC] F62+F77! New Kishsaver+Industrial Model F Keyboards 124197-10](https://geekhack.org/index.php?PHPSESSID=p27h34t3m816f31gvgc5s452lu84bol7&action=dlattach;topic=73363.0;attach=124197;image)
![[IC] F62+F77! New Kishsaver+Industrial Model F Keyboards 124199-11](https://geekhack.org/index.php?PHPSESSID=p27h34t3m816f31gvgc5s452lu84bol7&action=dlattach;topic=73363.0;attach=124199;image)
![[IC] F62+F77! New Kishsaver+Industrial Model F Keyboards 124201-12](https://geekhack.org/index.php?PHPSESSID=p27h34t3m816f31gvgc5s452lu84bol7&action=dlattach;topic=73363.0;attach=124201;image)
![[IC] F62+F77! New Kishsaver+Industrial Model F Keyboards 124203-13](https://geekhack.org/index.php?PHPSESSID=p27h34t3m816f31gvgc5s452lu84bol7&action=dlattach;topic=73363.0;attach=124203;image)
