Author Topic: What's your favorite text editor?  (Read 17608 times)
Offline UsualSuspectXXX
  • (⌐■_■)⊃━☆゚.*・。゚
Re: What's your favorite text editor?
« Reply #50 on: Tue, 14 July 2015, 21:48:38 »
I used to only use Notepad++ and Vim (yes, even on Windows). When I started my new job I switched over to Sublime and haven't dared go back. One of the largest appeals was the plugin for Salesforce.com development (my company is a Salesforce shop).
Offline PicklesKill
« Reply #51 on: Wed, 15 July 2015, 20:40:40 »
All this is just another reason why I love this forum.
« Reply #52 on: Wed, 15 July 2015, 21:06:07 »
Offline ishpeck
  • Life without MX Blues is no kind of life at all.
    • The Ishpeckian Network
0:=λfx.x
Offline daerid
    • Rossipedia
« Reply #54 on: Sat, 18 July 2015, 16:32:06 »
Then I got good with emacs and all other editors just fell by the wayside.
*hissssssss*
Offline jerue
  • (Whenever that happens :P)
« Reply #55 on: Sat, 18 July 2015, 20:05:38 »
Anyone using Coda/Coda for iOS? The iOS app just got a massive update. Definitely going to buy it soon, and will probably gift it for a friend of mine's birthday.
Offline Doyniish
  • Good you
    • Power Hour Playlists
« Reply #56 on: Tue, 21 July 2015, 20:00:08 »
Looks awesome, I have been thinking of purchasing it but would rather wait until I get a suitable iPad to edit with.
Offline fishcola
« Reply #57 on: Wed, 22 July 2015, 00:11:28 »
somewhere between emacs and mg for me! I don't use enough emacs plugins to make it an "ide" and i continue to work to make a leaner versionbetween the two extremes in that regard.
I used to use vim a lot, and i won't lie i make use of "hjkl" when i can find it implemented in applications that make use of it, ie: manpages, document viewers. if anyone uses a kde linux distro, okular is great for the hjkl-ing :D
ps: i'm often amused by the editor religious wars, but this graphic makes me smile; take note that she advises you learn both vim and emacs ;) http://sachachua.com/blog/wp-content/uploads/2013/05/How-to-Learn-Emacs-v2-Large.png
pps: i do want to see what all the textmate hype is about...
« Last Edit: Wed, 22 July 2015, 00:18:07 by fishcola »
Offline nothing4me
« Reply #58 on: Wed, 22 July 2015, 00:17:52 »
For Windows, it would be Sublime or Notepad++. I install Notepad++ on all new computers (much easier to use than Sublime for most people I've introduced both to).
Offline ishpeck
« Reply #59 on: Wed, 22 July 2015, 17:33:57 »
*hissssssss*
0:=λfx.x
Offline vyshane
« Reply #60 on: Thu, 23 July 2015, 09:42:43 »
I used to collect text editors like my wife collects shoes.
Among the collection were...
I keep putting off learning Emacs. I will have to take the plunge one day. With Evil mode, of course.
"You'll pry Vim out of my cold, dead hands... even after I switch to Emacs"? Doesn't quite have the same ring to it.
Offline pr0ximity
« Reply #61 on: Thu, 23 July 2015, 17:24:55 »
I don't use anything unless it has vim bindings available. I'm just nowhere near as productive without it.
Macros, norm, sed, block selection, ci/di/yi commands, etc. are all in other editors but my muscle memory is so solidified it's just not worth using anything else.
Offline ishpeck
« Reply #62 on: Sun, 26 July 2015, 22:04:32 »
Every now and again, I end up running vi inside an emacs terminal.  It's like they say: emacs is a fine operating system that only lacks a good editor. :P
The emacs/vi thing is a total false dichotomy for me.
0:=λfx.x
Offline jerr
« Reply #63 on: Sun, 26 July 2015, 22:09:56 »
I use Notepad++ because I'm too lazy to use anything else
Offline vyshane
« Reply #64 on: Sun, 26 July 2015, 22:20:30 »
I suspect that Emacs is a far more malleable tool than Vim.
I'm totally addicted to Vim's modal editing, but I don't feel strongly about Vim the tool itself. I'm not going to try and use it for everything. Instead, I run Vim plugins in various IDEs depending on what I'm working on.
