Author Topic: BFace Build Log  (Read 5266 times)
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
BFace Build Log
« on: Thu, 09 July 2015, 20:50:02 »
Preface:
I originally built this in Feb, and it was my first Kustom, but then I broke the PCB, and I recently got a new one, and it has stayed unbuilt, so I sold it as a board that I would custom build to their preferences. There are also some in-progress photos that are missing, but I can't be bothered to dig them up.
Disassembled Switches (Worn in clears from a Skidata board, had to clean out all the diodes)
Stems (and a spring) in isopropyl alcohol to clean of all the gunk from the past 21 years
Switch casing in isopropyl alcohol to clean of all the gunk from the past 21 years
Gold 62g springs!
Switches after being lubed, spring swapped, stickered, SIP socketed, and clear topped (I love the way  these look!)
Switches put in place on the plate, ready for soldering!
Switches soldered!
Caps off photo
Another angle
My blank blue IMSTO caps on (sadly they aren't going where the board is going)
I have never done ergoclears properly, and some people might say that I did these wrong as far as lube goes, but from the typing I did on it I really like them, and will be doing it with my next boards, but maybe with 67g springs. :)
And typing video (seizure warning, seriously)
« Last Edit: Wed, 15 July 2015, 14:29:45 by sethk_ »
Offline njbair
    • nickbair.net
Re: BFace Build Log
« Reply #1 on: Thu, 09 July 2015, 21:25:20 »
Those LEDs! My eyeballs hurt.
Nice job on the build. Those clear-topped switches look awesome.
My boards:
Offline alienman82
Re: BFace Build Log
« Reply #2 on: Thu, 09 July 2015, 22:15:47 »
removed.
« Last Edit: Thu, 01 March 2018, 17:20:27 by alienman82 »
Offline sethk_
  • www.kbdhub.com
    • My webstore
Re: BFace Build Log
« Reply #3 on: Thu, 09 July 2015, 22:21:14 »
did you buy the skidata off ebay for what $140 shipped I think the guy was asking?  And was it worth it?
No, but skidata's are worth the price, you get the caps, the switches, and the stabs. I am looking to buy more in the future if  you want to hop on, PM me.
Offline Jokrik
Re: BFace Build Log
« Reply #4 on: Thu, 09 July 2015, 22:40:52 »
Ma eyes! :D
that switch photos are dope! so sexy with that clear cover
