Author Topic: [GB](Closed) 1.8mm LEDs & SIP Sockets  (Read 112269 times)
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« on: Fri, 10 July 2015, 02:59:31 »
GB is now closed, collection starting today, you have until Sunday to pay it, if you need to work something out, PM me.
GB Information:
This groupbuy will run for 4 weeks, until August 8th. MOQ for each is 1000, but because there is enough interest, I will do this like I did with my stickers, and start invoicing once we break the initial MOQ.
How ordering works:
Each part is in a group of 10, so if you want 100 LEDs, or 100 SIP sockets, all you need to put in for your order is 10.
LED Colors Available:
Yellow $0.40 per 10
Green $0.40 per 10
Red $0.35 per 10
Blue $0.45 per 10
White $0.47 per 10
Pink $0.55 per 10
SIP Sockets:
Zeal's separated sockets $1.25 per 10
Mil-Max Plastic-Sheath SIP Sockets We will see when it is over
Shipping:
USA $5.95
INT $7.00
GB Fee & Discounts:
Since PayPal has a 30c invoice fee, and they also take 2.9%, I will just be adding a dollar to cover invoicing fees. If you order more than 1k LEDs, you get a 10% discount.
Order Form
http://goo.gl/forms/iEyATidRLR
Estimated turn around time: I plan on having these out by the 2nd week of September, but probably earlier than that because I have the proper boxes for the most part, and I will have help sorting. Any questions can be sent to my PMs and I will answer them to the best of my ability.
IC Thread: https://geekhack.org/index.php?topic=73230.0;topicseen
« Last Edit: Mon, 10 August 2015, 09:17:23 by sethk_ »
Offline filphil
  • One day I hope to find a love like JD and Turk
Re: [GB](Open) 1.8mm LEDs & SIP Sockets
« Reply #1 on: Fri, 10 July 2015, 08:45:28 »
If I put an order in and want to change the amount will I simply have to resubmit the form?
Thanks for doing this.  :thumb:
Offline azhdar
  • Praise the AZERTY god
« Reply #2 on: Fri, 10 July 2015, 08:49:02 »
Excellent prices.
I'll put up my order once I have figured out my numbers.
Azerty Propagandiste
Offline ccarlitos2
« Reply #3 on: Fri, 10 July 2015, 08:54:44 »
Yay! I'll put in my order once I figure out what color and how many I want. I think yellow would go great on a keyboard with TA, but I wanna think about it a little more.. hmm.. maybe pink..
Offline yobinad
« Reply #4 on: Fri, 10 July 2015, 08:57:07 »
I'm confused
SIP Sockets $0.69 per 10 is 10 pair or 5 pair ?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #5 on: Fri, 10 July 2015, 09:18:18 »
I'm confused
10 SIP sockets, not pairs, so you only get 10 SIP sockets, so 5 pair
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #6 on: Fri, 10 July 2015, 09:18:41 »
Yeah, but put in your whole order each time you update, makes it easier
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #7 on: Fri, 10 July 2015, 09:33:58 »
On the form, how do I specify which SIP sockets I would like?
Offline Invaderevan
« Reply #8 on: Fri, 10 July 2015, 09:43:57 »
in for stuff and things!
WTTF Ribbits, Ashen V2 MX, Bronins
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #9 on: Fri, 10 July 2015, 09:45:13 »
I did not have both when I made the form, let me fix that
Offline wakko
« Reply #10 on: Fri, 10 July 2015, 09:45:39 »
^ ... what he said?
NOOB
KUL ES-87
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #11 on: Fri, 10 July 2015, 09:45:53 »
and fixed! Sorry about that!
Offline Lastpilot
  • Power stance
« Reply #12 on: Fri, 10 July 2015, 09:55:03 »
Okay, just sent in a corrected order of 1,000 LEDs and 400 SIP sockets. Please ignore the 10,000/4,000 order lol.
Offline inanis
    • SEALWoodworking
« Reply #13 on: Fri, 10 July 2015, 10:00:28 »
Thanks for fixing the form. My order has been submitted. And thank for running the GB.   :thumb:
Offline Hellcatz
« Reply #14 on: Fri, 10 July 2015, 10:54:03 »
What the difference between the two sip sockets?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #15 on: Fri, 10 July 2015, 10:55:54 »
Zeal's do not have the plastic sheathing and are a bit longer, easier to use IMO, I like them more, but the other ones are the mil-max ones in plastic shipping.
Offline wlhlm
« Reply #16 on: Fri, 10 July 2015, 10:57:21 »
From IC thread:
sethk_: Do you have prices on the SIP sockets yet?
I think so. They are pre-separated from the plastic sleeves, so they are ~13c each. I personally like using these more and don't mind the premium since they are pre-separated.
A little disappointed on the SIP price. They are available ~8c each on mouser when you buy 10 just units (64 pieces each). The little sleeves pop off easily with flush cutters, not that much of an inconvenience imo. I'm still in for a big order of LEDs though!
EDIT: Forgot to acknowledge that the Zeal SIP sockets are slightly different than the MillMax ones on mouser. Both have worked great for me though, no preference for one or the other.
I've since changed to a different type of SIP socket from what you've purchased. My individually removed SIP sockets have a ~5mm long soldering tail.
Yeah, 0.170" solder tail would be good... I've used the ones with 0.125" solder tails and they don't protrude from the PCB, so soldering them is tricky.
Milmax ones have a solder tail that's roughly 4.3mm. The ones I stock have a 5mm tail. :)
(Pic provided by sethk_)
Offline rpeterclark
  • RPTR ❌
« Reply #17 on: Fri, 10 July 2015, 16:05:32 »
Great prices! Order submitted!  :thumb:
Offline AKmalamute
  • HHKB Scrub
« Reply #18 on: Fri, 10 July 2015, 17:28:31 »
These are just LEDs, not the matching resistors, right? Are the voltages named in the IC so I can make a note of what 'size' resistors to get? Since I'm hoping for some of four different colors.
(so ... much ... pink)
HHKB-lite2, Dvorak user
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #19 on: Fri, 10 July 2015, 17:50:32 »
I have personally found that 830ohm works for me for any LED colors, but I am probably retarded for doing it and probably screwing something up. Winkeyless uses these same LEDs and he says that for a 60% board, 830 is fine for any color.
Offline uJalled
  • Shrimp cracker enthusiast
« Reply #20 on: Fri, 10 July 2015, 19:41:35 »
yayy in for blue, green, and white  :)
Offline Grrizz
« Reply #21 on: Fri, 10 July 2015, 20:13:58 »
I'll echo the other requests: Datasheets for the LEDs would be a nice addition :)
Offline VinnyCordeiro
« Reply #22 on: Fri, 10 July 2015, 20:38:41 »
830 ohms is high enough to guarantee that it'll work with any color. That's why I asked for the specs of the LEDs (still waiting), so I can calculate a lower value resistor to increase current/brightness and still don't fry the USB port.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #23 on: Fri, 10 July 2015, 21:39:38 »
It does not say, but winkeyless uses the same LEDs, so maybe you could shoot him an email http://winkeyless.kr/product/1-8mm-led/
Offline quake4mhg
« Reply #24 on: Fri, 10 July 2015, 23:50:48 »
You mean I cannot use any color LED I want or fry my Race1? :-X I go check my Race1 spec ...
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #25 on: Sat, 11 July 2015, 00:01:18 »
You can, you should be fine, but look at the specs just to be sure. I am not the one to be asked about ohm as far as LEDs go, I just solder it in and hope it works
Offline quake4mhg
« Reply #26 on: Sat, 11 July 2015, 00:03:44 »
But white color should be fine, right? Cos it originally is white led.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #27 on: Sat, 11 July 2015, 00:12:55 »
yes!
Offline Grrizz
« Reply #28 on: Sat, 11 July 2015, 01:38:05 »
I think most KBs use high resistance values due to the USB current limit vs. the high number of LEDs on a KB so you can probably put pretty much any LED in and be well under their nominal current let alone their max current, it is always nice to have a datasheet though to know for sure.
« Reply #29 on: Sat, 11 July 2015, 01:47:00 »
Nah, a 5V power supply, a multimeter and a decade resistance box are all I need to discover what I want. ;)
Offline Wilba
  • Keyboard Stuff Person
    • wilba.tech
« Reply #30 on: Sat, 11 July 2015, 07:22:14 »
Or just a multimeter that can measure diode voltage. You can pretty much assume ultrabright LEDs will have forward voltage drop of 3.5V, except for reds which might be as low as 2V.
If you have a keyboard that powers all LEDs in parallel (i.e. one resistor per LED), start with the max current you want to supply all LEDs.
Let's be conservative and choose 400mA, leaving 100mA for powering the microcontroller.
Divide that by the number of LEDs. Let's say 61 keys for a standard 60%... so 6.55mA per LED.
If you were using ~3.5V forward voltage drop LEDs (e.g. white, blue, green, etc.) then the resistor value would be: R=V/I = (5V-3.5V)/0.00655A = 229 ohm
However, if you wanted to be compatible with LEDs with forward voltage drops as low as 2V, then do:  R=V/I = (5V-2V)/0.00655A = 458 ohm
Therefore, something like 470 ohm is a good choice for a 60% keyboard, and be compatible with white or red LEDs.
Reversing the math, white LEDs would receive 3.1mA and red LEDs would receive 6.3mA.
Now, if you were ONLY going to use LEDs with forward voltage drop of 3.5V (i.e. never use red LEDs), then you can use something closer to 229 ohm, so the LEDs get closer to 6mA each.
« Reply #31 on: Sat, 11 July 2015, 14:07:09 »
That's pretty much what I already calculated, but you know that The Real World™ isn't always so mathematically predictable. And the values changes when you are dealing with more LEDs. Like a 78% keyboard that some Brazilian guy is designing. :P
EDIT: I'm just waiting for USB 3.1 (and type C connectors) to become more common. It will support up to 3 A of current, we will be able to lit all the LEDs at full power.  ;D
« Last Edit: Sat, 11 July 2015, 21:34:19 by VinnyCordeiro »
Offline swimmingbird
  • keyset hoarder
« Reply #32 on: Sat, 11 July 2015, 18:58:53 »
I only just found out what SIP sockets are and I want them so bad now!
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #33 on: Sat, 11 July 2015, 19:07:26 »
if you made an order, you can just submit a new one
  • keyset hoarder
« Reply #34 on: Sat, 11 July 2015, 20:10:38 »
Just about to order
Does anyone know if these LEDs will work with the 470R resistors on my GON?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #35 on: Sat, 11 July 2015, 20:11:54 »
Just about to order
What resistance? I have never had any troubles with resistors personally, but I might be lucky.
Offline MagicMan
« Reply #36 on: Sat, 11 July 2015, 20:18:49 »
Just put an order in, I forgot it takes 2 sip sockets per switch.
Max Keyboard - Cherry MX blue
  • keyset hoarder
« Reply #37 on: Sat, 11 July 2015, 20:34:23 »
Just about to order
470 Ohm
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #38 on: Sat, 11 July 2015, 20:35:34 »
Just about to order
470 Ohm
They should, look at what Wilba posted
Offline tjweir
« Reply #39 on: Sat, 11 July 2015, 21:23:41 »
Ordered, thanks for running this.
  • keyset hoarder
« Reply #40 on: Sat, 11 July 2015, 22:14:23 »
Just about to order
470 Ohm
« Reply #41 on: Sun, 12 July 2015, 02:05:07 »
Very ordered.
As the price was lower than I'd originally thought, I went for 50 of each ;D
Offline yobinad
« Reply #42 on: Sun, 12 July 2015, 14:46:55 »
Ordered  :)
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #43 on: Tue, 14 July 2015, 10:54:16 »
So far MOQ has been hit for everything except for yellow LEDs and the SIP sockets from Zeal, but this is only after the first weekend, so as far as I am concerned, everything should hit MOQ, and if it doesn't, I will just round up to MOQ.
Offline potatowire
« Reply #44 on: Tue, 14 July 2015, 11:16:56 »
Are you planning to invoice us after the GB window closes?
Thank you for running this. I look forward to being buried by piles of LEDs.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #45 on: Tue, 14 July 2015, 11:25:41 »
In a day or so
Offline potatowire
« Reply #46 on: Tue, 14 July 2015, 12:05:19 »
Great, thanks!
Offline nmur
  • ಠ_ಠ
« Reply #47 on: Tue, 14 July 2015, 12:28:26 »
Ordered at least 100 of each colour plus a bunch of sip sockets.
I've only got one project on my sights, but you never know what you might feel like doing later on  down the track ;)
« Reply #48 on: Tue, 14 July 2015, 15:06:34 »
Need moar yellow orders plz ;D
Offline AKmalamute
  • HHKB Scrub
« Reply #49 on: Wed, 15 July 2015, 11:26:30 »
That's not a bad idea. I forgot what I ordered, but I don't think there were any yellows at all (?). Hey Seth can you add a '2' (20 LEDs) to my order?
