Author Topic: Looking for a Matias small board (FK-303_usb)  (Read 81130 times)
Offline magetricks
« on: Fri, 10 July 2015, 09:35:38 »
Does anyone know where I can find Matias part # FK-303_usb for a http://matias.ca/miniquietpro/pc/?
I contacted customer service, and they claim they don't sell them, which is unfortunate being that I banged up my micro USB connector and board. The micro USB connector on mine was broken after a fall and did some damage to the circuit board itself.
Re: Looking for a Matias small board (FK-303_usb)
« Reply #1 on: Fri, 10 July 2015, 09:44:39 »
You might provide a photo of the broken piece then someone may be able to tell you an alternative.
Offline vernonlloyd
« Reply #2 on: Tue, 13 October 2015, 19:54:23 »
same thing happened to me. Micro usb fell off :( I think the micro usb port is weak. Hope they can have a replacement for this or our keyboard will be just an expensive paper weight...
Offline Fuzzybear
« Reply #3 on: Sun, 07 February 2016, 11:32:27 »
If you know someone who can do some simple soldering, or if you're inclined to pick up a soldering iron and go watch some youtube videos on soldering, it should be less than a 3 minute fix .
You can buy USB connectors in all shapes and sizes from places like Farnell.
http://www.newark.com/webapp/wcs/stores/servlet/Search?pageSize=25&st=micro+USB&catalogId=15003&categoryId=800000054002&langId=-1&storeId=10194
