Author Topic: Rectangular Rubber Feet - Where to buy?!  (Read 1906 times)
Offline Dreamre
    • kbdlife
« on: Sat, 11 July 2015, 16:51:53 »
Hi guys,
Does anyone know where I can buy some rectangular rubber feet? I'm looking for ones similar to the ones on the bottom of a Filco or QFR? I know there's the circular bump-on ones, but I much prefer the rectangular.
Any help is much appreciated.
Offline Invaderevan
Re: Rectangular Rubber Feet - Where to buy?!
« Reply #1 on: Sat, 11 July 2015, 17:16:50 »
I have looked into sheets of adhesive backed rubber that would just need to be cut to size, like this
http://www.allelectronics.com/make-a-store/item/fp-3/100-x-54mm-rubber-pad-w/adhesive-backing/1.html
but I have not tried it yet, been looking for something locally available.
I would also like to know if there is a better option available, my Lightsaver didn't come with rubber feet :/
WTTF Ribbits, Ashen V2 MX, Bronins
Offline Dreamre
    • kbdlife
« Reply #2 on: Sat, 11 July 2015, 17:33:01 »
That's what I'm looking for but a thin strip so I can just cut to size in terms of length. Hopefully others may have some input. Thanks!
Offline VinnyCordeiro
« Reply #3 on: Sat, 11 July 2015, 17:41:32 »
I would buy, but living outside US means that shipping will be way more expensive than the rubber pads themselves.  :'(
