Author Topic: [IC] Varmilo VA12M - Custom Numpad Tester  (Read 10573 times)
Offline HendyZone
  • HHKB Elite
    • MechanicalKeyboards.co.id
« on: Mon, 13 July 2015, 10:55:17 »
Hello all :cool:
Actually right know we are dealing distributorship with Varmilo about their products in ID (Indonesia)
I thought their new switch tester is really cool
- Micro USB Connector
- LED
- 12 Switch
- PBT Keycaps
- Aluminium housing
Sample :
You can request both combined Cherry MX / Gateron Switch, Switch Position, LED Color
If many people are interested in, i will open the group buy here
For pricing i will update very soon
Offline Data
Re: [IC] Varmilo VA12M - Custom Numpad Tester
« Reply #1 on: Mon, 13 July 2015, 11:56:27 »
Hmm...  Similar to the one that was run on Massdrop a few months ago.  Looks like they added another row to the top and painted it.
I hope they improved the quality of their PCB.  The one that came with the Massdrop tester was terrible and nearly impossible to solder some pads.
You mentioned USB support.  Where is the connector?  I don't see one in those photos.
Offline Latin00032
« Reply #2 on: Mon, 13 July 2015, 12:03:19 »
I missed this on md. This looks cool.
I'd get one depending on the price.
Can I program macros?
Offline Data
« Reply #3 on: Mon, 13 July 2015, 12:19:05 »
Found a better image here: http://www.igao7.com/news/201503/lG3HnF4uSBcO1X8p.html
Original (HUGE)
So it does appear to have a controller (of some sort) and might be programmable.  If so I'm definitely interested.
Offline lolpes
« Reply #4 on: Mon, 13 July 2015, 12:20:50 »
Interest is here :D
Offline KnivesM
« Reply #5 on: Mon, 13 July 2015, 12:33:27 »
http://www.pcwaishe.cn/article-11564-1.html
Whole bunch of photos here, was posted about a month ago on reddit.
I'd be interested in getting one if the price is reasonable
Others
Offline lolpes
« Reply #6 on: Mon, 13 July 2015, 18:44:46 »
Just please do that color splash in blue and silver :3 or blue and cyan :3
Offline HendyZone
  • HHKB Elite
« Reply #7 on: Mon, 13 July 2015, 20:15:53 »
Original (HUGE)
Yes i forgot to take a shot of the connector
here is the picture when it plugged in
« Reply #8 on: Mon, 13 July 2015, 20:43:22 »
Interested.
Offline quake4mhg
« Reply #9 on: Mon, 13 July 2015, 22:45:35 »
What do we need to solder to make it works? Little wires on the back between switches & controller?
Offline Danboard
« Reply #10 on: Mon, 13 July 2015, 23:12:41 »
Definitely interested!
Offline HendyZone
  • HHKB Elite
« Reply #11 on: Tue, 14 July 2015, 07:31:46 »
You don't need to play with solder
It comes assembled :thumb:
Offline quake4mhg
« Reply #12 on: Tue, 14 July 2015, 12:22:14 »
I mean to make it works like a real numpad with computer. Thanks.
Offline Data
« Reply #13 on: Tue, 14 July 2015, 14:38:01 »
It doesn't exactly have enough buttons to emulate a full numpad.  If it's programmable (it probably is) you can assign your own functions to it, including number keys, using software.  There's no soldering involved, but there might be some programming.
Offline Latin00032
« Reply #14 on: Tue, 14 July 2015, 19:30:27 »
Im hoping for some macro type programmability.
It will make it easier for me to use my autocad. Instead of pressing multiple keys.
Offline 00zeRO
  • mechanicalkeyboards.com
  • * Commercial Vendor
  • The 00verseer of Vault 77
    • Mechanical Keyboards
« Reply #15 on: Tue, 14 July 2015, 21:27:02 »
Deal me in...
Daily Driver: Typist A w/Midnight Dawn | Kailh BOX Clicks
Junktown 2: Now on eBay!
Offline Data
« Reply #16 on: Wed, 15 July 2015, 08:03:49 »
Maybe, depends on how robust the programming software is -- assuming there is software.  We know nothing at this point.  It may require writing your own firmware and device drivers for all we know.
Offline SamFlynn
  • Location: From inside the hive, behind your eyes, and off the grid...into the Black.
  • Type until there is no need...
    • Firefly Online Forum
« Reply #17 on: Fri, 10 June 2016, 23:22:57 »
I have one of these, and I want to break the code and reprogram. Does anyone know what we are dealing with in the controller before I desolder mine to the max? I really want to write my own firmware for mine since it does not send Numpad codes, but number rows...yuk.
<Press Any Key>
Offline _skeletontoucher
« Reply #18 on: Wed, 08 February 2017, 08:57:30 »
Hey, were you able to reprogram this controller? I've been wanting to turn mine into a mini-game pad.
Offline SamFlynn
« Reply #19 on: Wed, 08 February 2017, 10:26:10 »
Nope. The problem is that the controller is very simplistic and requires a hardware rewriter in order to make changes. I tried the USB to USB converter made by Hasu, but it will not work at all. (Any Varmilo brand keyboards I have tried have the same result)
I think we're stuck...
<Press Any Key>
