Author Topic: Is it possible to remove the side-print of GMK keycaps?  (Read 7868 times)
Offline KHAANNN
« on: Mon, 13 July 2015, 13:51:58 »
I have no GMK keycap set myself, but most of the GMK sets that I like have side-prints that I absolutely hate
For example the @ side print on the '" keycap
Is it possible to just scrub/remove them without leaving a trace? (or much of a trace)
Re: Is it possible to remove the side-print of GMK keycaps?
« Reply #1 on: Mon, 13 July 2015, 17:36:19 »
They're pad printed, so you should be able to remove them.  I'm sure there's some solvent that could do the job without marring the plastic.  What that solvent is is a mystery to me though.
Offline CaplockJack
« Reply #2 on: Mon, 13 July 2015, 19:50:09 »
Try Magic Eraser
Offline KHAANNN
« Reply #3 on: Mon, 13 July 2015, 20:06:19 »
Try Magic Eraser
Interesting :)
Never seen the product, just google/researched it, not available locally
Normal soft erasers might also work, I use them to remove adhesive stains, but they might also affect the side-shine of the keycap
« Reply #4 on: Mon, 13 July 2015, 22:25:40 »
Magic Eraser is an abrasive, like super fine sandpaper or steel wool.  A normal eraser should not do anything to the pad printing.
Offline radio_killah
  • Chinchillin'
« Reply #5 on: Tue, 14 July 2015, 00:40:37 »
Isoproyl alcohol. It removed the red pad printed cyrillic legends on clacktalk's originative cyrillic set.
But oh make sure to use a diluted version. Don't use 100%
Offline KHAANNN
« Reply #6 on: Tue, 14 July 2015, 06:43:14 »
Wow that is an invaluable piece of information, thank you, I'm sure many (or probably 2-3 :) people will google this in the future and thank you too :)
Do you have any photos of the process / a suggested concentration to use / a description of the process/pace?
  • Chinchillin'
« Reply #7 on: Tue, 14 July 2015, 11:15:15 »
No photos but I have seen them in person and they got almost completely wiped off. I forgot his concentration but I think it was like 50/50 with water. It was quite funny to be honest since he only had the intention of cleaning the surface of the keycaps.
Offline KHAANNN
« Reply #8 on: Tue, 14 July 2015, 11:17:24 »
lol :D
Offline Dreamre
    • kbdlife
« Reply #9 on: Tue, 14 July 2015, 11:43:06 »
Nail polish remover/acetone will also remove it, but it will also melt the ABS plastic. Perhaps you may have some luck diluting it?
Offline KHAANNN
« Reply #10 on: Tue, 14 July 2015, 11:46:00 »
nope that would never work, at least acetone wouldn't work
I guess I might try some ripster style experiments If I need to remove the side prints, starting with isopropyl alcohol, in the meantime, I found a non-side printed set to use, so I will probably never pursue the idea unless something happens to the keycaps that I use/plan to use
Offline Dreamre
    • kbdlife
« Reply #11 on: Mon, 24 August 2015, 11:11:24 »
For those who are wondering, isopropyl alcohol (70% and 99%) cannot remove the side prints. I tried it myself.
Offline laminam
« Reply #12 on: Wed, 09 September 2015, 23:27:22 »
Thank you for the keyboard science.
