Author Topic: [GB][DONE] ROUND 2 LeandreN plate(designed by JDcarpe) + SPRiT PCB  (Read 259593 times)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
LEFTOVERS AND STUFF: LEANDREN.BIGCARTEL.COM
Universal 60% plate, support almost all layouts! Designed by JDcarpe
Choose between these colors
Purple
Blue
Dark red
Green
Black
Silver
Keep in mind:
Colors may vary from how you think they look. I will try to get them dark and vibrant.
The plate supports more layouts than the PCB!
PCB friendly, not suitable for handwiring, unless you like hot glue.
PCB-mount only. There is no way to have holes in the plate to clip stabs onto, and also have support for various layouts.
35$ 30$
More information
PCB
You should use the 60% PCB from SPRiT!
Available for an exclusive price of 45$ included in the shipping cost of your plate! This is the cheapest PCB around. Presoldered!
Read more about it here.
Available in blue, white or black!
Springs, LEDs & stabilisers
Springs
-  50  55  60  62  65  68  : all Gold & Standard
-  72  78  85  100 120  135  :  Gold Only
Measured in grams, Korean way!
6$ Standard
11$ Gold
LEDs:
White  Blue  Red  or Orange
100pcs
4$
Stabilisers
8$ for a set of PCB stabilisers. Standard, not gold.
ORDER FORM
Shipping
Still working on this one, may be slight variatons in price, 1 flat = one PCB or plate, 1 accesory kit is 3 packs of accesories(LEDs, springs and stabilisers).
1-2 flats is 10$ / 7$ EU
2-5 flats is 15$ / 11$ EU
5-10 flats is 22$ / 20$ EU
10-20 flats is 34$ / 30 $ EU
1 accesory kit is +3$
2 accesory kit is +7$
3 accesory kit is +10$
PP is 4%
This is just recomandations:
Case
Plastic case from Aliexpress 19.99$
More coming
More information + price coming.
Rules:
1§. Your package might be bent when it arrives, i will pack them after the packaging material i have available, but i can't make choose how the shipping company in your country treats the package. My experience from the last GB was that 60% off the plates where reported slightly bent, but after one night under a heavy book, was okay. I had a package to Asia who was totally unusable without a heatgun and other tools.
2§. If you can't pay the invoice by the invoice deadline, i won't ship the package to you. Leave me a message if you want to extend this deadline. I can't promise anything.
« Last Edit: Wed, 08 June 2016, 04:35:55 by LeandreN »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB] LeandreN plate + SPRiT PCB
« Reply #1 on: Sat, 01 August 2015, 09:41:35 »
Reserved
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #2 on: Sat, 01 August 2015, 11:58:57 »
Reserved
Offline a-c
« Reply #3 on: Sat, 01 August 2015, 12:27:01 »
Will you have PCB mount stabilizers as an option?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #4 on: Sat, 01 August 2015, 12:27:18 »
Yes.
Offline rpeterclark
  • RPTR ❌
« Reply #5 on: Sat, 01 August 2015, 12:47:13 »
I am in on this as soon as you put the order form up.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #6 on: Sat, 01 August 2015, 13:05:17 »
Great to hear!
Offline kennardsmith
« Reply #7 on: Sat, 01 August 2015, 13:31:13 »
Super excited for this!
[Control] is just left side of [A]. It comes from Sun Type3 key layout.
« Reply #8 on: Sat, 01 August 2015, 13:33:39 »
Count me in for at least one plate. I trust the design. ;)
Offline Fire Brand
  • Keeper of Rainbows
  • BISCUITS!
Re: [GB] LeandreN plate(designed by JDcarpe) + SPRiT PCB
« Reply #9 on: Sat, 01 August 2015, 14:03:30 »
Wait Can I buy one of those PCB's without getting the plate since I got one from you in the round 1 plates, and still need a pcb :x
My Youtube Channel ~
Keyboards owned
My classified thread :3
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #10 on: Sat, 01 August 2015, 14:04:40 »
That should work, yes :D Not before the GB starts though.
Offline Fire Brand
  • BISCUITS!
« Reply #11 on: Sat, 01 August 2015, 14:15:47 »
;D Thank you
Keyboards owned
Offline a-c
« Reply #12 on: Sat, 01 August 2015, 15:06:05 »
;D Thank you
Sprit's PCB's are very nice. I got two and built one using one of LeandreN's ANSI plates. Once you figure out the key layout program everything works great.
I also have a b.face winkeyless board. It is similar to Sprit's but also has the option for RGB led's on the bottom controlled by a second ATTINY85. Bought these as a bare board with just the controller parts. Soldering the controller parts is extra, diodes/soldering are extra, led resistors/soldering are extra.  If you don't mind spending the time soldering it's not too expensive. It uses the same key layout editor, with more options for the RGB leds. They ship DHL so buying a single board is expensive.
Offline FreeChemicals
« Reply #13 on: Sat, 01 August 2015, 15:07:43 »
Hmmmmm I might want another plate. This is what your first plate looks like with a blue SPRiT PCB: http://imgur.com/a/PnrzE  :thumb:
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #14 on: Sat, 01 August 2015, 15:18:04 »
;D Thank you
Cool!
Great to have more options.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #15 on: Sat, 01 August 2015, 15:18:42 »
Thanks for sharing, it looks really nice!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #16 on: Sat, 01 August 2015, 16:27:36 »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #17 on: Sat, 01 August 2015, 16:29:59 »
Hear that people? You can trust the design :)
Thanks for letting me use your design JD.
Offline zenless
« Reply #18 on: Sat, 01 August 2015, 17:16:25 »
Thinking about hoping on this and using it instead of an Infinity setup. Those sprit boards are all SMD already soldered on? I assume LED's are not by default.
I'm pretty tempted to switch my pcb/plate to this build instead. Thanks!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #19 on: Sat, 01 August 2015, 17:19:05 »
Presoldered for 45$, pretty good price :)
LEDs are unfortunately not included, but I might have it as an extra option beside.
Offline a-c
« Reply #20 on: Sat, 01 August 2015, 17:34:21 »
I paid $120 for my two Sprit boards shipped to the USA. This is a good deal especially if you are getting it with a plate.
Offline zenless
« Reply #21 on: Sat, 01 August 2015, 18:33:49 »
Yeah. Going to jump on this and go with it over the infinity board build. Great deal and good layout options. Watching this thread!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #22 on: Sun, 02 August 2015, 10:14:11 »
Yay! Great to hear!
Offline QuickDelat
« Reply #23 on: Sun, 02 August 2015, 10:34:50 »
A Europe based GB for a 60%, sounds amazing.
Very interested in what kind of cases you will offer.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #24 on: Sun, 02 August 2015, 10:36:51 »
I won`t be selling cases unfortunately. Just giving recomdations to you for your 60% build.
Offline 3K
« Reply #25 on: Sun, 02 August 2015, 11:17:36 »
So what about the PCB? Are they excluded too?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #26 on: Sun, 02 August 2015, 11:19:45 »
PCBs will be an optional add-on with the plate. It will also be shipped with the plate :)
Offline a-c
« Reply #27 on: Sun, 02 August 2015, 13:53:21 »
I bought several of those plastic cases from Aliexpress. They go on sale periodically, once was $17 each and then a few weeks ago it was $13 each. I bought 2 each time. In the first batch I got a black and a white. The black one was a little warped. It sit flat on a table but the left side was narrower than the right. I had to dremel out a bit of the inside so the space bar stabilizer wire (cherry plate mount) would not rub the case. The white one was just fine. In the second batch I bought 2 white ones. Both are fine. Comparing the 3 white ones the color is not consistent. Each alone looks fine but side by side they look different shades. At the price I paid I am happy with what I got.
As far as I can tell these are the same cases you can get with a third round Infinity or a KC60 on Massdrop. They look identical. I have both coming (eventually) so can compare them directly.
The hole for the DIP switch is on the small size. One switch is inaccessible on a V60. The Sprit PCB does not need this hole. There are no DIP switches on the Sprit PCB.
The only thing that these cases need is a sticker or plate to cover the ugly injection molding sprue mark on the bottom.
Offline faxe
« Reply #28 on: Sun, 02 August 2015, 15:28:16 »
So everythings except in switch led comes presoldered? Controller, diodes, resistors for led? Really interesting althoug I just finished a build with the last plate and a winkeyless b.face pcb....  :D
ISO Clueboard V2 Zealio 78g -ISO Clueboard V1 MX Clear - ISO 60% MX Clear - ISO Filco MJ 2 MX Brown - ISO is life
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #29 on: Sun, 02 August 2015, 17:20:21 »
Yes that's right! Time for your second 60% build!
Offline TalkingTree
    • My projects
« Reply #30 on: Mon, 03 August 2015, 06:59:44 »
How much is shipping for the PCB alone?
Offline Fire Brand
  • BISCUITS!
« Reply #31 on: Mon, 03 August 2015, 11:59:18 »
more than likely the exact same price as shipping for a plate, given its the same size and the weight is about the same
Keyboards owned
Offline norrinrad
« Reply #32 on: Mon, 03 August 2015, 16:46:23 »
Ooo would be very interested in this! To run the keyboard, would I need anything else apart from switches and diodes?
James
Offline norrinrad
« Reply #33 on: Mon, 03 August 2015, 16:47:06 »
Ooo I'd be very interested! Would I need anything apart from switches and diodes to run the keyboard?
James
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #34 on: Tue, 04 August 2015, 01:55:37 »
James
A case, no diodes is needed.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #35 on: Tue, 04 August 2015, 02:04:10 »
Yes
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #36 on: Tue, 04 August 2015, 14:33:10 »
Can't to see the choices of colors for the plate.
Offline inanis
  • Truly Literally The Cloud
    • SEALWoodworking
« Reply #37 on: Tue, 04 August 2015, 14:36:55 »
I too am looking forward to seeing those color options.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #38 on: Tue, 04 August 2015, 14:39:47 »
Options coming soon. Gonna be a poll
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #39 on: Tue, 04 August 2015, 14:40:49 »
Soon
Offline zenless
« Reply #40 on: Wed, 05 August 2015, 12:50:21 »
Soon
I'm excited, i keep looking hoping for an update... I need to be more patient
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #41 on: Wed, 05 August 2015, 13:01:13 »
Update
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #42 on: Wed, 05 August 2015, 13:05:28 »
Soon
Seriously though, waiting for samples. Should arrive next week! We have to decide the colors though!
« Reply #43 on: Wed, 05 August 2015, 13:10:29 »
Soon
Black, silver (clear anodized), grey, red. :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #44 on: Wed, 05 August 2015, 13:12:49 »
Soon
I want at least one option to be blue to match the new SPRiT PCB and the upcoming AUNK PCB from Vinny. But thanks for your input!
« Reply #45 on: Wed, 05 August 2015, 13:15:53 »
I get that, but you never see the pcb under the plate. Plate color should match or coordinate with the case instead.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #46 on: Wed, 05 August 2015, 13:17:52 »
Good point. I still like blue though.
Anyway, I think I need to make a poll soon.
Offline mashby
    • Mashby
« Reply #47 on: Wed, 05 August 2015, 15:36:54 »
A WYSE blue would be awesome.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #48 on: Thu, 06 August 2015, 12:22:11 »
UPDATE:
A lot of stuff happening next week.
I am setting up the shipping system. Please leave feedback!
The order form is almost ready. Samples for the PCB, plate, springs and stabs arriving next week. A huge thanks to SPRiT.
Do any one have a site where i can make a shipping calculator to make this easy?
Offline iAmAhab
  • Established member
« Reply #49 on: Thu, 06 August 2015, 12:34:55 »
Excel
