Author Topic: [GB][DONE] ROUND 2 LeandreN plate(designed by JDcarpe) + SPRiT PCB  (Read 254466 times)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Re: [GB][Taking orders] LeandreN plate(designed by JDcarpe) + SPRiT PCB
« Reply #150 on: Mon, 10 August 2015, 21:14:09 »
32 plates, 18 to go!
Please share this with your friends, and/or add another plate.
Offline theanyday
  • love love love
« Reply #151 on: Mon, 10 August 2015, 22:08:02 »
For sure it's not as nice and tidy as Amazon. It sometimes even feels a little sketchy, but so far I have not yet been burned. You'll have an opportunity to add notes to your order, be as specific as possible and don't hesitate to message the seller directly before, or after to make sure they got and understand your order. Pay with a credit card or something that offers a bit of protection. Also remember to be patient, these things are shipping super slow from China.
Well after several hours and several different email address I can't seem to get a verification email from AliExpress so might have to try and find a different clear case.
MIRA SE | White Fox w/ 67g Zealios | POK3R w/ Blues | K70 w/ Browns | Planck w/ Greens | NovaTouch TKL
Offline a-c
« Reply #152 on: Mon, 10 August 2015, 22:26:52 »
I used gmail. No problem receiving their signup or other messages. I think it may just take a while.
Offline twk
« Reply #153 on: Tue, 11 August 2015, 01:52:59 »
I have never build a keyboard before and I have som noob questions.
Will plate mount switches work? I have a keyboard that I want to use the switches from.
Are resistors compatible with white LEDs already soldered?
If I want springs that are a little bit harder than stock Cherry MX Brown which should I order?
Thanks in advance!
« Last Edit: Tue, 11 August 2015, 02:07:21 by twk »
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #154 on: Tue, 11 August 2015, 04:30:51 »
Thanks in advance!
You should get PCB mounted switches. That way, the switches clip into the PCB.
Resistors are already soldered and combatible with the LEDs.
You could try something like a 62g spring if you want a little weight increase.
Offline FreeChemicals
« Reply #155 on: Tue, 11 August 2015, 04:38:54 »
Thanks in advance!
I'm using plate mounted Cherry stabs with your V1 plate, works just fine.
Offline twk
« Reply #156 on: Tue, 11 August 2015, 04:58:24 »
Thanks in advance!
I'll think about it, thank you!
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #157 on: Tue, 11 August 2015, 08:15:09 »
What material is the plate made out of? Do you have any sample images to show the plate colours?
« Reply #158 on: Tue, 11 August 2015, 08:31:56 »
Thanks in advance!
Plate mount switches will work with the PCB and plate being offered here. PLATE MOUNT STABILIZERS WILL NOT. PCB mount stabilizers are REQUIRED for use with this plate design.
In order to mount the switches correctly in the large openings in the plate designed for multiple layout support, PCB mount switches are RECOMMENDED. Not required, but recommended, for added stability.
I assume since it is being anodized it's either 5052 or 6061 aluminum.
« Last Edit: Tue, 11 August 2015, 08:43:52 by jdcarpe »
Offline theanyday
  • love love love
« Reply #159 on: Tue, 11 August 2015, 08:40:04 »
You're absolutely right, I guess I was just a little anxious and impatient. After about 13 hours I received the verification email.  :thumb: Hopefully I can get one of those clear cases.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #160 on: Tue, 11 August 2015, 19:27:58 »
41 plates! We are really close to 50 plates. Thanks for all your orders.
The money left over in the GB will be used for further improvments in the next rounds.
70 is the final goal for the plates, but i might be very optimistic. 41, is still much.
Yes, you can change the colors after i get the samples, but please note that i only get "dark red" and "blue" samples.
Have a nice day! :)
Offline apolotary
  • Кто-нибудь купите мои клавиатуры ;__;
« Reply #161 on: Tue, 11 August 2015, 20:24:51 »
Sorry if that was asked earlier, but how much would it be to ship it to Japan?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #162 on: Tue, 11 August 2015, 20:26:09 »
10$ for 1 plate + 1 PCB :)
+3$ if you add up to 3 accessories.
Offline apolotary
« Reply #163 on: Tue, 11 August 2015, 20:35:48 »
Neat! Do you by any chance have switches too? Also when does this group buy end? I might jump onto the bandwagon if you're still selling in a couple of weeks :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #164 on: Tue, 11 August 2015, 20:39:21 »
A little under two weeks until it closes.
I do not have any switches. Anyway, they would cost a fortune to ship from here.
Offline trenzafeeds
  • **** off
« Reply #165 on: Tue, 11 August 2015, 21:48:03 »
Wow, props to you! In my experience the rates to Japan are often much higher.
What kind of switches are you looking for?
demik will never leave.
Unless he gets banned.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #166 on: Tue, 11 August 2015, 21:49:39 »
International shipping is all the same :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #167 on: Tue, 11 August 2015, 21:56:21 »
Production time is 2 weeks so the 3 weeks until shipping is very optimistic, but maybe not as realistic. I'll try my best though. Keep in mind there are parts and PCBs involved too!
Offline faxe
« Reply #168 on: Wed, 12 August 2015, 03:11:18 »
Ordered.... :eek:
ISO Clueboard V2 Zealio 78g -ISO Clueboard V1 MX Clear - ISO 60% MX Clear - ISO Filco MJ 2 MX Brown - ISO is life
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #170 on: Wed, 12 August 2015, 06:03:54 »
Samples are done. Colors are very off, i will get a better picture when i have them in my hands. If anyone has a way i can take a picture with accurate colors, let me know. I own a DSLR.
The two blues are the same color.
The other one is dark red(yes i know).
Better picture of the dark red:
Offline andysun
« Reply #171 on: Wed, 12 August 2015, 06:06:38 »
I'd say 7bit over at deskthority is a great source: http://deskthority.net/group-buys-f50/cherry-mx-taking-pre-orders-t2760.html
Or here in the classifieds. And welcome out into the light ;)
Thanks, that seems like a really good option! :)
I'm fairly new to this as well, just finished building on a GON 60% PCB (which is similar to this one), and I ended up ordering my switches from mechanicalkeyboards.com. I like MX Green switches, and they were one of the few places I could find them in stock at the time. I also really liked the orange aluminum TEX case they had....
Yeah, I checked MK.com before, but being US-based is a pain with customs :( too bad, because I also love their TEX cases.
Also, probably a silly question, what kind of screws will I need to assemble this plate and pcb on a case? Are they included?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #172 on: Wed, 12 August 2015, 06:08:13 »
The screws are always included with the case :)
Offline Applet
« Reply #173 on: Wed, 12 August 2015, 06:21:45 »
Any updates on the deadline? And when will the invoicing be done? I'd really like to join, but I have to check my economy :)
Is it possible to run TMK-firmware on these boards? (not a deal breaker, but I use it for everything else)
10 days :)
Would payment by the 25'th (of August) be fine? Thats when I get my salary (if so, I'm in for one or two plates, maybe a PCB :D)
« Last Edit: Wed, 12 August 2015, 06:32:15 by Applet »
Offline 3K
« Reply #174 on: Wed, 12 August 2015, 06:24:38 »
The red looks really nice! Well, as far as you can see it.
I just ordered but I think I'd like to change to a red plate!
If you can't get the color right you could try to adjust it in photoshop or something.
Offline andysun
« Reply #175 on: Wed, 12 August 2015, 07:44:48 »
Not for this one, according to the comments :P Where could I go about getting some?
http://www.aliexpress.com/item/Mini-Keyboard-GH60-plastic-Case-for-60-Mechanical-Keyboard-Compatoble-PBT-Keycaps-Poker2-Pok3r-Faceu-60/32311183273.html
Btw, any chance of a silver plate picture? :)
Offline faxe
« Reply #176 on: Wed, 12 August 2015, 07:48:05 »
In my experience Poker cases use  M2x5 screws. This must not be the right size for this specific case, but chances are pretty high.
« Reply #177 on: Wed, 12 August 2015, 07:50:50 »
Not for this one, according to the comments Where could I go about getting some?
Case screws are almost always M2 with 0.4mm pitch. I use 4mm long screws for mine, but most cases support up to 5mm.
Offline theanyday
  • love love love
« Reply #178 on: Wed, 12 August 2015, 09:03:37 »
Has anyone purchased this case: http://www.aliexpress.com/store/product/Acrylic-mechanical-keyboard-color-shell-scrub-poker-size-pure/1555390_32261256034.html Just wondering about quality mostly, seems a bit more sleek than the other plain clear one?
Offline bigDave
  • The biggest
« Reply #179 on: Fri, 14 August 2015, 12:15:20 »
Some quick questions:
Is the pcb and plate are compatible with poker cases?
Does the pcb support gateron switchs ?
Is the controller built it when it is shipped or do we need to solder it?
What type of solder is recommend?
Are the stabilizers cherry stabilizers?
Is it really $4 for 100 LEDs?
Just to clarify the plate supports both standard ANSI and standard ISO?
Sorry if some of these questions are silly or the answers are in the first post, this is my first time purchasing from geekhack and my first build.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #180 on: Fri, 14 August 2015, 12:23:38 »
Yes they are compatible with the Poker cases.
The PCB and plate support Gaterons switches, Cherry MX switches and all the other clones.
The PCB is plug and play, no controller or firmware required.
For soldering the switches, almost all solder should work, people may recommend something for you.
The stabilisers are PCB mounted stabilisers which mounts on the PCB.
4$ for 100 LEDs is correct :)
It supports ANSI and ISO.
Offline bigDave
  • The biggest
« Reply #181 on: Fri, 14 August 2015, 12:34:14 »
Thanks for the switch reply, are pcb stabilizers different to cherry ones? Does this mean that i need two types of stabilizers?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #182 on: Fri, 14 August 2015, 12:35:05 »
No, the PCB mounted replace the standard plate mounted ones.
You only need PCB mounted stabilisers.
« Reply #183 on: Fri, 14 August 2015, 12:47:14 »
There are 3 types of stabilizers generally available for MX switches -- Costar (plate mount), and Cherry (PCB mount or plate mount). The only type which mount to the PCB are Cherry, so indeed, these are Cherry PCB mount stabilizers.
There is also a new player in the stabilizer game, Matias, whose stabilizers work with both MX and Alps switches. But those are plate mount only, and require a different type of hole in the mounting plate than either Costar or Cherry. Best not to worry about those yet. :)
Offline bigDave
  • The biggest
« Reply #184 on: Fri, 14 August 2015, 12:49:05 »
So I should purchase the stabilizer accessory as I don't have any other stabilizers?
Offline DanielT
« Reply #185 on: Fri, 14 August 2015, 12:50:37 »
I have already placed my order :d but I have a small question, does the plate support the IvanIvanovici layout ? I want to do that with GH60 PCB :D
« Reply #186 on: Fri, 14 August 2015, 12:51:08 »
Yes, you will need stabilizers.
I think so, but I will verify for you. It should support almost anything.
Offline bigDave
  • The biggest
« Reply #187 on: Fri, 14 August 2015, 12:52:12 »
Thanks for the help!
Offline megaforce
« Reply #188 on: Fri, 14 August 2015, 13:05:56 »
Order placed, looking forwards to the goodies!
Thanks for running the GB.
Corsair K63 Wireless | Razer Huntsman Elite
Hokusai | Ogre| Yohane | Mc65 | Kaze | RBB
Former: LZ MX | LZ FE | LZ CLS TKL Silver |LZ CLS TKL Gray| LZ St | V.EA | Blackbird | LSV3 | OctagonV2 | Norbatouch | X60 | TX84 | Kyuu | SSK | 268.1| Jane CE | Corsair K95 | X60R | HHKB JP x JS HiPro | 910 CE |Nunu |Nunu FE | Jane V2 CE|Jane V2| RS (TKL)
« Reply #189 on: Fri, 14 August 2015, 14:05:01 »
Yes, both 1.25-1.25-1.25-6.25-1.5-1-1-1.5 and 1.5-1-1.5-6-1.5-1-1-1.5 layouts are supported by the PLATE.
Offline trenzafeeds
  • **** off
« Reply #190 on: Fri, 14 August 2015, 14:43:28 »
Is there any chance of the buying period being extended, or are you holding firm Leandren?
Offline tea.nah
« Reply #191 on: Fri, 14 August 2015, 17:01:28 »
Yay! Ordered.
Time for 2nd keyboard build.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #192 on: Fri, 14 August 2015, 17:06:23 »
Sorry i can't do that because then it will take a very long time before orders can ship for the other who has joined.
You can extend the invoice my leaving me aa note in the form.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #193 on: Fri, 14 August 2015, 17:06:48 »
Yay! Ordered.
Offline trenzafeeds
  • **** off
« Reply #194 on: Fri, 14 August 2015, 20:34:58 »
Alright, ordered! Planning on putting it in my Pok3r's case, so I've already got the whole case thing covered.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #195 on: Fri, 14 August 2015, 20:35:45 »
Thanks for your order!
Offline bigDave
  • The biggest
« Reply #196 on: Sat, 15 August 2015, 18:02:04 »
Order plate, PCB and some accessories. Thanks for organizing this!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #197 on: Sat, 15 August 2015, 18:02:29 »
Thanks dude!
Offline tea.nah
« Reply #198 on: Sun, 16 August 2015, 00:34:43 »
So once you collect a couple orders, will you email us the invoice afterwards?
I wanna make sure I don't miss the email.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #199 on: Sun, 16 August 2015, 02:52:29 »
I'll mail everyone soon :)
