Author Topic: [IC] FingerSK (75% PCB)  (Read 19481 times)
Offline meiosis
  • Time
« on: Mon, 20 July 2015, 11:16:30 »
Going to have some 75% MX MINI style Pcb's made by Leeku (and will feature a custom design).
These support SMD RGB LED on the bottom for $3 more.
http://kbdlab.co.kr/index.php?document_srl=2760492&mid=board_Lsno50
For more information.
Controller parts will come presoldered, looking at around $48 per PCB. (before shipping)
Color's will be white font on matte black PCB
Sadly there are not any cases available at hand, but plates might be made at a later date.
Estimate ETA is sometime around mid August (14th)
TL;DR:
$48 per PCB (RGB LED Controller included) - not including shipping, proxy service available.
There are also extra Finger PCB's available (65%) as seen on the LZ-SQ
« Last Edit: Sun, 02 August 2015, 16:46:55 by Meiosis »
Keyboards:
Aripeko TKL
Re: [IC] Leeku 75% PCB
« Reply #1 on: Mon, 20 July 2015, 11:17:42 »
Too bad about the cases.
Offline meiosis
  • Time
« Reply #2 on: Mon, 20 July 2015, 11:18:57 »
Yeah, I will look into other options for those who really want a case, we are having plates made too.
Keyboards:
Aripeko TKL
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #3 on: Mon, 20 July 2015, 11:21:13 »
If needed I can make a plate design, or an acrylic case for it.
Offline kirkvomit
« Reply #4 on: Mon, 20 July 2015, 11:52:56 »
Is this plate programmable?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #5 on: Mon, 20 July 2015, 12:00:38 »
I think you mean PCB, but yes, his PCBs are programmable
Offline Karura
  • Professional Canadian
  • SKidata life.
« Reply #6 on: Mon, 20 July 2015, 12:34:18 »
To be clear, there will only be PCB offered :)
« Reply #7 on: Mon, 20 July 2015, 12:35:50 »
For the uninitiated.
Offline taylordcraig
« Reply #8 on: Mon, 20 July 2015, 12:36:56 »
Would the PCB fit RS84 cases?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #9 on: Mon, 20 July 2015, 12:40:25 »
Would these fit RS84 cases?
I honestly don't know as far as the PCB goes, but I could make the plate so it doesn't extend far out.
Offline HckrSvn
« Reply #10 on: Mon, 20 July 2015, 12:57:50 »
I'm interested!
Offline Dreamre
    • kbdlife
« Reply #11 on: Mon, 20 July 2015, 13:58:07 »
I'd totally be down for 1 or even 2 if we can get plates + cases.
Offline geniekid
« Reply #12 on: Mon, 20 July 2015, 15:16:59 »
What layouts does the PCB support?  Split backspace?
Offline Data
« Reply #13 on: Mon, 20 July 2015, 18:53:20 »
Also curious about layouts. Is it similar to Duck Octagon?
Offline meiosis
  • Time
« Reply #14 on: Mon, 20 July 2015, 20:20:27 »
Yes it is.
There will also be 65% PCBs available
Keyboards:
Aripeko TKL
Offline Sent
  • Simplistic Serenity
  • ¯\_(ツ)_/¯
« Reply #15 on: Mon, 20 July 2015, 20:34:41 »
Teehee.
Offline meiosis
  • Time
Re: [IC] Leeku 65% and 75% PCB+Plate
« Reply #16 on: Mon, 20 July 2015, 21:27:42 »
I might be able to secure an order form for the 75% PCB's as well, if there is GREAT interest, I may consider finding an alternate case (Acrylic)
Keyboards:
Aripeko TKL
Offline geniekid
« Reply #17 on: Mon, 20 July 2015, 22:00:42 »
Yes it is.
I should point out the Duck Octagon doesn't support split-backspace and I do not believe Leeku usually provides support for that configuration either.  Bottom row configurations are very versatile, however.
Offline meiosis
  • Time
« Reply #18 on: Mon, 20 July 2015, 22:02:26 »
Yes it is.
It does support split backspace!
« Last Edit: Mon, 20 July 2015, 22:23:59 by Meiosis »
Keyboards:
Aripeko TKL
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #19 on: Mon, 20 July 2015, 22:13:34 »
Leeku's newer board's support new layout's, including split everything
Offline geniekid
« Reply #20 on: Mon, 20 July 2015, 22:40:39 »
Awesome :D
Offline nmur
  • ಠ_ಠ
« Reply #21 on: Mon, 20 July 2015, 22:57:51 »
If we are unable to get this case, what options for 75% cases are out there?
Offline Data
« Reply #22 on: Tue, 21 July 2015, 09:50:16 »
Safe to assume SMD components will be pre-soldered?
I think I'm in for 1.
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #23 on: Tue, 21 July 2015, 10:56:41 »
Leeku usually has the controllers and everything except diodes & resistors soldered on
Offline Booper
    • omniclectic.com
« Reply #24 on: Tue, 21 July 2015, 11:04:11 »
I'm interested in a 65% pcb for sure! Do you know what color they will be? Will the 65% be the matte black as well?
boop!
Offline tjweir
« Reply #25 on: Tue, 21 July 2015, 15:17:57 »
Any images of the 65% pub?
Sounds interesting.
Offline meiosis
  • Time
« Reply #26 on: Tue, 21 July 2015, 20:21:46 »
Sounds interesting.
These are already made, it's the same PCB used in the LZ-SQ.
Just a red PCB, currently available at around $45, this might be our next project to make a case for! But we're more focused on a 75% for now, but it might be an option some people want
Keyboards:
Aripeko TKL
Offline Cameron
« Reply #27 on: Tue, 21 July 2015, 23:16:54 »
i'd be in for sure if there's a case and plate made made for it.
Offline meiosis
  • Time
« Reply #28 on: Wed, 22 July 2015, 00:40:59 »
We are in talks, there might be an acrylic case option!
Keyboards:
Aripeko TKL
Offline tjweir
« Reply #29 on: Wed, 22 July 2015, 05:36:39 »
Sounds interesting.
LZ-SQ you say?  Interested for sure then.
I'd like to give that layout a shot.
Offline meiosis
  • Time
« Reply #30 on: Wed, 22 July 2015, 05:38:03 »
Sounds interesting.
Yep, they are already produced. There aren't any plates currently for it, or any cases.. No real ETA when they will be done.
If you are still interested in the Bare PCB (controller parts soldered) I can inquire for you!
Keyboards:
Aripeko TKL
Offline tjweir
« Reply #31 on: Wed, 22 July 2015, 06:13:37 »
Sounds interesting.
Do "controller parts" mean all SMD parts soldered?
I don't have good enough gear for SMD work.
If it's just switches and LEDs then I'd take one now.
Thanks!!
Offline meiosis
  • Time
« Reply #32 on: Wed, 22 July 2015, 06:24:13 »
Sounds interesting.
Thanks!!
You just need diodes and resistors soldered, then add switches and LEDS.
If you want everything presoldered, there is a $10 charge diodes and resistors included.
(You're looking at $55+shipping for a completely soldered keyboard minus switches and the LED's)
If you want it direct from Korea you can order now (will probably cost more in shipping)
But if you can wait a month or so, we will be having a large shipment come
« Last Edit: Wed, 22 July 2015, 06:26:53 by Meiosis »
Keyboards:
Aripeko TKL
Offline Cameron
« Reply #33 on: Wed, 22 July 2015, 10:53:01 »
Sounds interesting.
Thanks!!
But are the SMD LED's soldered/included?
« Last Edit: Wed, 22 July 2015, 11:00:19 by Cameron »
Offline meiosis
  • Time
« Reply #34 on: Wed, 22 July 2015, 11:03:01 »
But are the SMD LED's soldered?
Yep, everything except your switches and choice of switch LEDS
Keyboards:
Aripeko TKL
Offline tjweir
« Reply #35 on: Wed, 22 July 2015, 14:42:52 »
How are Leeku PCBs programmed?
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #36 on: Wed, 22 July 2015, 15:16:12 »
Here is his GitHub which seems to have some sources as far as programming the boards, and then in this thread is some information:
https://github.com/leeku11
https://geekhack.org/index.php?topic=72783.0
Offline tjweir
« Reply #37 on: Wed, 22 July 2015, 15:18:36 »
Offline meiosis
  • Time
Re: [IC] FingerSK (75% PCB)
« Reply #38 on: Fri, 24 July 2015, 04:11:16 »
Ordering will start in a few days for the 75% - now named FingerSK
Keyboards:
Aripeko TKL
« Reply #39 on: Fri, 24 July 2015, 04:17:15 »
Offline Data
« Reply #40 on: Fri, 24 July 2015, 08:09:36 »
Nice.  My wallet is ready.
Offline Cameron
« Reply #41 on: Sun, 26 July 2015, 10:41:12 »
Will the group buy starting in a couple days include the plate/case? Or will we have to buy them separately. Shipping will hurt me way too much if they come separately. (australia)
Offline Norman_the_Owl
« Reply #42 on: Sun, 02 August 2015, 15:31:27 »
Is the RGB controller a physical controller or software based?
Edit: does the 65% have RGB or only the 75%?
Offline meiosis
  • Time
« Reply #43 on: Sun, 02 August 2015, 16:46:23 »
Both do,
Also for an update this buy will be moved to August 14th!
Keyboards:
Aripeko TKL
« Reply #44 on: Sun, 02 August 2015, 17:21:56 »
Both do,
Awesome, a date.
Also, the controller?
and does the 65% PCB support per key RGB? There is a very vague video of an "LZ-SQ" on youtube with RGB backlighting per key. This is a long shot, i'm just curious, and i can't seem to find any info about them elsewhere.
Edit:
« Last Edit: Sun, 02 August 2015, 17:25:28 by Norman_the_Owl »
Offline meiosis
  • Time
« Reply #45 on: Sun, 02 August 2015, 17:46:13 »
It's the same PCB norm :)
Keyboards:
Aripeko TKL
Offline sethk_
  • www.kbdhub.com
    • My webstore
« Reply #46 on: Sun, 02 August 2015, 17:47:01 »
RGB backlighting is usually not per-led and changing the color changes all of them. There usually are LED effects. I have been working on a case for the 65%, and 75% should be easy since I have most of the harder measurements though
« Reply #47 on: Sun, 02 August 2015, 18:53:29 »
Neat. I'm totally in, split spacebar is neat. I've been looking for something like that (in the 65% form factor) for a bit now.
Offline ika
« Reply #48 on: Tue, 04 August 2015, 00:04:59 »
August 14th pushes the date past Ivan's RS84 GB... what cases would be compatible with this PCB? I was considering a sprit 75%, if they're even available. Would it fit a Race II case?
Offline beltet
« Reply #49 on: Thu, 06 August 2015, 13:35:14 »
What is the case option for the 75%?
And is there a plate option? And what rgb led is needed?
« Last Edit: Thu, 06 August 2015, 13:47:00 by beltet »
