Author Topic: Rubber Dome/ "Quiet Touch" Model M's?  (Read 2247 times)
Offline macguy80
« on: Fri, 24 July 2015, 03:23:35 »
So, I am loving my bucking spring Model M, but I find that, apart from the click, I also find the noise of the keycaps themselves to be quite satisfying in its own right. Is that due to the PBT keycaps, or some other aspect of the construction at play? Mine is a Unicomp Spacesaver M.
Has anyone actually typed on a rubber dome Model M to be able to say whether the keycap noise is the same, minus, of course, the click of the buckling spring?
Offline chyros
  • a.k.a. Thomas
  • Hello and welcome.
Re: Rubber Dome/ "Quiet Touch" Model M's?
« Reply #1 on: Fri, 24 July 2015, 06:16:34 »
It's probably due to a combination of the switch construction as well as the acoustics and materials of the board. I've found PBT keycaps to actually sound inferior to ABS ones (more high-pitched).
Offline jerr
« Reply #2 on: Mon, 27 July 2015, 17:19:54 »
A quiet Model M would be dope
« Reply #3 on: Mon, 27 July 2015, 17:24:42 »
There is a Model M variant (I think it is called "Soft Touch") that is true buckling springs with a squirt of grease in the spring.
Rubber domes are rubber domes.
PS - ABS sucks - PBT all the way
- D Trump 2026-10-24
Offline jerr
« Reply #4 on: Mon, 27 July 2015, 17:44:34 »
Where can I get one?
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #5 on: Mon, 27 July 2015, 19:12:00 »
The IBM "Soft Touch" keyboard is extremely rare.  You might find one in 1,000 IBM keyboards.
Good Luck!
http://www.clickykeyboards.com/index.cfm/fa/items.main/parentcat/13192/subcatid/0/id/152083
« Last Edit: Mon, 27 July 2015, 19:16:14 by Snowdog993 »
Offline macguy80
« Reply #6 on: Mon, 27 July 2015, 19:21:09 »
I'd love to hear a recording or see a Youtube video of one in action, but apparently that is equally as rare. :)
