Author Topic: Removing the spacebar on a Filco Majestouch  (Read 6021 times)
Offline dfrey
« on: Tue, 06 October 2009, 10:19:06 »
Is it possible to remove the spacebar on a Filco Majestouch?  It looks like it has a metal bar under the key that prevents it from coming off in the same way as the other keys.
It feels a bit sticky, so I want to take it off and see what's up.
Offline dfrey
« Reply #1 on: Tue, 06 October 2009, 10:52:43 »
I watched the video and that helped.  I don't own a key cap puller, so I used a thin piece of string to slide between the keys and underneath before pulling up.  Do other people use this technique?
Offline timw4mail
    • https://timshomepage.net
« Reply #2 on: Tue, 06 October 2009, 11:15:02 »
Quote from: dfrey;123413
Some of us, when without a keypuller, just used a screwdriver.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline dfrey
« Reply #3 on: Tue, 06 October 2009, 11:35:18 »
Quote from: timw4mail;123423
I have heard that before, but string (or fishing line) seems like it would be a lot less likely to damage your board than wedging a piece of metal between the keys.
Offline msiegel
« Reply #4 on: Tue, 06 October 2009, 11:46:41 »
you'll have to mount that thing on a pole, to scare away all lesser boards... :)
Offline timw4mail
« Reply #5 on: Tue, 06 October 2009, 11:56:19 »
Ripster, you didn't cook that keyboard long enough, you can still make out Find and Paste on the front of the keys.
