Author Topic: How do you take apart Cherry Switches?  (Read 10938 times)
Offline erricrice
« on: Wed, 07 October 2009, 22:40:32 »
So I did some searching on the forum and looked in all the wiki pages and couldn't find anything on how to take them apart.
I was thinking maybe I could take the tactile leaf from the blues in my DAS and put them into the blacks on my 11900 and I was going to look in the switch to see if there is even a spot for a click leaf(or if it even uses anything similar to ALPS) and I realized I had no idea how to take apart the switch!
Linkage, pics or vids would be much appreciated!
I\'m selling all my Shizz! Please buy it!
White ALPS: Northgate Omnikey 101-NCS(Real-Complicated)****Filco Zero FKBN87Z/EB(Fukka Simplifieds)****Siig MiniTouch(XM Simplifieds)
Black ALPS: Black Dell AT-101W(Real-Complicated)****ABS M1(Modded Black ALPS, Linear)
Buckling Spring: Model M 1391401(1988 & 1993)
Cherry Blues: DAS III Pro
Cherry Blacks: Cherry G80-11900
Cherry Browns: 3X Cherry G80-8113LRCUS-2
Cherry MY: G81-7000HPBUS-2****G81-3000LANUS-0****Modded to 20g
Rubber Dome: HHKB Lite 2 (White & Black)
Logitech G5[/FONT]
Erricrice\'s Song of the Day: Gorillaz - El Maņana
Yup, Blatantly stealing this from you Kishy, hope you don\'t mind, it\'s a great idea.
Offline msiegel
« Reply #1 on: Wed, 07 October 2009, 22:47:13 »
Quote from: erricrice;123816
huh. i see what you mean...
offhand all i could find was this:
http://geekhack.org/showwiki.php?title=Island:4433
Offline o2dazone
« Reply #2 on: Wed, 07 October 2009, 22:56:04 »
http://my3c.com/D5/viewthread.php?tid=4625&extra=&page=1
edit: dont mind the moon language, the photos are very descript. I swapped the stiffer green switch on my g80-3000 with a blue switch so they all felt the same. I just used some paperclips and a bobby pin, nothing fancy.
Offline msiegel
« Reply #3 on: Wed, 07 October 2009, 23:00:43 »
Quote from: o2dazone;123819
that's great! :D
i was a little disoriented around the 7th step, when the switch opens and dozens of tiny switches pour out. took a second before i realized they "switched" perspectives ;)
Offline o2dazone
« Reply #4 on: Wed, 07 October 2009, 23:04:03 »
lmao
little did you know one cherry switch is full of 100 tiny switches! and each tiny switch is full of 100 micro switches!
Offline erricrice
« Reply #5 on: Wed, 07 October 2009, 23:06:30 »
Yeah, good stuff!
Awesome that you don't have to de-solder the switch with this method.  I was afraid I was going to have to do that for a mod of this type.
More on this later, once I have my way with this 'board...
Logitech G5[/FONT]
Offline o2dazone
« Reply #6 on: Wed, 07 October 2009, 23:11:19 »
It depends on the boards too. You will have to desolder the switch IF the pcb is above the area that you can hook under.
This is what I'm talking about
Although I believe the DAS III and MX11900 are both fully above the pcb
Offline o2dazone
« Reply #7 on: Wed, 07 October 2009, 23:28:41 »
doh, sorry I got your hopes up erric
Offline Rajagra
« Reply #8 on: Thu, 08 October 2009, 06:33:16 »
I found that one of the "forks" from a fondue set was the perfect size for opening Cherry switches, I just had to bend the tips back:
Did you just swap the slider (and spring)? It seems to me the metal leaves are fixed and extend through the bottom of the switch to become the solder tags.
« Last Edit: Thu, 08 October 2009, 06:39:15 by Rajagra »
Offline timw4mail
    • https://timshomepage.net
« Reply #9 on: Thu, 08 October 2009, 07:08:28 »
Quote from: Rajagra;123847
From my experience that seems to be the case. Not all of the leafs are the same, though. There are slight differences between each type of switch that effects the feel somewhat.
The slider and spring still make the most difference, though.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline erricrice
« Reply #10 on: Thu, 08 October 2009, 08:24:14 »
Quote from: ripster;123824
Das is plate mounted.  This method won't work. Gotta desolder.
Nooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
Love will find a way...
Logitech G5[/FONT]
Offline o2dazone
« Reply #11 on: Thu, 08 October 2009, 08:49:02 »
Just the slider and spring yeah. Do the leaves differ between the greens and blues?
Offline itlnstln
« Reply #12 on: Thu, 08 October 2009, 11:30:29 »
Quote from: o2dazone;123861
They shouldn't.  The only thing that should differ between any two Cherry switches is the slider and the spring.
Offline timw4mail
« Reply #13 on: Thu, 08 October 2009, 11:35:18 »
Quote from: itlnstln;123877
While they probably don't differ between the greens and blues, the leafs are subtly different on each type of switch. A linear leaf with a tactile slider is not the same as a tactile leaf with a tactile slider.
Offline itlnstln
« Reply #14 on: Thu, 08 October 2009, 11:40:56 »
Quote from: timw4mail;123878
The tactlity's not in the leaf on a Cherry, it's all in the slider:
http://park16.wakwak.com/~ex4/kb/tech_cherry_mx.htm
Offline timw4mail
« Reply #15 on: Thu, 08 October 2009, 11:51:18 »
Quote from: itlnstln;123883
More clearly, when I have combined parts from different switches, the switches did not feel only like the slider and spring, but also has some influence from the leaf. Subjectively, at least.
Offline itlnstln
« Reply #16 on: Thu, 08 October 2009, 12:06:17 »
There might be some wear that might be causing that, too.  Since the sliders are plastic, depending on which key the parts were pulled from/put into, they wear on the slider might be a little different.  The new "T" key might feel a little different than an old one,  or it might feel different than the "Q," for example.  I have never, personally felt any difference in swapping Cherry guts other than trading a less worn key for a more worn key.  The only other thing might be if you swapped between a Cherry-manufactured and a non-Cherry 'board (say, a Filco).  Apparently, they make switches for Cherry 'boards in another factory/assembly line than they do for non-Cherry 'boards (there is an early thread here that discusses this).  There might be some minor manufacturing difference that could explain the different feel.
Offline timw4mail
« Reply #17 on: Thu, 08 October 2009, 13:22:05 »
Quote from: itlnstln;123888
Actually, I had individual switches that I got from Digikey, and I've played around with the three I got, a blue, a "clear", and a black.
Having lost a spring inside a keyboard when pulling a key on my Cherry keyboard, I decided to swap out the brown slider for my white one, and comparing it to the one other white switch that came with the keyboard, it felt different.
Probably, it was just less lubricant on the slider, as the one I transplanted doesn't seem as smooth as the original.
I also replaced the gray switch for the spacebar with a black slider and spring, which actually feels a lot nicer, I'm almost thinking about making the rest of the modifier keys linear.
So, maybe there are differences, maybe there aren't, but considering the only thing that matters is how it feels to you, I guess it doesn't matter whether the leafs are identical or not.
Offline itlnstln
« Reply #18 on: Thu, 08 October 2009, 15:02:21 »
Quote from: ripster;123897
I've always thought that "custom" Cherry rumor to be completely bogus. Xsphat got that from a Manufacturers Rep. Anybody in Sales knows Manuf Reps lie like dogs.
I bet you're right, too.  It doesn't seem to make much sense to have more than one prouction line for the same item (unless you sell tons of them, or manufacturing time is slow like cars, for example).  It certainly doesn't make sense for Cherry MX switches.
