Author Topic: New user looking for advice on Model F  (Read 2974 times)
Offline JohnDoe77
« on: Sat, 01 August 2015, 22:53:34 »
Hi. New user here. Currently using a Model M 42H1292. It's pretty nice, but I've heard the Model F is even better.
I just so happen to have one. It's a Model F AT. It looks exactly like this one:
I found it in my dad's garage and he let me have it. It is dirty, so I need to recondition it. I also need to convert it to USB and convert it to ANSI. Is there some guide I can follow to do all that?
One concern I have is that it only has F1-F10. F11 and F12 are missing. Is there some easy way to solve it? Having to re-learn my hotkeys would be annoying.
Sorry for being clueless. I'm a total beginner.
Offline JohnDoe77
Re: New user looking for advice on Model F
« Reply #1 on: Sat, 01 August 2015, 22:56:07 »
By the way, I know this is not the correct place to post this. I'm not sure where I should, though. Could someone direct me to the appropriate board to ask for advice?
« Reply #2 on: Sat, 01 August 2015, 22:58:23 »
Well, if you do one of the converters, you can create a function layer.
Offline FrostyToast
  • Litshoard
« Reply #3 on: Sat, 01 August 2015, 23:00:27 »
You should put a new controller in it an program a function layer on your board for f11 and f12 on f1 and f2.
You might as well since you require a new controller for the ANSI mod.
Quote from: elton5354
Offline JohnDoe77
« Reply #4 on: Sat, 01 August 2015, 23:04:39 »
I assume "converter" is a Soarer's converter, right? People mentioned that on other sites. How do I get/make one of those? Is there a comprehensive guide or did someone else document their own repair/upgrade process so I can follow along?
« Reply #5 on: Sat, 01 August 2015, 23:07:02 »
There's xwhatsit and soarer's.  I don't know the functional differences between the two since I haven't used either, but I know some people prefer the xwhatsit.
Offline Snowdog993
  • Grace Under Pressure
  • Justifiably Clueless.
« Reply #6 on: Sat, 01 August 2015, 23:09:34 »
Orihalcon has the AT to USB Soarer's converter on Ebay.
https://geekhack.org/index.php?topic=64670.0
The one you want to get is this one:
http://www.ebay.com/itm/NEW-XT-AT-to-USB-Soarers-Converter-Remapping-Macros-NKRO-Support-IBM-Model-F-/281476427201
Please read on the notes at the bottom of the page to fully understand what it does and how it works.
« Reply #7 on: Sun, 02 August 2015, 02:20:08 »
Welcome to Geekhack!
For an F122 ISO to ANSI conversion, look here.  The same principal should apply to your Model F.
And a good place to post questions (or to create your own build thread) would be making stuff together (where, incidentally,. the other thread I linked is located).
