Author Topic: Custom-made handwired matrix keyboard  (Read 23326 times)
Offline fknraiden
« on: Wed, 05 August 2015, 19:21:18 »
I decided I wanted to go farther down the rabbit hole and make something that I could call my own.
Saw some of the awesome projects matt3o, lowpoly and a few other have done and wanted to see if I could do it myself.
So I went and got a plate cut locally here in PDX from Precision Laser. 16ga 316 SS #4 Finish.
Pulled some Vintage blacks off a NIB Wyse and lubed then with RO-59 and added red switch stickers. BUTTER!
Got some acrylic cut from a someone I met at Portland's Mechanical Keyboard Meetup. (thanks Chris)
Now the wiring begins:
Adding Diodes.
Adding Columns, I used 24ga Magnet Wire
Debated over how to wire up the teensy to all the columns. At first I tried lowpolys way of using a ribbon cable. Ended up using a piece of paracord and shoving 30ga wrapping wire into it. I think it looks very clean. I have some pictures with ribbon I might add if I find them or if there is interest, it would have worked fine.
I made my own extension cable for the removable cable and connected it to the teensy. I may figure out a better way of attaching the female Micro connector to the case.
Ended up with a little less room that I expected so I added in a extra clear layer that Chris gave me from the extra acrylic.
Got everything wired up and ready for keycaps
This will eventually be for sale along with the keycaps.
Thanks for reading! I'd love to hear your comments.
« Last Edit: Mon, 08 February 2016, 17:41:28 by fknraiden »
Offline neverused
Re: Custom-made handwired matrix keyboard
« Reply #1 on: Wed, 05 August 2015, 20:43:03 »
Looks beautiful
Offline TD22057
« Reply #2 on: Wed, 05 August 2015, 21:31:53 »
That looks fantastic!  Might be the nicest looking hand wiring job I've ever seen.  How did you get the wires inside the paracord?  And then extract them at the right locations?
Offline sethk_
  • Grand Master Wizard Pizza
  • www.kbdhub.com
    • My webstore
« Reply #3 on: Wed, 05 August 2015, 22:03:27 »
Where did you get the lube from? I think it's hard to come by.
Offline fknraiden
« Reply #4 on: Wed, 05 August 2015, 22:36:35 »
very carefully =P
I just made a tiny hole where I wanted them to come out, then fed it through to the end. Then I just had to pull on one and I could see where it was for connecting to the teensy.
From some member here on GH i dont remember.
Offline vvp
« Reply #5 on: Thu, 06 August 2015, 03:24:32 »
I can recommend this too. But I used 32ga (Ø 0.2 mm) wire. The thinner the wire the easier it is to work with it (the easier it is to burn through the insulation when soldering it).
Offline fknraiden
« Reply #6 on: Thu, 06 August 2015, 04:46:40 »
yes! i ran into a little trouble with this wire, maybe it was the tip i was using, but it isn't wanting to melt the insulation. I ended up taking my dremmel an took some off, a lot more work that I expected. I did get some 30ga recently and that flew off the second it made contact with the solder.
Offline Yoe
  • Alps & ISO <3
« Reply #7 on: Thu, 06 August 2015, 06:43:24 »
This looks absolutely awesome! I've been wanting to use magnet wire too, but never came around to ordering some. Looks really good with the paracord sleeve too.
« Reply #8 on: Thu, 06 August 2015, 06:58:18 »
Really like how the board turned out, congrats!
« Reply #9 on: Thu, 06 August 2015, 08:42:10 »
Bravo on your custom creation. That is really great work!
I especially like that you had wrapping wire to use for your controller connections. :)
Offline 0100010
  • Not Sure
« Reply #10 on: Thu, 06 August 2015, 09:15:53 »
Offline vvp
« Reply #11 on: Thu, 06 August 2015, 10:23:06 »
Get something in the range of Ø 0.15 - 0.2 mm. Set iron to 400 - 450 °C. And it will be a piece of cake. A blob of solder on your iron will burn through the insulation in a matter of seconds.
You can even order (or make yourself) a tool for it: https://en.wikipedia.org/wiki/Wiring_pencil
But it is not really needed.
Offline Yoe
  • Alps & ISO <3
« Reply #12 on: Thu, 06 August 2015, 10:29:30 »
Great advice! Thank you! :) There are different kinds of insulation too, right? Some easier to burn through?
Offline vvp
« Reply #13 on: Thu, 06 August 2015, 11:07:31 »
I heard so. I do not really know though.
If the wire is not too thick then a small blob of solder on your iron (which will surround the wire when you touch it) will burn through the insulation quickly. I used wires intended for electromagnets as well as wires bought with a wiring pencil and I did not notice a difference (provided the wire diameter is the same). My experience indicates that the most important things are wire diameter and the soldering iron temperature.
I do not really know whether the wires I used had different kinds of insulation.
If you have a choice then you can pick the wire which insulation is easier to burn (i.e. intended for soldering) but I would not bother too much about this.
Offline vvp
« Reply #14 on: Thu, 06 August 2015, 11:13:59 »
Here is an example of a Ø 0.25 mm bare vertical wire and Ø 0.2 mm horizontal magnet (enameled) wire.
Offline fknraiden
« Reply #15 on: Thu, 06 August 2015, 13:05:24 »
So tiny! Is that 3d printed?
« Reply #16 on: Thu, 06 August 2015, 13:33:41 »
I don't know if you followed my advice, or if it was serendipitous, but I'm SO glad someone finally made their custom board using the square switch holes and Cherry-only stabilizer holes! Makes for much more secure attachment of the stabs and switches.
Offline fknraiden
« Reply #17 on: Thu, 06 August 2015, 14:04:40 »
It may have been partly you, I read a ton of stuff. I just knew I'd run into issues down the road if the switches had any room to move. The alternative would have been hot glue, and that never looks pretty.
On the other hand, I don't plan on ever taking the intended caps off.
« Last Edit: Thu, 06 August 2015, 14:07:29 by fknraiden »
Offline fknraiden
« Reply #18 on: Thu, 06 August 2015, 14:10:58 »
Double post, but just wanted to thank everyone for the kind words, means a lot.
If anyone has any questions about something, I'll do my best at answering, or pointing you in the right direction.
Offline vvp
« Reply #19 on: Thu, 06 August 2015, 14:37:19 »
Yes. You can find a full picture of it here. I only wanted to post a picture of the magnet wire joints.
I plan to post more pictures in a week or two ... and a much more pictures about reach-ability of the keys sometimes later.
I'm glad you went with magnet wire since if you use a thin one (e.g. 32 awg) then it is easier than common thick wires with plastic insulation. We should raise awareness of prototyping with magnet wire :)
Offline fknraiden
« Reply #20 on: Thu, 06 August 2015, 15:31:28 »
Speaking of prototyping with magnet wire...
Thus guy is amazing.
Offline fknraiden
« Reply #21 on: Mon, 23 November 2015, 04:26:34 »
sorry to necro, but na, I didn't see your comment about that. I just knew the layout I wanted, and knew that I didn't want something that could budge in any way.
EDIT: and i just realized i already replied to that comment. sigh
Offline MaNiFeX
  • Wu Tang Killa Keebs
    • MaNiFeX.net
« Reply #22 on: Tue, 08 December 2015, 11:08:56 »
Just saw this...  SO sick.
Offline fknraiden
« Reply #23 on: Tue, 08 December 2015, 21:36:09 »
oh thanks, stalking my recent posts? lol
Offline livingspeedbump
    • KeyChatter
« Reply #24 on: Tue, 08 December 2015, 21:53:55 »
legitimately some of the cleanest hand wiring I've ever seen.
Fantastic job.
<- My Collection (so far)
Offline fknraiden
« Reply #25 on: Tue, 08 December 2015, 21:59:52 »
Fantastic job.
That means a lot Andy!
Especially from you bae =P
« Last Edit: Wed, 09 December 2015, 17:21:58 by fknraiden »
Offline Me
  • Location: Niskayuna, Capital Reigon, NY State, US, North America, The Atlantic, Earth, The Sun's Solar System, The Milky Way, The Quadrant of the Universe that the Milky Way is in, the known Universe, the whole Universe, the theoretical Multiverse, this dimens
« Reply #26 on: Mon, 26 April 2021, 09:56:43 »
Go to the 14th photo and scroll up and down on it, it looks so weird.
"In the end...the keyboard's most grand form of existence is as an ethereal bridge between man and machine...Each depression of the keys, evanescent.. Our transitory thoughts crashing into the web, carving canyons through the internet wasteland such that life may once again flourish..."
tp4, compendium of speed, 2015
